2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics Suspension | Chassis | Brakes Brakes - discoloration
      04-13-2014, 11:53 AM   #1
GFK007
Drives: 2014 m235i
Guys:
Is this supposed to happen??
MG on CR M235i, mods to come...
(gone but not forgotten) 2011 e90 M Sport - M-Tech Carbon Diffuser, OEM Carbon Trunk Spoiler, 20% tint, black reflectors, black OEM grille, LUX white Angel Eyes.
      04-13-2014, 12:30 PM   #2
JustChris
General
JustChris's Avatar
Drives: Tesla MYRWD
i see that a bit after cleaning but it burns off pretty quick, not sure theres as much as that. Was this right after a clean?
My car made front page of Bimmerpost
      04-13-2014, 12:36 PM   #3
ska///235i
***** noob
ska///235i's Avatar
Drives: 325xi>M235i>428GCx Mspor
2006 325xi  [0.00]
All brakes do that when theres moisture over time
2006 325xi (Sold)
2014 M235I (Current)
2015 428xi Gran Coupe (STB)
      04-13-2014, 12:42 PM   #4
Cripple
Cripple's Avatar
102
Drives: 12' 335is
Specifically on the East coast were it's humid and near the sea. Oxidization occurs when moisture meets steel.
14' M235I | BMW Performance Exhaust | BMW Performance Diffuser | BMW Performance Carbon Interior | ER DP |
JB4 S2 | BC Forged HB29's | N54Tuning.com | getBMWparts.com
Current: 2015 Cayman S on HRE P101
      04-13-2014, 12:44 PM   #5
BEM-S4
BEM-S4's Avatar
Is the paint chipping on your calipers already or is that just a reflection on the photos?
      04-13-2014, 12:56 PM   #6
Jockey
Jockey's Avatar
3451
Drives: 992 C4S
You never noticed this after washing your car?
It's completely natural.
      04-13-2014, 01:01 PM   #7
M2BMW
Drives:
Try this:
http://hydes-serum.com/products/
      04-13-2014, 01:09 PM   #8
ska///235i
***** noob
ska///235i's Avatar
2006 325xi  [0.00]
Wait, is OP talking bout the caliper??
2006 325xi (Sold)
      04-13-2014, 01:16 PM   #9
GFK007
Drives: 2014 m235i
That was just a reflection on the caliper.
I've noticed this kind of discoloration on previous cars just not to this extent. Sounds like it's normal though.
      04-13-2014, 01:46 PM   #10
///cpt
///cpt's Avatar
Drives: '14 M235i BSM/CR
totally normal, no worries.
      04-13-2014, 01:48 PM   #11
BEM-S4
BEM-S4's Avatar
Thanks, was worried for a second. I have had this on every car I have ever owned. Annoying and ugly but no cause for concern.
      04-13-2014, 04:42 PM   #12
flyga3
Geboren zu Fahren!
flyga3's Avatar
Drives: F25 X3
Yup, typical iron oxidation of the rotors. No worries.
2011 F25 X3 2.8 (in service)
2009 E90 328i (retired)
2007 E92 335i (retired)
2005 R53 MINI Cooper S (retired)
2002 E53 X5 3.0 (retired), 1999 E46 328i (retired)
      04-13-2014, 06:29 PM   #13
DanG
DanG's Avatar
Drives: 2018 M2 AW DCT
2018 BMW M2  [7.68]
After a nice drive the brake pads will scrap off all the oxidation.
      04-13-2014, 08:12 PM   #14
RPM90
Drives: 340i M-sport AT
If it cleans up after you drive it, then it's normal.
If it doesn't, then take it to the dealer.
But, yes, a layer of rust can and does form if the rotor got wet while not driving.
      04-13-2014, 10:13 PM   #15
Aust350z
Aust350z's Avatar
243
Drives: F87 M2
This...
plus this...
</thread>
      04-14-2014, 03:40 PM   #16
Dr. Indiana Jones
Dr. Indiana Jones's Avatar
57
Drives: BMW M240i
I agree w everything above that has been said. It is completely normal after a wash for the rotors to rust a bit; nothing to worry about and a short drive and application of the brakes will take care of the problem. Yes it's a pain, but not a problem.
A more serious problem w BMWs is that eventually the brake rotor's central hub will rust out, and there's nothing u can do to stop this. Makes an expensive car look a bit cheaper. My 335i's rear rotor hubs rusted out within 1.5 to 2 years.
An even more serious problem - and regrettably I've had this rare one too - is when the car sits in rain for a week or two w/o being driven, and the rotors develop a marginal (and I mean so marginal u can't see or feel it) warp to them. The rotors will actually squeak when the car is driven w/o applying the brakes, as the rotors rub up against the brake pads. Although the dealer will recommend replacement, in time (a few short months) usually the rotors will grind back into perfect shape in most instances (at least they did for me).
Above all else never trust your brake wear gauge or the dealer to decide when the brakes need replacing. The gauge often gets miscalibrated (and will need a software reset), and the dealer will want to replace brakes even when there's lots of wear (say 25%) left on them. My gauge worked well for the front brakes but overestimated the wear for the rear brakes (and needed to be recalibrated during a routine service). I laugh because the dealer's first inclination was that the brakes needed replacing, when all that was required was a gauge reset.
      04-14-2014, 03:44 PM   #17
darkerosxx
Drives: '14 M235i
Just fyi, the manual actually says if the brakes get wet to take them out and use them for a bit to dry them out before letting the car sit to get rid of specifically this.
      04-17-2014, 11:55 AM   #18
bitcore
bitcore's Avatar
107
Drives: F87 BSM Manual M2 Comp
It's not even really a gauge, it's a calculated value based on a number of figures. Only the "Your brakes are shot" light means you need to replace your pads because the wear sensor wire was worn through - triggering the light. (at that point check for rotor run-out as well)
2addicts
