BMW 3-Series (E90 E92) Forum
Is the N54 out of production?
08-02-2013, 09:01 PM | #1 |
Thats all you need to know.
43
Rep 1,188
So I was checking out the BMW site and it appears the N54 is finished. I did not check every possible build option so please don't fire up the flame thrower if I am wrong. The Z4 and 135is are showing N55 with power kit now. Near as I can tell the 335is has stopped production even if you can still built it online.
- M2 2018 LBB / Black
- X5 F15 2016 Mineral White / Black 1981 Delorean number 6489 |
08-03-2013, 02:34 AM | #4 |
Rep 4,732
Drives: Alpine White '13 550i
08-03-2013, 03:39 AM | #5 | |
Rep 1,407
Diligentia Vis Celeritas
08-03-2013, 06:15 AM | #6 |
Rep 243
Aww thats sad No more N54's, all done and dusted along with the whole E9x production RIP
2008 BMW 335i M-Sport Black Saph w/ Dakato Black | M-Sport | Sunroof | iDrive | 6SP Steptronic | Comfort Access | Lights Package | JDM Spec |
08-03-2013, 06:57 AM | #7 |
Rep 670
the B3 uses a N55 they put twins on, not a N54.
2010 335i e90 Le Mans Blue/Chestnut Brown | M-Sport | 6MT
08-03-2013, 07:05 AM | #8 | |
1706
Rep 14,829
The N54 was probably an engineer's doing, and it got past the bean counters and marketing. I still laugh that the list price on the exhaust is over 6k. True duals. On the N55 they managed to remove one turbo and 3 CATS, and the exhaust costs 1/2. yet the price of the car went up. WINNING! |
08-03-2013, 07:31 AM | #9 |
46
Rep 1,556
08-03-2013, 08:31 AM | #11 |
Rep 670
The B3 has valvetronic. Check the specs. You tell me which is easier to do- retrofit valvetronic to a n54, or switch out the exhaust manifold from a single for twins?
08-03-2013, 10:57 AM | #12 |
Rep 291
Interesting that the Z435is uses the N55 as well now...I see that the tech specs lists TwinScroll turbo and Valvetronic for it now...so I guess that would be the N55. So have they added overboost to the 'is' version of the N55 or does the Z4is not have the overboost any longer? If the Z4is no longer has the overboost then that would be a setback in the power department compared to the N54is cars.
08-03-2013, 11:12 AM | #13 | |
43
Rep 1,188
08-03-2013, 11:16 AM | #14 | ||
Rep 4,724
Current: 2021 M340i xDrive
Previous: '18 340i xDrive; '15 335 xDrive; '14 435i xDrive; '09 335 E92 xDrive |
08-03-2013, 12:25 PM | #15 |
46
Rep 1,556
You are most likely correct. If I remember right, the e92 based Alpina car (was it also called "B3"?) was definitely an N55 with twins fitted so that makes sense. Top Gear got it wrong.
08-03-2013, 12:27 PM | #16 | |
Rep 670
10-11-2013, 05:59 AM | #19 | |||
Rep 833
Proof #1 that the USA website is wrong The German BMW website. http://www.bmw.de/de/neufahrzeuge/z4...2/motoren.html Quote: "Das BMW TwinPower Turbo Triebwerk im BMW Z4 sDrive35i kombiniert zwei Turbolader mit Doppel-VANOS und Benzindirekteinspritzung." Proof #2 that the USA website is wrong The combined fuel consumption Z4 sDrive35i is 9.4l/100km (with MT) 135i convertible is 8.6l/100km (with MT) So the 135i convertible offers better mpg although it's 187lbs HEAVIER than the Z4 35i. This is because the 1-series uses the N55 which is simply more fuel efficient than the N54 used in the Z4. PS the USA website also states 17/24 mpg city/highway for the 35is with automatic. Compare this to the heavier 135is convertible with automatic: 18/25 mpg. Both use DCT I assume. If so, the only reason the heavier 1-series convertible gets better mpg is because it uses the newer N55 engine. BTW have the stopped production of the 335is convertible? |
10-11-2013, 06:07 AM | #20 |
Rep 833
10-11-2013, 08:49 AM | #21 | |
I have to return some video tapes
362
Rep 4,712
Which might make some people think n54
13 Carbon Black e70 X5M - 13 Black Sapphire e92 335i - 10 Le Mans Blue e92 335i - 09 Monaco Blue e92 328i xdrive - 07 Sparkling Graphite e92 328xi
10-11-2013, 09:17 AM | #22 |
43
Rep 1,188
I emailed BMW about the contradiction, it does appear the BMW USA website might be incorrect. If I have time today I will swing by my local dealer and look for myself so I can end my curiosity.
