M2 Technical Topics > Cosmetic Modifications > M2C Turner Motorsport Skid Plate
      05-17-2021, 09:19 PM   #23
ROBM2C
ROBM2C's Avatar
Drives: BMW M2C , DATSUN 260z, Porche
Just about to do this! Glad I came across this thread ...I will be doing that jb weld trick for sure !
      06-05-2021, 01:54 PM   #24
2020M2Competition
2020M2Competition's Avatar
429
Drives: Yes
Recently had mine installed by my shop
They tig welded in an aluminum grill for me to add a little extra protection
Went back and forth with them about whether to notch the skid plate to accommodate the plastic rivets, but they insisted it wasn't necessary
Things seem pretty secure without the plastic rivets, but I guess time will tell
      06-06-2021, 10:30 AM   #25
ROBM2C
ROBM2C's Avatar
@2020M2Competition
Looks good ! I wonder why they went with a screen that has such big holes .
      06-06-2021, 01:34 PM   #26
2020M2Competition
429
Drives: Yes
Originally Posted by ROBM2C View Post
@2020M2Competition
I chose this particular grill for a few different reasons
The larger holes should still allow for good airflow
It's made out of aluminum so it was easier to weld in
I also think the rectangular shape of the holes look good and goes together well with the rectangular opening of the skid plate
In any case, as I think most will agree, this grill should provide considerably more protection than nothing at all
      06-06-2021, 02:48 PM   #27
ROBM2C
ROBM2C's Avatar
Yes I agree ,
Looks great !
      06-11-2021, 07:11 PM   #28
BMW DIY Guy
BMW DIY Guy's Avatar
Drives: 2019 M2 Competition
2024 BMW M2  [9.80]
2017 BMW X1  [10.00]
2001 BMW X5  [10.00]
Just installed this myself, and will have a DIY video up shortly. I am really impressed with the construction and have no doubt it will do a great job. 8)
Check out my BMW DIY Channel on YouTube! E, F and G series projects from Active Autowerke, Bimmertech, Kies Motorsports, AvinUSA, Karbonius Composites and more!
** YouTube BMW DIY Guy **
'Nimona' G87 M2 Build Thread
'Lillith' F87 M2 Competition Build Thread
      06-12-2021, 12:52 AM   #29
stefan
stefan's Avatar
Drives: M2 Comp
What did you decide as a solution to the rogue rivet?
///M Power
      06-12-2021, 01:47 PM   #30
BMW DIY Guy
2024 BMW M2  [9.80]
2017 BMW X1  [10.00]
2001 BMW X5  [10.00]
Do you mean the plastic push rivets on each side that need to come out? If so, I just took them out.
      06-19-2021, 04:19 PM   #31
Rick4345
Rick4345's Avatar
472
Drives: 2022 WRX World Rally Blue
I wish they made these for the OG M2!!
Rick
      07-07-2021, 09:07 PM   #32
DARKMTTR
DARKMTTR's Avatar
229
Drives: '20 M2 Competition & '18 X1
Thanks for the tutorial OP and for all the recommendations from the others for adding the mesh.
I finally got around to installing the TMS Oil Cooler Guard / Skid Plate. I got the black powder coated version and also installed a bit of black mesh for added protection. It took around 2 hours by myself, but fitment was perfect. Its an incredibly solid piece and provide the protection the oil cooler needs.
2020 BSM M2 Competition | Blue Stitching | 6MT | Sunroof | My M2C European Delivery Story! | AA EL Midpipe | TMS Skid Plate
      07-08-2021, 04:19 PM   #33
M Fifty
844
Drives: M2 & 330CI
The OG doesn't have the same type of intercooler, so doesn't need to to be protected in the same way. But, I'm sure you can fit one if you want?
      07-08-2021, 04:39 PM   #34
Rick4345
Rick4345's Avatar
472
I hit something a while back and took a chunk out of the plastic guard. I replaced it easy enough. If definitely buy the metal equivalent if available. I live in the country. I've seen anything from badgers to snapping turtles that are as long as two lanes wide.
Rick
      07-08-2021, 04:55 PM   #35
omasou
omasou's Avatar
Drives: BMWs
2023 BMW S1000RR  [0.50]
2022 BMW F900XR  [3.00]
2022 BMW X6 40i  [0.50]
2020 BMW M2C  [9.50]
Originally Posted by ZL9M2 View Post
Yes, or maybe as usual we're all too worried about something that probably may never happen?!!!
That and a new oil cooler is less expensive than the aluminum part that won't do anymore than the plastic part.
I'm more worried about the opening and rocks.
      07-12-2021, 03:01 PM   #36
BMW DIY Guy
2024 BMW M2  [9.80]
2017 BMW X1  [10.00]
2001 BMW X5  [10.00]
It isn't just that the oil cooler is cheaper.. its failure while driving and associated costs and damage. Failing on a long trip, tow costs, loss of oil to the motor and an infinite number of other possible scenarios.
Even if the oil cooler was free I would still do this upgrade, but doubly so if you uograde the oil cooler as well.
      07-12-2021, 03:25 PM   #37
omasou
omasou's Avatar
Drives: BMWs
2020 BMW M2C  [9.50]
I had a small rock take out my E30 325iX oil cooler at a toll booth. Believe me you'll know rather quickly that it's leaking.
The challenge I have with the skid plate is that it has the same exact design as the factory part. If I don't add mesh that is small enough to deflect smaller debris and maintain airflow I've accomplished nothing. That leaves larger debris like rocks and tree limbs, which will take out my front end first and then probably bend the metal up into the oil cooler. So same result a new oil cooler plus if it's that big probably a new oil pan and maybe even the diff.
Additionally, being more "robust" it will rip out the rivets holding it on so you will may actually have higher repair costs associated with the collateral damage.
      07-21-2021, 07:29 PM   #38
ROBM2C
ROBM2C's Avatar
@omasou
The point of the skid plate being aluminum rather then plastic is for head on collisions with objects that would otherwise tear through the plastic and get to the cooler . The amount of protection beyond stock is tenfold.
      11-29-2021, 11:53 PM   #39
Twilson25
I've been around
Twilson25's Avatar
Drives: 2020 M2 Competition
What's the OEM part number it replaces?
2020 M2C
      12-01-2021, 09:24 AM   #40
BMW DIY Guy
2024 BMW M2  [9.80]
2017 BMW X1  [10.00]
2001 BMW X5  [10.00]
It should be: 51758079566
      02-28-2024, 07:15 PM   #41
parraline5750
parraline5750's Avatar
Drives: 2020 M2C
Attachment 2643952
I just ordered this piece for 2020 M2C, and thanks to all who have put up install help. For those who added mesh yourself, did you go with aluminum or stainless mesh? And am curious approximately what size the grid gaps were, pictures little hard to guess scale. Thanks.
