M2 Technical Topics > N55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > HELP | Weird front axle noise when driving slowly and turning (video)
      07-08-2021, 11:58 PM   #1
DailyDownshift
Battle Tactician
DailyDownshift's Avatar
453
Drives: TR G87
Unhappy HELP | Weird front axle noise when driving slowly and turning (video)
Here's a quick video of the noise, it happens when the car is moving forward or backwards very slowly with the steering wheel moderately to fully turned.
The noise started happening a while ago but seems to have gotten worse, some days it's not noticeable while other days it's very obvious. I tuned the car very recently so taking it to BMW is probably not an option as the warranty would be void for any drive train stuff.
Any suggestions are appreciated.
Last edited by DailyDownshift; 07-08-2021 at 11:58 PM.. Reason: clean up formatting of thread
      07-09-2021, 01:22 AM   #2
Dj_Quik
120
Drives: 2018 F80
Sounds like wheel bearings
      07-09-2021, 03:00 AM   #3
DailyDownshift
Battle Tactician
453
Drives: TR G87
From the bad wheel bearing videos I've seen on youtube, it sounds quite different. Hoping somebody with an M2 has had a similar problem
      07-09-2021, 06:45 AM   #4
David.m
Drives: M2 LCI 6MT BSM
If you've had any front suspension work done (springs/struts/top hats) it could be the top mount bearing binding or the sprint not properly seated in the bearing, alternatively could be the strut pinch bolt installed incorrectly (must be installed with bolt head facing forward & nut goes on from rear), not torqued correctly or maybe even re-used (it's a single use bolt).
If front suspension is all stock think I've read of another known issue with front strut/hub noise where there is dealer fix, maybe someone else can help with this or you'll have to do a search of the forum.
      07-09-2021, 12:51 PM   #5
3t3p
New Zealand
455
Sounds from description and video same as what I had. I'll find thread.
https://f87.bimmerpost.com/forums/sh....php?t=1819548
      07-09-2021, 10:13 PM   #6
DailyDownshift
Battle Tactician
453
Drives: TR G87
Haven't done any suspension mods at all, was planning on doing springs pretty soon but probably will hold off for the time being.
      07-09-2021, 10:16 PM   #7
DailyDownshift
Battle Tactician
453
Drives: TR G87
So the issue is from between the shock absorber and bearing housing? Was your noise the same as mine from the video?
      07-10-2021, 05:01 AM   #8
3t3p
New Zealand
455
Yes, same noise. You get it if dry steering or going over bumps under 30mph yeah? Or normal low speed steering too. Not influenced by braking. Sounds like a metallic creaking sound. It'll just be a loosened.
Funny how multiple threads now cropping up as our cars age together...!
      07-11-2021, 02:19 AM   #9
DailyDownshift
Battle Tactician
453
Drives: TR G87
Yup, metal creaking is exactly how I would describe it!
Tags
bmw m2
