M2 Technical Topics > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > DIY: Rear View Mirror "Upgrade"
      07-23-2020, 01:21 AM   #1
Matt Devo
Recovering RS4 owner
Drives: 2017 M2
2017 BMW M2  [0.00]
One of the few minor defects on the 2017 M2 I acquired a few weeks ago was two small scratches on the rear view mirror, which were just annoying enough from the driver's position that I needed to do something about it.
After checking the classifieds here and not finding anything, I decided to hit up ebay and see what I could find. Came across a more modern looking mirror off a 2019 X3 with the same features as the one in my M2 (auto-dimming, homelink, alarm LED) for less than a like-new replacement, and decided to give it a shot. The part # I used is 51166995975.
After receiving the new mirror, I removed the stock mirror and immediately noticed that the mounts and connectors were different. No problem, I'll just swap them over, as the # of pins and wire colors were identical.
The stock M2 mirror uses a 10-pin connector (5x2), with the following arrangement:
3: +12v (red)
6: homelink (white/blk)
9: alarm (blue)
10: ground (brown)
The X3 mirror uses a 6-pin connector (6x1), with the following arrangement:
1: +12v (red)
2: homelink (white)
3: alarm (blue)
4: ground (brown)
As the mounts are slightly different, both in attachment to the windshield and cutout for the wiring connector, you'll need to swap them. De-pin both connectors (opening the locking tabs on the connectors, and then lightly pressing on the tab on each pin to allow it to be removed. You'll need to do this twice for each pin as there's 2 stops/lock points. Once you have the connectors removed, move the wiring out of the way and pull off the mount/ball from the socket in the mirror.
I laid the mirrors face down on a towel folded over many times, sprayed a tiny bit of GDL (garage door lube) on the ball, and used another towel to grip the mount and pull **hard**. That pop you hear when it releases will almost certainly momentarily cause you to think you broke the mirror. After removal, move the mount from the stock mirror over to the new one, route the wiring up through it, and press down hard. Another pop, another moment of panic.
After you gather your wits, route the wiring up thru the front exit of the mount, and re-pin the stock connector. Start all 4 pins in their correct slots with the correct orientation, then push forward together, taking care not to jam/break any of the pins (I did this, and had to cut/splice in one from the stock mirror). Re-engage the locking tabs, and then reinstall in the car.
In addition to being an aesthetic upgrade, the X3 mirror provides a slightly wider FOV, and the homelink buttons are IMO much easier to push. I'm happy with the result.
My stock mirror is listed in the classifieds for anyone who might want it for parts
cheers,
Matt
Appreciate 12
cncmastr1603.50
gphung193.50
OKCZ11.00
AndrewC198910949.00
StephGOD218.50
Poochie9107.50
BFLY80.00
cpow9946.00
dtmurf486.00
      08-03-2020, 11:34 PM   #2
StephGOD
KYHOMPB
StephGOD's Avatar
Drives: Only BMW's Ja
2020 M2C  [0.00]
2017 M3 Comp  [0.00]
2011 135i  [0.00]
I've always hated the narrow FOV produced by the OEM mirror in comparison to other BMW's I've owned previously but never thought there was an easy direct swap until I stumbled upon this post. Going to give this a shot here soon once I find a reasonably priced X3 mirror on eBay. Thanks for the write up man, much appreciated!
      08-04-2020, 08:40 AM   #3
OKCZ
Drives: BMW M2 2017 MT; MINI GP2 2013
Great upgrade Matt, you inspired me to do the same. Result is perfect. It was not that hard to swap it. I used P/N 6830616 (LED + EC)
      08-04-2020, 09:15 AM   #4
Matt Devo
Drives: 2017 M2
2017 BMW M2  [0.00]
awesome, thx for the additional pics
      08-07-2020, 04:34 PM   #5
Poochie
Luxury at the redline :)
Poochie's Avatar
Drives: 2016 M2
But you lost the compass with the X3 mirror, didn't you?
///M TOWN22347.50
      08-07-2020, 06:58 PM   #6
Matt Devo
Drives: 2017 M2
2017 BMW M2  [0.00]
with this particular one, yes. I've used a compass exactly zero times over the past 20 years, and there's one on the nav if I really need it. If anything, I'm happy to be rid of it as it's cleaner without
Appreciate 4
Poochie9107.50
StephGOD218.50
///M TOWN22347.50
AndrewC198910949.00
      08-07-2020, 07:01 PM   #7
Poochie
Poochie's Avatar
Drives: 2016 M2
I never use it myself, it's cool to look at though... 😛
Just clarifying that it's gone, that's all..
Thanks for sharing
      10-18-2020, 08:24 PM   #8
///MaDeuce
Curious if the stem size is the same as to not require a different BlendMount for my radar detector? Very cool mod though, definitely thanks for sharing!
      03-16-2021, 06:20 PM   #9
BMW DIY Guy
BMW DIY Guy's Avatar
Drives: 2019 M2 Competition
2024 BMW M2  [9.80]
2017 BMW X1  [10.00]
2001 BMW X5  [10.00]
Super useful info thank you! If I am reading realoem correctly, referenced against my VIN lookup, looks like I would need 51169476753
For vehicles with
Alarm system
and
Interior/outside mirror with auto dip
and
Interior mirror with automatic-dip
S302A=Yes
S430A=Yes
S431A=Yes
I have all of those plus anti-dazzle..
For vehicles with
Integrated universal remote control
and
High-beam assistant
S319A=Yes
S5ACA=Yes
So I think that all boils down to.. 51169476753.. I think..
Check out my BMW DIY Channel on YouTube! E, F and G series projects from Active Autowerke, Bimmertech, Kies Motorsports, AvinUSA, Karbonius Composites and more!
** YouTube BMW DIY Guy **
'Nimona' G87 M2 Build Thread
'Lillith' F87 M2 Competition Build Thread
      03-17-2021, 08:46 AM   #10
Matt Devo
Drives: 2017 M2
2017 BMW M2  [0.00]
For vehicles with
Alarm system
and
and
S302A=Yes
S430A=Yes
S431A=Yes
For vehicles with
and
High-beam assistant
S319A=Yes
S5ACA=Yes
I have all the same features as you I believe. As long as you get an EC mirror, your side mirrors will function properly. HBA etc are all handled by the camera not the mirror so unsure how that relates other than mounting config
      03-17-2021, 08:54 AM   #11
BMW DIY Guy
2024 BMW M2  [9.80]
2017 BMW X1  [10.00]
2001 BMW X5  [10.00]
I am really intrigued by the mirror I saw in the new G80.. (not sure yet if its the same, realoem doesn't have that new listed yet)
Its basically borderless and looks really good!
      03-28-2021, 11:56 PM   #12
BMW DIY Guy
2024 BMW M2  [9.80]
2017 BMW X1  [10.00]
2001 BMW X5  [10.00]
I struck gold and found what appears to be the correct G2X/G8X mirror for my F87 on German ebay!
They wanted 450 euro for it, offered 200 and they accepted!
Thank you for figuring all.of this out! Figure worst case scenario even if this mirror doesn't work out, I should be able to resell easy at break even price or better.
      04-03-2021, 06:00 PM   #13
BMW DIY Guy
2024 BMW M2  [9.80]
2017 BMW X1  [10.00]
2001 BMW X5  [10.00]
Aaaaaah yeah....
      04-03-2021, 06:01 PM   #14
BMW DIY Guy
2024 BMW M2  [9.80]
2017 BMW X1  [10.00]
2001 BMW X5  [10.00]
new mirror is in!
      04-03-2021, 09:32 PM   #15
chip_dip19
151
Looks good. I still need to find a mirror to do this
      04-03-2021, 10:43 PM   #16
BMW DIY Guy
2024 BMW M2  [9.80]
2017 BMW X1  [10.00]
2001 BMW X5  [10.00]
The DIY video is finished and I will upload it to my channel, and share here as soon as it is ready.
      04-04-2021, 08:36 PM   #17
Matt Devo
Drives: 2017 M2
2017 BMW M2  [0.00]
new mirror is in!
looks great! but doesn't appear to be any different than the G01 X3 mirror I used ;-)
      04-05-2021, 08:46 AM   #18
BMW DIY Guy
2024 BMW M2  [9.80]
2017 BMW X1  [10.00]
2001 BMW X5  [10.00]
Actually hugely grateful for your post, and yeah the mirror is the same. It appears quite a few of the new G models use that new design!
Thanks for posting this or I would still be off hating my mirror! Your instructions were dead on and I followed your lead.
Well done, thanks again!
Matt Devo296.50
      11-12-2021, 01:49 PM   #19
gphung
194
Drives: 2018 M2 LBB - 6MT
2018 BMW M2  [0.00]
Stumbled across P/N 51162471107, which appears to be an official OEM option for frameless G-series style mirror for F series vehicles (including F22, which I assume will work for our cars). If you do a quick search on google you will also find the installation pdf.
Is it just me or is this mirror even more "frameless" looking? It seems from some pictures online there's less black bezel than the ones mentioned in this thread.
      12-09-2021, 06:48 PM   #20
AM9
Drives: M2C
Can confirm it fits F87N. Straight forward installation, all pins are exact just unplug and swap new unit in. As easy as it gets. A wider FOV, more glass area and so much cleaner look. FYI the red alarm flashing bulb is now way brighter. Cant miss it now.
Thanks for the P/N!
If anyone needs pictures let me know.
      12-09-2021, 08:34 PM   #21
iRasF87
Drives: MG_'17Ⓜ2
Thanks for the P/N!
Yes please post pics. Will this mirror be plug n play for my OG as well? Any helpful instructions in the removal of old mirror would be appreciated.
      12-09-2021, 10:46 PM   #22
AM9
Drives: M2C
Not sure as I have the M2C but the retrofit states F22 so I would presume all F 2 series would work.
I will take pictures tomorrow day time so you can view the mirror.
Honestly as far as tips, its crazy easy. Open the plastic covers, I used my fingers with pressure and a plastic trim tool; pull plastics aside, unplug the mirror connector, then slide old mirror straight down with a bit of force, mine slid right off.
New mirror matched up in pins so I just plugged it in, and slid it back straight up and in with a bit of force until it clicked in (took maybe 2-3 times as I was afraid to go too hard). Put plastic covers back in and voila!
All in all 10 mins top
** added a screen shot of where to order and Part supplied PDF
FYI they ship insane fast got stateside in 2-3 days max!
iRasF8713.50
