BMW 3-Series (E90 E92) Forum
Beyond confused...
01-10-2014, 11:58 PM | #1 |
Rep 69
Beyond confused...
Can someone point me in the right direction? I'd love to get into detailing. I'm trying to compile a list of things I will need to get started and so far I think I have a good idea. Before I jump in and get to work though, I would at least like to know what the hell I'm using. Compounds, polishes, glazes, sealants, waxes, etc. I have no clue what the difference is in all of those and which ones I will need. Can anybody give me a quick breakdown of what exactly those things are and why I need them? Or can you provide a link so I can do some reading?
01-11-2014, 12:02 AM | #2 |
Rep 4,221
SLC Goonski
14 F31 MSport Wagon 08 335i e90...sold |
01-11-2014, 04:42 AM | #3 |
Rep 17
Washing:
- Two five gallon buckets, doesn't matter where they come from, one will be filled with clean water for rinsing your wash mitt, the other will have your wash mix. - Grit Guard, placed in your rinse bucket: http://www.detailedimage.com/Grit-Gu...t-P119/RED-S2/ - Gilmour Foamaster gun (If you do not have a pressure washer), put some wash mix in it to give your car a nice foaming pre-wash: http://www.detailedimage.com/Gilmour...allon-Tank-S1/ (There are different versions of this gun, they all work the same and can be had much cheaper through Amazon) - If you do have a pressure washer: http://www.detailedimage.com/DI-Acce...am-Lance-P770/ - Invest in a good wash mitt, again nothing special needed, just make sure it is soft, can hold a decent amount of suds and does not have an exposed stitching or tags that could scratch your paint while you wash. - If you have hard water, you may want to invest in a water softening system, this one has a rechargeable cartridge by soaking it in salts you can get at any hardware store: http://veloximo.com/shop/index.php?r...&product_id=86 Drying: - Use an electric leaf blower, the less touching you have to do, the less scratched and swirled your paint will come out. You could invest in a fancy Metrovac Master Blaster if you had money to burn. - Any remaining water spots, wipe clear with a good quality microfiber towel, again, no exposed stitching or tags, Zaino Borderless Blondes are a favorite of mine: http://www.zainostore.com/Merchant2/..._Code=Z-BBFT-3 Claying: - Buy only Simoniz/Body Magic Clay Magic clay bars. It is the cheapest clay bar you will ever buy and it's the same clay bar you get whether you buy it for a few dollars in their package or $20+ in a Meguiars or Mothers or (Insert boutique detailing website's name here) package. They own the patent on detailing clay and take great pleasure in taking other companies to court for patent infringement when someone releases a clay bar that they did not source from Simoniz/Body Magic. Polisher: - Get a good DA polisher, personally I use a Meguiar's G110 V2 DA. There are two other good ones, Porter Cable 7424XP and Griott's Garage does their own. The Meguiar's is very easy to use for a beginner, doesn't bog down. Pads: - Pads can be very confusing to a beginner, you have finishing pads (To apply sealant or wax, these pads are the softest, usually have no cutting power), polishing pads (With varying levels of cut, run your fingers over the surface and you can feel the difference), compounding pads (With even more cutting power than polishing pads). I recommend Lake Country and Chemical Guys Hexlogic pads. Compounds/Polishes/Sealants/Waxes: - When it comes to compounds and polishes, most are paired, and for the best results, it is wise to not switch brands between a compound and polish, unless through experience you have found it works for you. For me, I use pair Meguiar's M205 and M105 together for compounding and polishing. They both utilize the SMAT (Super-Micro Abrasive Technology) that made their Ultimate Compound and Ultimate Polish famous with retail clients. M205 and M105 are from Meguiar's professional end of the business. - Sealants for the most part are wax that lasts much longer than traditional wax, some may have some fillers or polishing agents. For the past few years I've used Chemical Guys Blacklight, a great sealant for black or dark colored cars. - Wax is wax, wax does not shine nor does it add depth, don't spend much money on wax. Just find one that goes on easy and comes off easy for you. To see if the wax is ready to be buffed off, take a clean finger and swipe the panel, if the area you swiped is clear and not streaky, then your wax had cured and is ready for buffing. The most important piece of advice I can give you is technique trumps product every time. Below is a link to the best YouTube series to teach technique in everything car detailing: http://www.youtube.com/user/Junkman2000/videos |
01-11-2014, 05:18 AM | #4 | |
Rep 69
01-11-2014, 07:29 AM | #5 | |
Rep 17
Every time you compound and polish you remove a microscopic layer of clear, so you want to minimize every time you do this, plus it's a lot of time and sweat to invest. Always take the least aggressive method possible, for example, say you have some swirl marks, don't go straight to compound and your heaviest cutting pad. Instead start with polish and a light cutting pad, work a 2x2 area and see if that took care of it. Only then go to compound if it did not. As you gain experience you will be able to judge paint and what correction steps are needed. |
01-11-2014, 07:41 AM | #6 |
Rep 17
Yes. Sealants and waxes serve the same function, protecting all that hard work you put into paint correction. Sealants usually have polymers and silicone in it which allow it to "bond" to the paint, giving it a longer service life.
Putting a wax on top of a sealant is often referred to as a "topper" it will help extend the life of the sealant. |
01-11-2014, 01:30 PM | #7 |
Rep 1,733
Drives: 2003 M3
This is a very good writeup that touches on everything.
http://www.detailedimage.com/Auto-Detailing-Guide/ |
01-11-2014, 11:50 PM | #8 |
Rep 69
I think I'm starting to get a better understanding of everything. The link the two guys posted above has A TON of good information. I was reading on there all night last night. I do have one last question though. Just to explain myself a little better I will give you an example. So last night after doing some reading about the Meguiar's M105/205, I went to their website just to see what else they have. All I saw was a bunch of numbers. Every description for each product was only a little different. How am I supposed to know what each one of those is? They have (just to name a few) the Microfiber Correction Compounds, M105, M205, and all of these other numbered products. I don't really understand how to tell the difference. Also, the M105 and M205 that I see everyone talking about is labeled as Mirror Glaze on their website. After reading about glazes and compounds and all of that, a glaze isn't really what I'm looking for. I guess what I'm trying to ask is, how do you know what each product is used for? Here is the link for the website. Maybe if you see the selection of products you will understand my question better. http://www.meguiars.com/en/professional/products/
01-12-2014, 01:53 AM | #9 |
Rep 547
Here are some info straight from the horses mouth. Keep in mind that these products were originally designed for the pros so there will be some learning curves on all of them. I, personally, have not use M105 in over a year. There are products that are much more user friendly than M105 in the market place. I am still a big fan of M101 and D300. Menzerna FG400 is also pretty awesome.
Meguiar's M105, M101 and M100 Compounds Round Table Discussion Meguiars Microfiber DA Correction System Meguiar's DA Microfiber Correction System Part II - Enhancement
What is absolute control???? Having the means and the abilities to exercise it at will but....chooses not to.
01-12-2014, 07:52 AM | #10 | |
Rep 69
01-12-2014, 09:29 AM | #11 |
Rep 547
If you are looking for a "Formula".....then you will have a hard time finding an answer. Unfortunately, a formulated approach generally doesn't work due to the variables being way too numerous (such as pad combinations, technique, the paint system of the vehicle, paint thickness (CC), etc).
Before I start to work on any vehicle, I always do a test spot to determine the process that I will be using. The following is a polish aggressiveness chart that would give you an idea on how these polishes rank on a scale of 1 to 10. The only way you will know how a product will perform for you is to work with it. Like I stated earlier, there are other factors that would affect aggressiveness. The pads combinations, work area size, and technique will all play a role. Paint corrections is both an art and a science. This is the "ART" part. http://lib.store.yahoo.net/lib/autopia/polish-chart.pdf
01-12-2014, 11:10 AM | #12 |
Rep 1,509
Compound-Heavy cutting for deep defect removal, hard clear coats, and cuts faster. It's not always necessary.
Polish-Light to medium cut depending on which one you are using. Polish adds the gloss and removes the haze from compounding or it can be used by itself (one step correction) for removing light to medium swirling. Glazes- Fill in swirls and hides a majority of them. When the glaze wears off, the swirls will show more again. Wax- Used to protect the car from the elements. It makes cleaning bugs and dirt off easier. It's generally around 5-10% of the look. The rest of the look comes from the compounding/polishing step. It also looks the best compared to sealants. Sealants- Basically the same idea as wax, but it will last much longer. It doesn't look as good but it is slicker.
2009 E90 328i Monaco Blue
premium/idrive/convience/logic-7/cold weather/ xenons/ saddle brown interior |
01-12-2014, 03:24 PM | #13 | |
SuperFastYo
50
Rep 790
For wax though I recommend a polymer sealant instead. Last 10x longer, looks better, but is more expensive.
C63 AMG - LSD - Straight Pipe - EuroCharge v5 - Vossen CV7 - |
01-12-2014, 10:59 PM | #14 | |
Rep 69
01-12-2014, 11:18 PM | #15 | |
Rep 547
01-13-2014, 01:10 AM | #16 |
Rep 69
Thanks again for all of the help. I think I've got enough information to get started and hopefully not screw up my car lol. Appreciate everyone's input!
01-13-2014, 03:37 AM | #17 | |
Rep 17
01-13-2014, 04:48 AM | #18 | |
Rep 69
01-13-2014, 01:40 PM | #19 | |
Rep 790
sealants are synthetic, and they can look just as good was wax. but mainly you will need a higher quality sealant to match the look. you always can let a sealant cure for 12-24hrs and top with 1-2 coats of wax. something that was left out would be swirl removers....which you could consider light compounds or powerful polishes. Most true compounds will remove quite a bit of clear so you really dont want to use them unless you have to.
2010 335i M sport
2008 328i 2006 325i 1995 Z28 6spd - 377rwhp rip |
01-13-2014, 05:06 PM | #20 | |
Rep 1,509
01-15-2014, 05:19 PM | #21 |
Rep 4,444
Watch out for products with "filler" properties, what that does is it hides the "light" scratches (in general,) so after a couple of washes where it "filler" comes off, you'll see the swirls again. Assuming you detailed it properly, and the washes after that properly as well. haha
So, if you're worried about that. Before you do the final step, do an alcohol wipe down (diluted), and bring it out into the sun or use a strong light to check your work before you put a wax/sealant. (Sometimes wax/sealant can hide the scratches too.) |
