05-10-2021, 10:33 PM | #23 | |
Rep 753
Again, don't want to get into a C vs OG thing as we all know too well where those kinds of posts go |
05-11-2021, 11:35 AM | #24 | |
Rep 3,842
https://f87.bimmerpost.com/forums/sh....php?t=1529257 My original point was that someone shouldn't get repremanded for making a post about weighing his M2 just because it's a Competition. Afterall the thread title is about M2 in the general M2 section. It says nothing about "only OG cars." Last edited by AlpsRider; 05-11-2021 at 11:48 AM.. |
06-06-2021, 05:35 PM | #25 |
Rep 95
Curious, what scales did you end up getting? Tossing the idea around myself but there is a pretty wide range of price points out there.
Current: 2020 X3M, 2022 911 GT3
Past: 2020 M2 Competition,2018 X3 M40i,2017 X3,2016 VW ,Golf R,2015 BMW M3,2010 VW GTI,2008 911 GT3,2005 VW GTI,2002 VW GTI 337 |
06-07-2021, 09:58 PM | #26 | |
Rep 753
Longacre Accuset II Scale Kit https://www.amazon.com/dp/B007W37QXM...UTF8&psc=1 |
06-16-2021, 10:36 AM | #28 |
Rep 753
06-18-2021, 08:31 PM | #31 |
Rep 1,286
My M2C DCT came in at 3620 lbs with half tank of gas. Stock wheels, 275/295 tires, M Performance Coilovers.
06-25-2021, 02:18 AM | #32 |
Rep 753
Update: I have since installed KW Clubsport coilovers, an ER front mount intercooler, ER charge pipes, one size larger tires on the 437M wheels and a 60Ah AntuGravity battery. Everything, except the battery, added some weight. But the battery compensated for them and then some.
Weight with a full tank: 3370 Distribution: 53.5% front, 46.5% rear Weight with me in the driver seat: 3537 Distribution: 53.1% front, 46.9% rear The only other weight reduction mod I plan to do is a M Performamce hood, that I am hoping is good for around 30-35 lbs reduction. [IMG]https://media.fotki.com/2v2aQ28aMxu6LVA.jpg[/IMG] [IMG]https://media.fotki.com/2v2aQ28Zdxu6LVA.jpg[/IMG] [IMG]https://media.fotki.com/2v2aQ28b5xu6LVA.jpg[/IMG] With me in the driver seat [IMG]https://media.fotki.com/2v2aQ281rxu6LVA.jpg[/IMG] [IMG]https://media.fotki.com/2v2aQ28KNxu6LVA.jpg[/IMG] |
06-27-2021, 12:27 AM | #33 | |
Rep 1,074
Instagram: M2_Medusa
01-29-2023, 05:39 PM | #34 |
Rep 753
Finally got around to getting the hood painted and installed this morning. Covid and labor shortage, combined with huge backlog of work, put my hood on a lower priority with my body shop. But they finally got it done. Since the last weigh-in, I've removed the rear seat bottoms and now installed the BMW M Performance carbon hood.
I believe this is about the extent of basic bolt-off weight reduction. After this we are going into trade-off territory, followed by more permanent changes that are, at the very least, not easy to revert back to stock. Looks like the CF hood is good for about 32-34lbs. Weight of the car with a completely full tank of gas: 3330 lbs Here are some pictures, because pictures make everything more interesting |
01-29-2023, 07:33 PM | #35 |
M///modifyer
2489
Rep 1,295
Nice one. 1510kg ‘wet’ is a pretty good result for our tubby M2’s given its still very much a street car.
You could always go with the carbon front guards/fenders which would improve the f-r bias further but they are pricey. I agree youve probably reached the point of diminishing returns now. 👍
www.tarmacperformance.com
Best Modified BMW - BMW Nationals 2022 |
pal433.00 |
01-31-2023, 10:49 PM | #36 |
Rep 75
That's a nice setup, Long Acre makes some pretty good stuff. That setup for total weight is fine but if you want to do cross weights, or axle weights, you have to level all four scales relative to each other (I mean seriously close, within 0.2 degrees). Otherwise the total weight is the only truly accurate measurement.
If you want to corner balance the car, you're best bet would be to find a spot you would want to use continuously for corner weighting, mark the outlines of the scales, and level the scales to each other to create a level plane. Once you've done that, you can use that spot with the set amount shims to get accurate readings everything time. For those wondering how much of affect that could really have, I can take an otherwise perfectly balanced Spec Miata car and, just by turning the adjustable end link on the front sway bar with my fingers, take the car from 50% to 52% cross weight just with pre-load. Granted a Spec Miata is light (around 2400 lbs) but that is certainly a testament to the accuracy requirement of the level platform. |
02-01-2023, 12:00 AM | #37 | |
Rep 753
02-03-2023, 12:31 AM | #38 | |
Rep 75
The initial setup takes a while, but once you have the spots marked out it should be repeatable and consistent. Last but not least, to get a truly accurate reading you'll want to disconnect one sway bar link per axle so you don't have any torsional pre-load in the suspension. |
pal433.00 |
02-24-2023, 05:40 AM | #39 |
Rep 135
I am at 1487kg with half a tank of fuel.
That equals 3280kg's. Stock interiour -no electris seats for weight saving reasons during ordering- Apex wheels Mperformance suspension Custom exhaust Eventuri intakes CF hood Blue brakes Deadweight Industries 104Ah battery (this is alone -17kg/37lbs) On the planning to further reduce weight -Back seat delete -AP racing brakes -CF bucket sets -CF roof Car will end up with 1450kg's/ sub3200lbs easy to be honest and when we are there it will be time for a 911 GT3 LOL |
VicF87OG72.50 infinitekidM2C4206.50 |
02-25-2023, 03:47 PM | #40 | |
Rep 1,334
I don't know which scale is lying, yours or mine. |
chris7197334.00 |
03-13-2023, 05:17 PM | #41 |
Rep 135
03-14-2023, 02:12 PM | #42 |
Rep 570
I am at 3,371 (1/2 tank fuel) with some additions (chromoly steel roll bar, fire extinguisher, FMIC, etc.) and deletions (rear seats, factory front seats).
M4 GTS Euro Seats weigh approx 15 lbs each I’ll corner balance again and get an updated weight with fuel normalized |
AUSf222689.50 |
03-15-2023, 04:22 PM | #43 |
Rep 7,429
You guys should also mention transmission variant as well, because the 6MT is considerably lighter than the DCT.
03-23-2023, 11:24 PM | #44 | |
Rep 1,977
Drives: 2020 M2C HS & Ferrari Roma
2020 M2 Competition | Hockenheim Silver | 437M Wheels / 763M Wheels | RHD | 2NH Brakes OEM M2 CS Steering Wheel | MP Carbon Steering Wheel Trim | MP Pedals | MP Dash | MP Interior Kit OEM M2 CS Bonnet | M Performance Coilovers | MP Rear Spoiler | MP Rear Diffuser| Perl Carbon Front Lip | Remus Race Exhaust |
