2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics Suspension | Chassis | Brakes Squeaky brakes at very low speeds
      04-22-2014, 06:32 PM   #1
modeboy
Drives: 2020 M2 Comp / HS / DCT
Hey guys, something that's been bugging me since I got the new car.. (235)... and I usually only notice this at a drive through where you're moving very slowly and then stopping again (such as in a line of cars) - the brakes squeak. I've had the car about a month and there's 1200 miles on it. I never hear this at higher speeds or with harder braking.. Just soft braking during slow start/stops. Is this normal?
JB
2020 M2 Comp. / Hockenheim Silver / DCT / Executive / Moonroof
      04-22-2014, 06:37 PM   #2
Killramos
Killramos's Avatar
312
Drives: '19 M2 '21 X5
I had it. It passed.
Just a factor of high performance brakes. Any car that I have had with good brakes did it. M6. Cls550. If you want it to go away fast do a 60-0 run : P
      04-22-2014, 07:41 PM   #3
modeboy
So a few hard braking sessions will get rid of it?
      04-22-2014, 08:39 PM   #4
JustinCredibleM
Drives: '15 GT-R, '02 996TT
I had the same problem as well.
Just bed in the brakes a bit by doing some aggressive 80-20 stops.
      04-22-2014, 11:26 PM   #5
modeboy
Thanks guys, I'll give it a whirl.
JB
      04-23-2014, 04:40 AM   #6
aacabriolet
aacabriolet's Avatar
Drives: '14 435i Coupe
Same thing on my 435i.... Quite embarrassing! Dealer said to bring it in, but I'm always wary of taking it in for niggles like this as they usually end up breaking more than fixing.
      04-23-2014, 07:37 AM   #7
five3three
Drives: m2c
It's a bmw. Brake squeaks will haunt you in your sleep. I took my e90 in so many times during the warranty and they kept replacing all parts until it stopped. Then get another set of brakes later on and squeaking returns. At a certain point you will just give up! The stock brakes suck.
      04-23-2014, 08:52 AM   #8
darkerosxx
Drives: '14 M235i
I reported this at ~1700 miles to my local bmw service and they said it's just a product of the humid air in the south. Huh? Crazy, but I've gone through a couple hard breaking sessions and it's less apparent now, although it does still happen.
      04-23-2014, 09:55 AM   #9
bman6074
Drives: 14 M235i and 07 Lotus Exige S
that's funny cause i get this on my 135i and i'm in the north. I believe its the rears that are squeaking on my car. If i do some hard braking like a bedding process it goes away. But the next morning its back.
This happens with race pads on my other car. But I don't think the M235i or 135i comes with race pads.
Maybe pull the pads put some quiet gel on them to help silent the low speed squeaks.
      04-23-2014, 11:42 AM   #10
modeboy
This is my 3rd bmw (2002 330ci, 2012 135i), and I never had this issue before. I'll try the bedding process...
JB
      04-26-2014, 05:23 PM   #11
Oyinko
Drives: M235i
I have some noise with the brakes too. It's not a squeaking but rather one short clonk when I press gently the pedal brake. It happens mostly when I'm maneuvering to park. I think the noise is coming when the brake pads clamp the front rotors. Do you have this noise too?
      04-26-2014, 08:58 PM   #12
kerm1t
Drives: 17 M3 ZCP Stage 2
anyone having brake clunks?
      04-28-2014, 06:21 PM   #13
modeboy
No clunking here...
JB
      04-28-2014, 06:27 PM   #14
ska///235i
***** noob
ska///235i's Avatar
Drives: 325xi>M235i>428GCx Mspor
2006 325xi  [0.00]
The 235 front and back are both fix caliper right?? That means no sliding pins (they always squeak if not greased)....hmmm has to be improper bed-in/break-in of the pads. You dont have enough pad material on the rotor so it squeaks at low speeds
2006 325xi (Sold)
2014 M235I (Current)
2015 428xi Gran Coupe (STB)
      05-02-2014, 01:40 PM   #15
tccox
tccox's Avatar
Drives: 2014 228i Msport
Same here with my 228
A peasant and proud of it
Save The Manuals!!!
      05-02-2014, 08:59 PM   #16
pikcachu
pikcachu's Avatar
1403
Drives: M235i (F22 Red angel)
drive faster
      05-03-2014, 02:42 PM   #17
leesat
samuray
Drives: M235i
2014 M235i  [0.00]
im having a clunk when i brake during reverse.
      05-21-2014, 11:19 PM   #18
P454905
Drives: l
Man I thought I was going crazy! This thread restored my sanity.
      05-22-2014, 12:33 PM   #19
modeboy
Mine seems to have subsided... I didn't do anything special to bed the brakes.
JB
      05-22-2014, 03:31 PM   #20
Oyinko
Drives: M235i
I asked my dealership to check it and they told me it's normal.
      11-18-2014, 04:22 PM   #21
tccox
tccox's Avatar
And my Msport 228 just started doing this at 5600 miles. Seems to be cold weather related. Driving me crazy
Save The Manuals!!!
      11-19-2014, 07:50 AM   #22
tccox
tccox's Avatar
Going to carry it to dealer next week. $40,000 car should'nt be waking up my neighbors when I go to work at 5:30am
Save The Manuals!!!
2addicts
