F30POST
F30POST
2012-2015 BMW 3-Series and 4-Series Forum
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > M Performance Exhaust Impact on Performance
ARMA SPEED
      01-23-2013, 10:40 PM   #1
spideypm
Drives: 2013' 335i M Sport
Hello,
For those of you that had installed the M Performance exhaust, has anyone of you noticed a difference in performance of your car? Either enhanced it or hindered it? I was under the impression that this mod is only for audio effect but was told that it makes the lag more noticeable?
Tks!
      01-23-2013, 10:41 PM   #2
FotiosF90M5
///M Specialist South Shore BMW
FotiosF90M5's Avatar
Drives: 2021 M5 Comp BHG/Silverstone
If anything I thought the turbo was a bit more responsive. I love mine.
2021 M5 COMPETITION LCI Brands Hatch Gray on SIlverstone, carbon roof, comp wheels, Mperf splitter, carbon pro spoiler, carbon diffuser , carbon paddles, executive pkg. Dinan HAS, RaceChip, dinan spacers, FC stud kit, etc
      01-24-2013, 08:53 AM   #3
shivaswrath
shivaswrath's Avatar
Drives: 2012 335i
Nothing substantial...
CURRENT: 2017 RS3 (miss you guys)
SOLD: 2012 335i Mineral Gray
M Performance Exhaust/Brakes/Suspension/LSD|Bav Stage 1/AMP||ER CP/IC/DP/OC | Dinan CAI/N55 PWG BIG TURBO|BMWF30.com
      01-24-2013, 10:09 AM   #4
Tsuvoi
22
Drives: 2013 F30 328i
No and that's a lot of money for just some noise.
      01-24-2013, 07:50 PM   #5
Quackdiesel
Corleone
Drives: 2014 X5 35d M Sport
I was considering a mpe but not so much if it is just to improve the sound. My next problem is if I were to install an aftermarket exhaust would the increase in performance decrease my fuel economy? If so I would have to stick with the mpe. LOL
      01-25-2013, 12:46 AM   #6
buildbright
buildbright's Avatar
155
Drives: F80 M3 MG
Any performance part will decrease your fuel economy because you will be driving more aggressively. The performance exhaust is great but if it adds anything it will be like 5hp.
No performance exhaust will add much as ours is designed almost perfect. You want some good performance get a BMS JB and maybe a downpipe.
      01-25-2013, 10:30 AM   #7
sean10mm
sean10mm's Avatar
Drives: '13 335i xDrive 6MT ZDH
Turbos can benefit from a higher flow exhaust, but the main restriction is from the cat in the downpipe. You need a higher flow exhaust all the way from the turbo to see any substantive power gain, and you need a tune to really get the full advantage of it.
      01-25-2013, 10:39 AM   #8
shivaswrath
Drives: 2012 335i
The stock exhaust, outside of the EPA mandated cat's, is pretty nicely sized...there aren't too many kinks I've seen when getting down below, which is probably why most aftermarket exhausts that aren't axle-back's are netting 10 whp over the entire range...
if I were to do it, like sean10mm was saying, I'd focus on the DP - getting a 200 cell cat will give you a lot of gains WITH a strong tune.
I saw that on my Evo, turned up the boost with the stock DP, not too many gains...with a high flow cat, something like an additional 15 whp. That's CRAZY! (this is for a high boost evo, so probably not too comparable).
      01-25-2013, 11:25 AM   #9
Alpine F31
Alpine F31's Avatar
Drives: MB E350 4MATIC Estate
My M Performance exhaust is on the UPS truck for delivery today. I don't expect to feel any power difference but I hope it will be a little lighter and I know it will be audible, unlike my almost silent OE system. I really just want to hear my car, especially at the track. I have plenty of power for my skill level.
      01-25-2013, 04:39 PM   #10
rallybull
rallybull's Avatar
Drives: F30 335i w/PPK
Originally Posted by Alpine F31 View Post
My M Performance exhaust is on the UPS truck ..........
Damn... for a few milliseconds I thought you attached the M Performance exhaust to some UPS truck....
      01-25-2013, 04:58 PM   #11
buildbright
155
Drives: F80 M3 MG
You will really like it once it is broke in but its sounds the best full throttle. You will love it. its so easy to install.
      01-25-2013, 06:57 PM   #12
Alpine F31
Alpine F31's Avatar
Good to know! You installed yours yourself I presume? Did you have access to a lift?
I just opened the box, it's going on tomorrow!
      01-25-2013, 07:10 PM   #13
SergioK
Drives: F30 328i
Where'd ya get it from? Are floor jacks enough to get this exhaust installed?
      01-25-2013, 09:15 PM   #14
buildbright
155
Drives: F80 M3 MG
I didn't use a lift because it was such an easy install took me 15 to 20mins and most of that is jacking the car up or getting it on wheel ramps. The stock exhaust is dimpled exactly where you should cut it and everything.
Just get a chain pipe cutting tool. If you don't have one, rent one from a autoparts store.
      01-26-2013, 10:35 AM   #15
Jadar
Dejan
Jadar's Avatar
Serbia
1753
Drives: 2018 Audi S3
Originally Posted by spideypm View Post
Hello,
Tks!
No, and you wont notice a seat of the pants difference on any given catback, unless you do the whole header, midpipe/downpipe and catback. Especially with a tune is when you can notice a big seat of the pants difference.
But with the M perf dont expect anything other then deeper sound.
Its not lighter....not to dissapoint you or anything, its the same muffler as your oem with different packing materials and a tiny bit of better exhaust flow.
floor jacks or ramps is your friend ton of info on here my friend
http://www.f30post.com/forums/showthread.php?t=768703
FBO-PS1 and stuff
      01-27-2013, 11:16 AM   #16
Alpine F31
Alpine F31's Avatar
Originally Posted by dd1981 View Post
....But with the M perf dont expect anything other then deeper sound.
Right and right!
I had the exhaust installed yesterday (didn't do it myself, $70 at the local muffler shop) and overall I'm very happy with it. As dd1981 said, it's NOT lighter but I love the way it sounds! It's deeper but not raspy. I can hear it now inside the car but it doesn't "drone". The best part (obviously) is when I get on it hard and click off full throttle up shifts........YES! It sounds awesome...every shift delivers a race car like snort between gears and downshifts sound even better. Someone said this exhaust is "a lot of money for some noise" but for me, it was money well spent. The stock car was just tooooooooo quiet.
      01-27-2013, 01:59 PM   #17
mtgswede
Drives: 2013 335i xdrive m sport
It was already on my car when I bought it and I can agree, it sounds amazing under hard throttle, the exhaust burble is music to the ears.
[IMG]
Rear Quarter 3 by M.G.90, on Flickr[/IMG]
      01-27-2013, 04:25 PM   #18
Jadar
Dejan
Jadar's Avatar
Serbia
1753
Right and right!
Very glad to see you're happy with it. And $70 isn't much considering its cold out and who wants to crawl around on cold concrete to work on a car.
It's worth it, especially no warranty hassle. It's not intrusive at all and that's perfect. I think you summed it up nicely. Congrats
[IMG]
Wow you got lucky, enjoy it. That inline 6 sounds so unique I love it.
FBO-PS1 and stuff
      02-01-2013, 08:20 PM   #19
zibawal
Drives: 2012 X5D
Where can I get m performance exhaust kit with lid spoiler?
      02-01-2013, 11:02 PM   #20
shivaswrath
Drives: 2012 335i
The exhaust comes with a lid spoiler now?!!! :
      02-02-2013, 10:25 AM   #21
Balzz
96
Drives: F97 X3M
2019 M4  [0.00]
2021 X3M  [0.00]
Hmmm was about to pull the trigger on one of these things, but now wondering if there's a benefit to getting the GT high flow downpipe and keep the stock exhaust.
      02-02-2013, 05:39 PM   #22
shivaswrath
Drives: 2012 335i
The axle back muffler aka M Perf Exhaust only has an impact on sound, nothing discernible with performance.
Bear in mind a DP voids your warranty.
f30post
