M2 Technical Topics > Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls > Pass side A pillar rattle?
      05-24-2017, 02:49 PM   #1
racer34v
Drives: 2017 M2
Anyone else have a rattle emanating out of where the pass a pillar meets the dash? Shows itself inconsistently on back roads. Emptied the glovebox contents just to be sure and its the same. Not speed sensitive.
      05-25-2017, 12:50 AM   #2
mjsaville
101
Drives: M2 LLB - Arrived 4th Mar 2017
I have rattle from the triangular piece in the door, which is vey close to where your rattle is? Mines not all the time though, just on rough surfaces. As i have hi-fi sound only and not HK sound. I will be installing the HK speakers at some point, so will be reseating everything then.
MJ
      05-26-2017, 04:06 AM   #3
racer34v
Drives: 2017 M2
It seems to come more out of the dash, I do have the HK tweet in the door.
      05-26-2017, 06:06 AM   #4
MagnusT
MagnusT's Avatar
Sweden
538
I have it too. Was on the list of things when I left it in for service. They did not manage to find what it is or fix it.
      05-26-2017, 01:18 PM   #5
OG///M
Always +10MPH
OG///M's Avatar
Drives: 6MT
Yes. The interior rattles. A lot. The stiffer suspension doesn't help.
Can try to ask the dealer to try to find and fix it. But it doesn't always gets fixed.
Do I care? Not really. Think about this, the M4 GTS rattles like crazy too.
      05-27-2017, 09:57 AM   #6
David1
David1's Avatar
Drives: 09 E92 09 X5
Every BMW i have had rattles inside or just makes noises. The window noises around the edges are fricking annoying.
      03-17-2020, 06:21 PM   #7
bartginger
I have had it since new (2017). Just got it addressed; we'll see when I pick up the car today if it is fixed or not. Here is what the repair order says:
"customer states there is an intermittent rattle in the cabin when going over
rough pavement. It is coming from the right side near the A-pillar customer
going on test drive with shop fore man cc"
Cause:
Correction: TEST DROVE VEHICLE AND VERIFIED COMPLAINT. FOUND NOISE COMING FROM DASH
AREA ON PASSENGER SIDE. REMOVED A-PILLAR AND PASSENGER AIR VENT. TEST DROVE
VEHICLE AND FOUND NOISE STILL PRESENT. REMOVED CENTER VENTS AND TEST DROVE
VEHICLE. FOUND NOISE STILL PRESENT. REMOVED DASH AND FOUND A BOLT THAT HOLDS
SKELETON FRAME TO VEHICLE LOSE. TIGHTENED BOLT AND REINSTALLED DASH. TEST DROVE
VEHICLE AND FOUND NOISE NO LONGER PRESENT. REINSTALLED ALL OTHER PARTS. TEST
DROVE VEHICLE ONE LAST TIME AND FOUND NOISE NO LONGER PRESENT.
      03-17-2020, 08:57 PM   #8
bartginger
Part two: picked up the car this afternoon, got five minutes into the drive home before the exact same rattle started again. Took it back to the dealership again. It has already been there for 8 days.
      03-17-2020, 10:59 PM   #9
AndrewC1989
AndrewC1989's Avatar
Drives: 2015 328d xDrive
https://f87.bimmerpost.com/forums/sh....php?t=1546468
      03-18-2020, 12:51 PM   #10
bartginger
Originally Posted by andrewc89 View Post
Thank you Andrew; my car is already back at the dealership but I forwarded your reference post directly to my Service Advisor and asked him to give it to the technician to look at. Thanks for your help and we'll see what happens. I seriously hope they don't remove my windshield....
AndrewC198910931.00
      03-22-2020, 07:59 AM   #11
nelsdvn
Gangnam Member
nelsdvn's Avatar
Drives: '17 M2, '15 X5d
This!! I had my dealer perform the TSB a few weeks ago. Completely fix a very annoying noise. This is my third 2 series car (F22, F22, F87) and the first to exhibit this noise. The dealer had the car for a few days to complete.
Current: 2015 BMW X5d | 2017 BMW M2 | 1976 BMW 90S
Gone but not forgotten: 2016 BMW 228i, 2014 BMW 228i, 2008 BMW 535xiT, 1998 BMW 328iC, 1991 BMW 325iC
      03-25-2020, 06:39 PM   #12
3t3p
New Zealand
455
Why would you install the cheap nasty HK speakers?! Get some focals in there
      03-28-2020, 10:27 PM   #13
MiamiM235iEstorilBlue
Drives: 2016 m235i
I've never seen/heard just swapping speakers do much at all without also adding a more powerful amp. Is it different in the M2? Focals make a big difference on their own?
      04-18-2020, 03:33 PM   #14
bartginger
Part Three: another two weeks went by. I was told by the dealer the rattle has been fixed and was determined to be a loose screw in the "aftermarket" (actually, it's a BMW carbon accessory) passenger mirror cover. Does appear to have resolved the issue though, and I am grateful they did not have to resort to removing the windshield under the TSB I mentioned above.
