BMW 3-Series (E90 E92) Forum
Gas station car wash
12-11-2005, 12:07 AM | #1 |
Rep 8,091
During the winter months do you think it will be ok on the Zaino wax on my car to take it though the touchless car washes?
Thanks! |
12-11-2005, 09:20 AM | #2 |
418
Rep 12,276
Even if it ends up removing your wax (which will happen over time anyway) what choice do we really have? When it's too cold to hand wash the car we have to do something - and thank God for touchless washes. They don't get the car "clean" like a real wash, but at least they remove the grime and salt, etc.
The soaps are probably harsh, but a good pre-Winter wax will help and a thorough Spring cleaning and detailing...
I think it is bad luck to be superstitious |
12-11-2005, 11:45 PM | #3 |
Pirate
113
Rep 1,395
carwash detergents are made to clean off dirty cars. since the owner of the car wasg doesnt know what type of cars will be coming n he doesnt know how dirty u're call will be. so u're getting the same high ph soap everyone with nasty paint is getting.
if u own a garage, i would look into QEW from PROTECTALL. when used RIGHT, with 2 sheepskin mitts, two buckets, and 2 waffle weave towels, its u're best option... not spamming but if u want better info go to detailcity.com or autopia.org and do a search on them. the majority of them members there are using QEW as their wash regimen for these cold months and they have some of the nicest finishes u will see. |
12-12-2005, 11:19 AM | #4 | |
Rep 581
I personally go to the touchless wash at the gas station. Believe it or not the soap is not as harsh as you think. I have no scientific evidence to prove this though. All I have to do is look at my paint after I exit. There is always a very thin film of dirt left. If the soap was as strong as you think, it would get everything off. As a side note, don't dry your car after exiting the wash. You'll just end up rubbing the micorfilm of dirt around your paint and create swirls. Let it air dry. The water used at many washes is recycled, hence the water is soft (so no hard water spots to worry about). As for Zaino, it is durable stuff. You'd be surprised to see that it will last through a winter's worth of touchless washes. It has for me. |
12-13-2005, 03:15 PM | #5 |
Rep 266
I took mine to one of those touchless places today and there is some water spots now. Should I go out in this 35 degree weather and wash by hand? Or will be ok to wait til tomorrow to get rid of them? I have monaco blue.
12-13-2005, 03:27 PM | #6 |
Rep 581
It should be ok. The water spots should go away next time you wash. If you aare really paranoid, you can try QD'ing the spots. But try not to rub. Try blotting the spots instead in order to avoid swirls.
12-18-2005, 10:46 AM | #7 |
Rep 127
I have used touch free a few times until I managed to screw up the entry into the wash once. I drove in with our at the time few months old A4 ultra sport (18" rims) and badly scratched both left rims. You would think this won't happen to you but after examining the rails on the wash I found that there is not much room for error with a big rim. Of course instead of rubber they have to make the rails (on this particular wash) out of steel so if there is contact those will tear into the aluminum like warm knife into butter. If your tire height is normal or you drive a truck than you will be fine but with sport rims you better be perfectly alligned.
So just watch out... have someone help you in. I ended up getting compensated for 50% of my damage (each rim is around $900). It took me quite some time with Exxon to get at least that much back. Other than that, the touch free is OK especially for thick dirt, but the car won't ever be really clean and it leaves spots all over as well. I go for a hand wash if I have the time. |
12-18-2005, 09:51 PM | #8 | |
Pirate
113
Rep 1,395
like i said, its all about technique. which is why i gave links to detailing forums where they offer good instructions on how to safely use qew. qew uses a formulagtion of lubricants and cleaners to disolve and soften dirt, better than car wash soap which mainly focus on lubricants and soaps to LIFT dirt. they both do two different things but they end in the same result. a wise detailer once told me, u can have the best products in the world, but without knowledge or technique, u got nothing. |
12-19-2005, 09:26 AM | #9 | |
Rep 581
And yes, technique is important. But you can't remove swirls with pi$$, no matter how good your technique is. |
12-19-2005, 10:01 AM | #10 | |
Pirate
113
Rep 1,395
autopia really isnt my place of posting. im really only big on read here on e90 and dc. but i post autopia as some will find its larger population helpful. but i prefer to stick to the more calm detailcity. this isnt an excuse to forget about hose and bucket, but it is a solution when they are not available or not possible like in the colder climates. ive found that getting a sprayer and presoaking the paint prior to using qew really helps. collinite 845 is also very durable in the winter and states to be detergent safe so im sure that might also shield away the nasty chemicals in touchless washes... |
12-19-2005, 04:50 PM | #11 | |
guardian of ice and snow
67
Rep 424
Have u tried the new touchless ROLLOVER car washes?
There are no rails. You just simply park your car in the middle of the wash, the doors close, and the washing machines move around your car.
12-20-2005, 09:57 AM | #12 | |
Rep 581
Where else have you seen these washes located? Thanks. |
12-22-2005, 11:22 AM | #14 |
Rep 84
I give up!!
I tried washing my car today on the driveway using warm water from the hose and a mitt.
Water still froze on the car and the driveway is a mess. Used a whole bucket of deicer on the driveway and car still not really clean. The wife is going to kill me. I'm going to start using a touchless wash. Probably Canadian Tire I've got 7 coats of Zaino on it so hopefully it will last.
2006 330i, Alpine White, Black Dakota Leather/Aluminium Trim, Manual, SP, PP, Nav, PDC
01-02-2006, 09:08 PM | #15 |
Rep 740
Drives: e90 325i
i've been using touchless car wash a couple of times during winter. They are awesome and no "scratch" yet
e90 325i Jet Black / Sports Pkg / Auto
