06-13-2018, 03:47 PM | #45 | |
3525
Rep 6,752
We have actually attempted this on our EC-7, SM-10 and FL-5. These wheels will not clear the OEM CCB optional brakes. Due to the size of the CCB package brakes, you will need to use a 19" wheel at minimum. - Max
Bee Pee1779.00 |
06-22-2018, 02:18 PM | #47 | |
3525
Rep 6,752
That's a great question! The 19x10" ET25 wheel is just a bit too aggressive in the rear and will cause issues with fender side clearance. We would recommend the following rear fitment for your M2: Rear: 19x9.5" ET33 - 265/35-19 I hope this information was helpful. If you have any further questions, feel free to reach out to me! - Max
06-26-2018, 12:20 PM | #49 |
3525
Rep 6,752
kpaso,
We do not have any 18" FL-5 sales waiting in the wings at this time. Please keep an eye on our website, this forum or our social media channels for any new sales that could come up in the future! - Max
10-04-2018, 02:58 AM | #51 |
Rep 117
Hi. Has anyone managed to fit 18" ARC 8's to a stock M2? If so, what is the best plug and play solution without modification/spacers etc?
I'm after a track/drift setup and love the ARC 8's. |
10-04-2018, 09:01 AM | #52 |
Rep 1,084
ARC-8 barrels don't clear the brakes
10-04-2018, 09:42 AM | #53 |
Rep 117
This seems to disagree:
https://support.apexraceparts.com/hc...-Fitment-Guide I've been talking to someone about a square setup of 18x9.5 ET 35 with 5mm spacers on the front. Just wanted to know if anyone was running that? Are you talking about 18's only or the 19's as well? |
10-04-2018, 12:04 PM | #54 | |
3525
Rep 6,752
See photos: While it does fit and look stunning, we don't recommend running the 18" ARC-8 on the M2 for the reasons stated above. The M2 Competition will require 19" wheels, and our 19x9" ET28 should work with 3mm front spacers, but we have not tested this ourselves yet to confirm. --Dylan
10-05-2018, 02:24 AM | #55 | |
Rep 117
Ok cool. Thanks for clearing that up. What would be your suggestion then for a square 18" setup from your line for the M2? Or are you running the risk with any 18" wheel? Therefore stick to 19s? |
10-05-2018, 11:45 AM | #56 | |
3525
Rep 6,752
The only additional modification required is front camber plates, which you'll want to have anyway to save your tires if you plan to track the car. The ARC-8 is our only design with slightly reduced inner barrel clearance. All of our other 18" designs clear the brakes with plenty of room to spare. --Dylan
01-10-2019, 06:39 PM | #57 |
1427
Rep 2,650
We've been getting a lot of customers asking about M2C fitment, check out our new 19" SM-10 wheels on this customer car.
19x9" ET30 SM-10 square fitment over the new M2C 400mm brakes.
01-11-2019, 09:10 PM | #58 |
Rep 10
Would I be able to get 265/35 front and 295/35 rear without rubbing using the 30 et in the front and the 45 et in the rear?
01-12-2019, 03:41 PM | #59 |
Da Baus
283
Rep 259
What setups have been tried for an og M2 and 19" arc-8s? Would 19x10 work square and what would be the most aggressive staggered set up? Thanks!
Fabspeed/Wagner/ER/Eibach/UCP/RTD RA Evo X/WhalenTuned/AMS/ETS/UR/AEM/Swift/RRM/VIS/ID E46 330ci --> S54 M3 xplant vzv 3bananas (retired) |
01-16-2019, 08:01 PM | #60 | |
Rep 3,077
What happened to this setup you guys posted on IG?
Follow me on IG
02-22-2019, 04:53 PM | #61 | ||
3525
Rep 6,752
Front & Rear: 19x9.5" ET33
You can also run the following: Front: 19x9 ET28 - 245/35-19 Rear: 19x9.5" ET33 - 265/35-19 Quote:
SM-10 ONLY: Front: 19x9" ET30 Rear: 19x11" ET44
Front: 19x9.5" ET22 Rear: 19x11" ET44
SM-10, EC-7 or ARC-8: Front & Rear: 19x9.5" ET22
The car you posted above, features the following: Front: 19x9.5" ET22 EC-7 Wheels in Race Silver -2* camber Rear: 19x10" ET25 EC-7 Wheels in Race Silver KW Clubsport 3 Way Suspension Original BMW M2 Competition Tires I hope this helped! - Max
02-23-2019, 04:42 PM | #62 |
Rep 116
Hi Max Expert@ApexRaceParts
Will that 19x9.5 / 19x10 EC7 fitment accommodate winder tires than OEM sizes with R-Compound tires? Assuming -2 (or more) degrees negative camber |
02-25-2019, 11:45 AM | #63 | |
3525
Rep 6,752
The M2 chassis is quite limiting when compared to the other F8x chassis cars. - Max
03-05-2019, 04:24 PM | #64 |
Rep 88
New to the Bimmer world and picking up my 2017 M2 this Saturday. Looking for 18s and seems like Apex is the way to go. Is there an 18” setup that can be used without running spacers? Either square or staggered.
03-06-2019, 02:24 PM | #65 | |
3525
Rep 6,752
As a baseline, you can use the following: Front: 18x9" ET30 with 245/40-18 tires Rear: 18x10" ET33 with 275/35-18 tires - Available in EC-7 and SM-10 designs only. - This is a direct fit with no spacers or modifications required. We have many other options listed on our M2 fitment guide here: https://support.apexraceparts.com/hc...-Fitment-Guide Take a look and let me know if you have any questions! --Dylan
03-06-2019, 02:47 PM | #66 | |
Rep 538
