M2 Technical Topics > N55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > BMS clutch stop = awesome
      05-10-2016, 09:28 PM   #1
supersam
Da Baus
supersam's Avatar
Drives: F87 6MT, RA, E46
Put in the BMS clutch stop, o - m - g. I loove, love, love it. Install took 2 minutes; remove two 10mm bolts with a socket wrench and pull the panel partially down. You don't need to remove the driver-side kick panel. You can see the stock clutch stop, its puny. Pull it out by hand. Stick in the BMS one.
1) I used 2 of the 3 shims provided (they were all the soft type, not the hard metal washers). Feels great, I don't think I'd want to put in the 3rd one. your milage may vary
2) engagement point is now 12-14mm off the floor instead of 35-ish mm
3) haven't had it in bad traffic, but I could already tell it will be somewhat of a relief from the dramatic decrease in leg work
4) no problems with full clutch disengagement, no problem with cold/hot start
5) maybe its placebo, but rev-matching for yourself even feels more fun with the decrease in pedal travel
totally worth the 10 bucks to try. if you don't like it, sell it to another forum member for $5 haha
Fabspeed/Wagner/ER/Eibach/UCP/RTD
RA Evo X/WhalenTuned/AMS/ETS/UR/AEM/Swift/RRM/VIS/ID
E46 330ci --> S54 M3 xplant vzv 3bananas (retired)
Deso130.00
      05-11-2016, 01:14 PM   #2
DrKevM5
DrKevM5's Avatar
Drives: G05 X5, F87 M2
ORDERED! Awesome find. Thanks! This clutch travel is WAY beyond the point of engagement.
      05-11-2016, 03:06 PM   #3
TunedM2C
TunedM2C's Avatar
Drives: 2016 LBB M2
Yes, this is a must have for us manual folks.
      05-11-2016, 08:04 PM   #4
TTFS
TTFS's Avatar
130
Drives: M2, F10 M5, E46 M3, E90 M3
We did this about 200 miles in and it was well worth every penny.
      05-17-2016, 07:56 AM   #5
DrKevM5
DrKevM5's Avatar
Huge difference. Actually no panel removal is necessary. Located stock stop under the flexible shield, reached in and pulled it out, stuck the new one in. Easy peasy.
      05-18-2016, 11:36 AM   #6
BruceM
Drives: '17 6MT MG M2,930,Jag XKR 5.0
So, this is a true newb question, but where exactly does this product stop the action of the pedal? Some distance after the engagement point that is shorter than stock?
      05-18-2016, 12:59 PM   #7
DrKevM5
DrKevM5's Avatar
Exactly
      05-20-2016, 08:19 PM   #8
Fatal Flash
Drives: M2/i8/M3 GTS3/335is/KTM390 Cup
Ordered! Forgot about this component I've been off my manual game so hard! Car isn't here yet but this is en route! Thanks!
      06-18-2016, 07:17 PM   #9
Detailers Domain
Detailers Domain's Avatar
Drives: 20 M2C / 22 X3MC
got the link to this
      06-18-2016, 07:29 PM   #10
supersam
Da Baus
supersam's Avatar
http://www.burgertuning.com/clutch_stop_BMW.html
Corinne1171.00
      07-18-2016, 05:51 PM   #11
S65V8
*_*
Drives: ...
yup, this has been sitting around for a while in my toolbox. This works great, super easy to install, used all three shims to really get the full benefit of decreased pedal travel.
While I never really pushed the pedal to the floor to shift, this now provides a real floor to the level of where my foot pushes the pedal (no empty floor feeling any more).
      11-12-2016, 03:33 PM   #12
CosmosMpower
CosmosMpower's Avatar
2051
Drives: F87c, GT3, MK7 GTI
+1 just get a flashlight and shine it up behind the rubber flexible shield/trip that surrounds the pedals. The factory clutch stop is a white round rubber nub. Just yank it out and then push the BMS one in fairly hard and it will pop in.
      11-15-2016, 11:58 PM   #13
kevlee23
kevlee23's Avatar
72
Drives: 2008 e92 335xi, F87 M2 AW EXEC
Does anyone have a pic DIY location st least
      11-16-2016, 12:22 AM   #14
BAN_M2C
BAN_M2C's Avatar
4185
1987 BMW 325is  [10.00]
2004 BMW X3  [6.50]
2018 Porsche 911 GT3  [10.00]
1974 BMW 2002tii  [10.00]
2004 BMW M3  [10.00]
http://www.burgertuning.com/instruct...lutch_stop.pdf
Follow me on IG
Garage: 2018 991.2 GT3|2013 135i|2004 M3|2004 X3|1987 325is|1987 325i|1974 2002tii
      11-17-2016, 06:54 AM   #15
twin fed
Doc Brown
twin fed's Avatar
1176
Drives: 2016 MG MT M2
I just installed mine. It literally took me 30 seconds. You don't even need to remove any trim like BMS says to. Just stick your hand through the little slit in the rubber shield on the underside of the dash where the pedal goes through and you can feel the OEM stop, just pull it out and stick in the BMS counterpart. Super easy. I used all three shims. I haven't driven the car yet but I definitely notice a difference just by depressing the clutch pedal.
      11-17-2016, 08:46 AM   #16
DCM2
DCM2's Avatar
Drives: LBB 6MT M2!
Are there any errors or issues that pop up? I remember reading somewhere that occasionally the car doesn't want to start when the clutch isn't fully depressed to its OEM position
2017 F87 ///M2 LBB 6MT
AndrewC198910931.00
      11-18-2016, 09:25 AM   #17
bi0hazard
bi0hazard's Avatar
133
Drives: '17 m2
Just installed . Put on 20 miles. Feels really good. I used all three shims. Is there a reason not to use all 3?
B
      11-18-2016, 11:19 AM   #18
kevlee23
kevlee23's Avatar
72
Okay cool mine will be here today, I put it on my e92 that was easy wasn't sure if the set up was different under there for f82
      11-21-2016, 02:06 PM   #19
kevlee23
kevlee23's Avatar
72
Tried pulling it out it's so hard to pull out but so who here thinks 2 shims is good or 3?
      11-21-2016, 02:27 PM   #20
twin fed
Doc Brown
twin fed's Avatar
1176
So maybe it's me but I don't notice any real difference. I never pushed the clutch down all the way to begin with as I knew where the clutch engaged. I was expecting some miraculous difference, oh well......
      11-30-2016, 01:55 PM   #21
switlikbob
Chuggin' Along
switlikbob's Avatar
Drives: 2017 LBB ///M2
I drove without a clutch stop for years in my e36. Installed one, drove it for a while longer, got used to it. Then it broke. That's when I really noticed a difference.
However, I did buy a BMS unit...still waiting for M2 to arrive at dealership.
      12-28-2016, 09:47 AM   #22
mssVT98
mssVT98's Avatar
142
Drives: 2017 M2
2017 BMW M2  [9.67]
Probably overkill on this subject at this point, but I just installed mine, and this is exactly right. No need to remove anything to get to it. In fact, after looking at this link to know what I was looking for - http://www.burgertuning.com/clutch_stop_BMW.html - I didn't even have to see it. I just felt behind the clutch through the rubber flaps, yanked out the factory stop and then pushed in the BMS one. Really couldn't have been easier. Best $10 mod ever?
