05-05-2018, 09:45 PM | #111 |
Rep 141
They wouldn’t void the entire warranty only parts directly related or could be related to the modification installed. Flash tunes or piggyback Tunes are a grey area because technically a tune increases the horsepower which is now putting stresses on the differential it was never designed to see such as the op’s case.
05-05-2018, 10:34 PM | #112 |
Rep 1,608
Huh? I doubt much can go wrong with the mirrors, unless something were to happen to the control of the folding or adjustment mechanism, and then, if the car is flashed, theyd likely pull it ... Youre going to tell them you know for a fact that the software you installed had nothing to do with those electronics? Have you seen the code? Good luck. When customers hack into the proprietary software from BMW, you'd better believe they dont look kindly on it..If they can draw any Possible connection to any part, they will.. Since the ecus control the workings of most of the key components, tuning can be treated very differently than replacing part of an exhaust system. Have fun taking them to court..
Boostm3
05-06-2018, 12:16 AM | #113 | |
Rep 6,638
05-06-2018, 08:20 AM | #114 |
Rep 1,608
I'm not really sure whether the dealer was referring to coding or to a tune.. However, I dont see a large difference from BMW perspective, since both either alter or replace proprietary software that lies at the very heart of the operation of the vehicle. When you code, youre usually using unauthorized third party equipment. BMW has no idea what that code comprises, nor is it their business to know. All they know is the electronic heart of the vehicle has been altered. Which specific systems were actually altered, or what impact it had, is really beside the point. Same for tuning.
Im not condemning these endeavors, as in the past, Ive been a big player in that game.. All Im saying is messing with modern vehicle software is a risky business.. Go ahead and engage, if you want, but be prepared there may be consequences.
Boostm3
05-06-2018, 08:59 AM | #115 | |
Rep 6,638
So maybe BMW could say if you coded mirroring folding on lock and have problems with other things related to that module it's because of "coding". Maybe they could stretch a bit and say random other unrelated module electrical problems are from coding. However they couldn't ever say it was the reason your engine threw a rod, why your transmission is leaking, or why your differential is making noise. They would have to prove it, and they wouldn't be able to. If they could people would be using esys and bimmercode to tune their engine! |
M3 Adjuster7909.00 |
05-06-2018, 09:08 AM | #116 | |
Rep 1,608
You're asking them to vouch for the fact that the product(s) you used to hack your software was bug free and did what it was supposed to do, with no side effects. Its not up to them to debug the tools you used. How many times have we read in these pages posts stating that after I coded X, Y no longer works. Is it BMW's job to debug this? Hacking the electronic brain(s) of your car is far different than putting on black kidney grills from BMW's perspective. Im not saying every dealer would take this austere approach, but those that do Im sure would tell you theyre well within their rights to withdraw warranty coverage on part if not all of the vehicle. Clearly, because a tune affects more of the vehicle's integral components, it could present an even larger potential problem.
Boostm3
'18 LBB MT M2 Exec pkg, Moonroof, Production 7/6/17 Last edited by boostm3; 05-06-2018 at 09:22 AM.. |
05-06-2018, 09:51 AM | #117 | |
Disrupter
1566
Rep 2,484
People who are writing their own coding and introducing it by flash into BMW's modules probably have something to worry about, at least if they screw up. The programs that merely access hidden menus that are already present, such as Carly and Bimmercode, and change the check marks, are simply enabling things that BMW has already coded for, and which in many cases are either accessible to the owner through iDrive, by asking the dealer, or the cars are sold with different boxes checked in different countries or regions of the world. The above having been said, if you go about coding a whole bunch of things on your car you are taking a minute chance every time that you will fry a module. In that case, you have likely bought yourself a module, and maybe you will get lucky and succeed in getting Bimmercode or Carly to pay for it, but I wouldn't count on that. I would suggest that if you are going to code things in your car using one of these mainstream apps, that you should probably limit yourself to things that are absolutely important to you. In my case, that was the ASD (turning it off) and duration of the seat belt chime. I can live with the rest of the stuff and even though I could spend hours fine-tuning every aspect of my car's behavior, I think that is taking a chance and asking for trouble. The former owner of my 1M (in Canada) unbeknownst to me put a Lojack device into the car. The car had a battery drain and basically needed to be plugged into a float charger all the time or the battery would go dead, which it did at least once. When I took it into the dealer, the tech ultimately found the Lojack device, and it took a lot of time and effort to find and remove it. In the end I paid for this, and also for a new battery, since none of this was the fault of BMW even though the car was still under warranty. I guess if they hated me at the dealership that maybe the car would have been black-listed, but they don't so this was the only complication I faced and the rest of the warranty remained in place for the duration remaining.
Disappointing People for Two Centuries; 3 Pedal Fanatic
05-06-2018, 10:08 AM | #118 |
Rep 45
The reviews on Yelp and Dealerater.com are mixed on the place you bought your vehicle from. However on some of the reviews, employees of this place seem to want to fix the customers problems, but we are not talking about a bad burger. A 7k differential replacement is a whole other ball of wax. I’m pretty sure they are going to dig their heels in on this one.
I would give your dealership, “in writing” a chance to remedy the problem. Be clear what you want, keep it simple and short, don’t get angry in your correspondence. If that doesn’t work within a reasonable time period, let them know you will be contacting a DMV investigator, not just the over the counter person that we are all accustomed to. California DMV has a special investigative unit, they have guns and badges and deal specifically with dealerships such as the one you bought your car from. Then... if that doesn’t remedy the problem, you can take your case to small claims court. The max recovery amount is up to 7.5 k. You have to play the long game here. That means, corresponding via registered snail mail. No phone calls. Document everything and then be prepared to back up everything you claim. Good luck. Last edited by Ktmdriver; 05-06-2018 at 10:23 AM.. |
05-07-2018, 02:49 AM | #120 | |
7909
Rep 11,785
Agree with you. Of course BMW just dropped an S55 in and I bet they aren't changing the diff so i bet it's good for 410 hp... |
dmboone254972.00 |
05-07-2018, 02:51 AM | #121 | ||
7909
Rep 11,785
05-07-2018, 07:20 AM | #122 |
Rep 1,608
Keep dreaming. I mean, yeah, if you replaced your kidney grills with IND stuff or your brake pads with Powerstops and your exhaust blows a weld or something of that ilk, sure, Magnusson Moss to the rescue, if need be. However, the very act of hacking or replacing BMW proprietary software which affects hundreds of parts, parameters, and components with third party tunes may void warranties on those components. How is BMW supposed to know that the software you installed wasnt all kinds of buggy and didnt affect components outside the drivetrain? It's not up to BMW to deconstruct that third party software; easier for them to just void warranties on any component that could conceivably be affected by ecu hacks. It will wind up being up to you to prove what you hacked DIDNT harm those components should something go awry. Just the way things work.. Very few folks are going to want to take BMW to court over this.. Live in the real world!
Ok.. rant over.. the fact is, some dealerships will overlook these things. Others will get the VIN 'flagged' as happened to the OP's car. If a serious problem with a drivetrain component crops up which usually will require a BMW regional rep to examine, in many cases, youll simply be SOL. We've had ex SAs on here confirming pretty much the same thing. You take this risk when you tune your car under warranty. Either wait til warranty is up or take your chances with a friendly dealer.
Boostm3
'18 LBB MT M2 Exec pkg, Moonroof, Production 7/6/17 Last edited by boostm3; 05-07-2018 at 12:45 PM.. |
05-07-2018, 10:23 AM | #123 |
Chief Warrant Officer
1025
Rep 1,638
I consider myself very lucky to have a mod-friendly dealer. That said, while under warranty (including CPO), I kept my 135 to things done by that dealer, like my Dinan tune.
So when, for instance, at about 60k Miles My manual transmission crapped out, they covered it without batting an eye. I've also heard of people going there with DPs with no problem.
"Prius" is Latin for Eunuch.
"Hrothgar": 2012 135i: 6MT M-Sport, BSM/Blk; Nav, Premium, Convenience, HK Dinan Stage 2 +PPK /// BMW PE /// VRSF CP /// K&N /// Koni Sports /// RSFB Inserts /// MPS4S 225/255 /// Other Stuff |
05-07-2018, 12:12 PM | #124 |
Rep 2,104
It seems like most of these types of threads eventually uncover that the OP was doing something a little less than straightforward, or has not been upfront with the forum when asking for help/advice. Have we gotten to that point yet? I only mention this because there appear to be some parts of the story that don't quite add up*...
*disclaimer: I only read the first and last page of this thread. |
05-07-2018, 04:23 PM | #125 | |
Rep 6,638
I don't believe any software is really installed or "hacked" by the "coding" all it's doing changing settings that already exist because they were developed and shipped on the car by BMW but didn't add those settings to iDrive. |
Poochie9107.50 M3 Adjuster7909.00 |
05-07-2018, 04:26 PM | #126 | |
Rep 6,638
AndrewC198910949.00 McGary911480.50 |
05-07-2018, 06:05 PM | #128 | |
Rep 1,608
As for tuning, I think logically, they have a stronger case to disallow.
Boostm3
05-08-2018, 12:31 AM | #129 | ||
7909
Rep 11,785
Coding a vehicle is making manipulations withinBMW's own software. It's akin to changing dip switches on an old school garage remote or accessing the service menu on a television to calibrate the television for better picture quality. You can't " code" a car to do something that isn't a permitted BMW item. BMW has set defaults for items and coding is simply adjusting a toggle to a list of already available alternatives to the default. A BMW Genius in my area codes cars as a side job. |
05-08-2018, 01:12 AM | #130 | ||
Rep 6,638
05-08-2018, 08:33 AM | #131 | |
Rep 1,608
Boostm3
05-08-2018, 11:19 AM | #132 |
The deuce gets loose
290
Rep 499
All I know is that if BMW flagged it in their system, something was suspect to begin with. i would also check why the car was in there to begin with. OP, send me a PM with your last 7 VIN and I will have my friend at BMW check the history if you would like.
