M2 Technical Topics > Suspension | Brakes | Chassis > M2C front end rattle over repetitive bumps
      04-23-2021, 11:08 AM   #1
pablom2c
pablom2c's Avatar
125
Drives: 2020 M2C
Hi,
I bought my 2020 M2C used around 5 months ago and right now it only has 5,500 miles.
When driving normally over smooth roads either fast or slow I don't notice any strange noises, but when driving slow over sharper repetitive bumps and irregularities or a pebble road I feel a rattle from the front end, it seems to come from the bottom of the car as if something is loose? Over single regular speed bumps or cat eyes there is no noise.
Is this a normal suspension noise from the M2C during repetitive bumps? I haven't noticed that the rattle stops if I brake, it still seems to be there with or without braking. Steering feels good, nothing strange.
The car is stock, it only has Eventuri intakes and M Performance front lip (this doesn't feel loose but could it rattle?). I also looked in the engine bay and didn't notice anything being loose.
I have an oil change coming up soon and will ask the shop to check for anything loose in the suspension/brakes but if you have any ideas I would appreciate it.
Thanks.
CURRENT: 2020 M2 Competition (BSM)
Previous: 2008 135i
      05-03-2021, 09:31 PM   #2
Brokenbones
Drives: M2c and S2000
Originally Posted by pablom2c View Post
Hi,
Thanks.
Yup. Same going over cobblestone road. Think maybe it's noticeable because the disconnect between the numb electric steering and vibration feedback you'd normally feel through the wheel on a hydraulic steering rack?
pablom2c124.50
      05-11-2021, 03:28 PM   #3
pablom2c
pablom2c's Avatar
125
Drives: 2020 M2C
Thanks for your comments that might be true also. I was also thinking that since the M2C has less soundproofing than regular BMWs in rough roads the suspension noises are more obvious. I also have the active sound design disabled, not sure if that also cancels other road noises or if it only generates fake engine sound.
Previous: 2008 135i
      05-11-2021, 09:20 PM   #4
DanG
DanG's Avatar
Drives: 2018 M2 AW DCT
2018 BMW M2  [7.68]
ASD is only fake engine noise. I have mine disabled too.
      05-12-2021, 02:48 PM   #5
Billy_BMW
54
Drives: BMW M2 Competition
Absolutely no noise from my M2C and it’s on KW V3’s. If there’s a rattle on stock suspension, there’s a problem.
      05-23-2021, 11:20 AM   #6
ROBM2C
ROBM2C's Avatar
Drives: BMW M2C , DATSUN 260z, Porche
I had this same problem ...unknown front end rattled ...pings etc ...swapped out the oem suspension and wouldn't you know ....zero rattles and pings now .
      05-26-2021, 12:18 AM   #7
Karmic Man
Karmic Man's Avatar
1996
Drives: M2C
No rattles, I mean real rattles like a 20 years old shitbox with a lose steering rack
      05-28-2021, 12:55 PM   #8
Rumbloki
Rumbloki's Avatar
Drives: Faster than most
I hear a rattle from under the front end on startup. Is this normal?
Also, rattles in the rear on startup. I assumed this has to do with valves moving?
I've read on here that some cars were delivered with loose bolts on rear exhaust hangers.
Maybe I can find time to get under the car this weekend.
2021 M2C, HS, 6MT, ZED, 763M w/spinners, AA single, AA axle back, Turner High Kick, Turner shifter support, M pedals, honeycomb reflector delete, BC Racing DS series
      05-28-2021, 04:22 PM   #9
3t3p
New Zealand
455
OMG my car today, is doing as you describe. It occurs on slower bumps, is not linked to braking or accelerating. At first not doing it on steering then later seemed to be.
Its fairly high pitched but not a solid sound, tried to record with my phone to no avail.
On way to work sounded like debris got flung up underside of car at one point and wonder if started from there?
Car seems fine and getting coilovers put in in three weeks anyway I suppose...
      06-01-2021, 09:10 AM   #10
EDWYER
Yoda of mods
EDWYER's Avatar
1674
Drives: X5 RWD
2015 X5 RWD  [0.00]
2016 BMW M2  [10.00]
Get the upper strut mounts checked.
Current: 2020 Explorer ST (Agate Black Metallic), F15 SGM RWD
F87 AW (retired) F30 SBM 316rwhp/440rwtq (retired)
Follow me on Twitter: https://twitter.com/EdwyerCLT
YT: https://www.youtube.com/@DWYERGARAGE/videos
      06-08-2021, 12:18 PM   #11
Encanto
Encanto's Avatar
Drives: 2021 X3 M40i
Front left rattle?
      06-08-2021, 02:27 PM   #12
3t3p
New Zealand
455
Getting mine checked this Thurs
      06-10-2021, 06:45 AM   #13
3t3p
New Zealand
455
Back from garage, noise gone.
Here is their documentation:
'Investigated creaking noise from FOS mainly when turning. Checked tightness of control arms, rack, subframe. Stripped brake off to remove wheel bearing and check for any movement between housing, none found, cleaned off corrosion and rebuilt, noise still there. Eventually traced noise from between shock absorber and bearing housing. Applied a lock compound on joint and rebuilt, noise now gone.'
smknjoe234.00
CSBM52722.50
      06-10-2021, 01:04 PM   #14
M Fifty
844
Drives: M2 & 330CI
So the strut was moving in the bearing housing?
      06-10-2021, 01:09 PM   #15
3t3p
New Zealand
455
I thought it was odd, between shock absorber and housing. Don't know if they mean pinch bolt.
They def sorted it though!
      06-14-2021, 12:23 AM   #16
warrenw
Food Critic
warrenw's Avatar
South Korea
1086
Drives: 19 AW M2C, 21 M340i
I have the same problem.. But I'm on Ohlins plus camber plates. I had a shop re-grease the "cups" the suspension sits in which requires taking the coilover out partially, then they put it back together and the noise went away.
For a month. Now it's back.
      06-23-2022, 01:19 PM   #17
arturlnyc
Drives: 2017 M2
Same issue on my 2019 M2C - Driver's side front rattle over bumps at 16 MPH.
Been reporting this issue to my local dealer over the past couple of years. No resolution to date.
Going in for service on July 7th/22. Will report back.
EZ
      06-23-2022, 02:00 PM   #18
M Fifty
844
Drives: M2 & 330CI
Okay, noting the date on the post - I'll bite.
The bottom of the front strut is meant to be clamped into the Front Carrier (31212284001 and 31212284002) such that it cannot move independently. At all.
Your shop's "solution" was to add lubricant?
Go somewhere else in future...
chris7197334.00
      03-09-2023, 09:52 AM   #19
pablom2c
pablom2c's Avatar
125
Drives: 2020 M2C
Could it be the steering rack is noisy over slow bumps and it is not really a suspension related knock?
Previous: 2008 135i
      03-09-2023, 09:53 AM   #20
pablom2c
pablom2c's Avatar
125
Drives: 2020 M2C
Did the coilovers fix the rattle?
Previous: 2008 135i
      04-11-2023, 07:00 AM   #21
Carrera2RS
203
I had a slightly worn roll bar drop link and that was replaced and cured a small 'knock' over low speed bumps
      04-11-2023, 11:06 PM   #22
D.Yooras
Drives: BMW M2 MY18
I take it you haven't done front end work. Let me explain how this situation worked:
1) To find that problem the shop has to be good btw, that approach was methodically and correct.
2) The struts AND spindles on M2s are aluminum. Aluminum doesn't have the same characteristics under compression (clamping) that steel does (or even steel and aluminum clamped together). Unlike steel, aluminum crushes but doesn't spring back, or at least not as much. That means when you bolt two pieces of aluminum together, and torque to spec, the torque that bolt is applying will be reduced overtime. When that happens, the two pieces of aluminum will squeak and creak like crazy unless the bolt is re-torqued.
3) Given all the forces at work on the area where the strut meets the spindle, there is a lot of potential for movement as clamping force reduces. In fact, since the spindle is a pitch style bolt, the clamping force is exponentially higher per degree of rotation.
4) Proper lubrication and cleaning of the mating surfaces, is critical to ensuring the two parts are sufficient attached to each other. This is especially true after the parts had run loose for any noteworthy period of time. This is a somewhat known problem on these cars, my strut bolts where not tight enough when I installed camber plates and they had never been serviced by the previous owner.
So don't throw that shop under the bus, especially when they did things the right way AND solved the problem.
chris7197334.00
SDR5550.00
