BMW 3-Series (E90 E92) Forum
Question about Battery in 335
12-20-2013, 05:35 AM | #1 |
Rep 150
So, I know this is a subject that has been beaten to death, but I have a slightly different twist on it.
After replacing the battery, there is a heated discussion about whether or not it needs to be registered to adapt the charge properly. So my question, given that the computer determines the state of the battery through the IBS (Intelligent Battery Sensor), what happens if you just unplug the sensor? I'm pretty sure it throws a silent error, but without the sensor, how does it charge the battery? |
12-20-2013, 09:42 AM | #3 |
Rep 221
Dude... registering your batter takes literally 10 minutes and ANYONE with the equipment for coding (mirrors, iDrive, keyfob, etc) can do it for you. check craigslist or kijiji.
You have to register your battery or else you could just kill you battery in less than a year or even short things. get it registered... and if you cant find someone independant, BMW charges $50 for it. |
12-20-2013, 12:24 PM | #5 | |
Rep 150
12-20-2013, 01:05 PM | #6 | |
Rep 221
If you can somehow prove that, I would absolutely go FULL kamakazie on them.... no remorse. |
12-20-2013, 01:30 PM | #7 |
Rep 122
I replaced my battery (with registration) last year. This year, my alternator went bad and was putting upwards to 18V. Had the alternator replaced and a few months later the battery went. This was most likely caused by the bad alternator. I replaced the battery and registered it. The car still cranks slower then I believe it should and I'm also curious what would happen if I were to disconnect the IBS. I don't see any benefit to having this part designed into the car and if there is a way to bypass it I would be thrilled!
12-21-2013, 08:11 PM | #8 |
Rep 2,202
The car would appear to work as normal. Only there will be no battery monitoring by the IBS that is all. In the event by some miraculous way however; if there is a short to the battery/car, the car will not know to cut power from the distribution block. Ie fire, electronics failure etc etc..
Retrofits: 322, 609, 6FL, 6NR, 6VC, 2TB..
Upgrades: Bilstein B8 Eibach Spring kit |
12-21-2013, 10:11 PM | #9 | |
Rep 48
12-21-2013, 10:37 PM | #10 | ||
Rep 2,202
12-22-2013, 08:52 AM | #11 |
Thats all you need to know.
43
Rep 1,188
Car will default to a pre determined routine, same procedure as if any sensor failed.
- M2 2018 LBB / Black
- X5 F15 2016 Mineral White / Black 1981 Delorean number 6489 |
12-24-2013, 05:16 PM | #12 | |
Rep 48
Bus systems can be no fun to Diag! |
12-24-2013, 06:42 PM | #13 |
Rep 2,202
12-25-2013, 12:59 AM | #14 | |
Rep 3,696
We all have the transport cable disconnected since we r actively using the car after original delivery. |
02-10-2014, 06:10 AM | #15 | |
Rep 150
02-10-2014, 11:26 PM | #16 |
Rep 3,696
My IBS cable *i think* is under that battery hold down, you can see that blue connector if u zoom in. However, i have another connector that is just dangling as well (forgot what color it is) but its a transport cable and should not be connected.
02-10-2014, 11:51 PM | #17 |
Rep 447
