BMW 3-Series (E90 E92) Forum
E92 - failed LED "bars" in tail light
08-03-2012, 03:12 PM | #1 |
Rep 1,495
Hi all,
The LED "bars" in my right tail light won't light up. This happens every time I detail my car (I polish and apply sealant with a Porter Cable DA polisher), but after a week or so they'll usually come back on. So far, it's been a couple weeks and no luck. I'm curious if anyone else has had this intermittent problem, in that the bars will go out, but come back on eventually. I'd like to avoid buying a new outer tail lamp assembly, but it's looking that way. Thanks! Zach
Then - E53, E85, E92, E82, F15, F80, G01
Now - F97, Macan S |
08-03-2012, 05:36 PM | #2 | |
Brotographer
88
Rep 1,741
08-03-2012, 05:45 PM | #3 |
Rep 2,063
Drives: 2007 335i Coupe
Garage List 1991 BMW E30 325i s ... [8.50]
1995 BMW 318Ti [0.00] 2007 BMW 335i Coupe [10.00] 1962 VW KarmanGhia [10.00] 2007 BMW Mini Cooper [9.00] |
what year is your car?.. if it is an 07 E92... it is just one of the bulbs ... easy fix... just remove the tail light assembly on the side you need to fix... there is only 3 bulbs inside... it is not LED so do not worry.... It happened to me one bar is out i thought it is complicated and one shop says need to be replaced with LCI but I checked myself and found out that is is just a blown-out bulb...
08-03-2012, 08:57 PM | #4 | ||
Rep 1,495
08-03-2012, 10:44 PM | #5 | ||
Rep 1,357
Drives: '08 e92 335i COBB 4.01 Stage 1
http://www.gospecracing.com/forums/showthread.php?p=220 Last edited by onesuperboi; 08-03-2012 at 10:49 PM.. |
08-04-2012, 01:58 AM | #6 |
Where'd my VTEC go?
481
Rep 6,067
The tubes are definitely LEDs on E92/E93. Those halogen bulbs are (from top to bottom) 2x for brake lights, reverse light, turn signal. The LEDs are bult into the tail lamp unit and can't be replaced separately. You need a new tail lamp. Unless you're adventurous and are willing to crack them open and see what part has failed on the LED board.
The E90/E91, however, do use regular halogen bulbs for the "tubes".
AW/Terra | ZSP | ZPP | ZCW | iDrive | CA
Mods: BC BR coilovers | Blacklines | M-tech rear | dual exhaust | M3 steering wheel | BMW SSK | ZHP shift knob | High-kick CF spoiler | NBT Retrofit M3 front control arms | M3 rear guide rods | Manzo rear toe and camber links | Monroe rear shock mounts | Varrstoen ES1 19x9.5+20 Front, 19x11+25 rear |
08-04-2012, 02:23 AM | #7 |
Rep 2,063
Well i guess this is a good reason for you to UPGRADE to LCI ... it is only $500++ a set... DO IT!!! DO IT!!!
http://www.e90post.com/forums/showpo...20&postcount=1 Last edited by crzylildude; 08-04-2012 at 02:30 AM.. |
08-04-2012, 09:28 AM | #8 |
Rep 1,495
Well, the outer tail lamp assembly is "only" $150 or so from Tischer. Looks like I'll just have to order one. Knowing my luck, they'll mysteriously come back on after I order, though.
05-04-2013, 05:38 PM | #9 |
Rep 518
I've just come across this issue guys anyone got anywhere with this without replacing the lamp. I don't want to replace the lamp just encase its not that. its really weird because its only done it since I polished my car and had it cleaned at a hand car wash :S
05-05-2013, 08:30 PM | #11 | |
Rep 1,495
05-05-2013, 09:01 PM | #12 |
Rep 423
thats a decent chunk of change. I have the same issue and it takes away from rear of the car. might have to bite the bullet and buy it
6K Halos, 6K interior Lights, 6K License plate lights, 5" VRSF FMIC, 3K Fogs, JB4 G5, Cyba air scoops, 19in ST1s, ACS Roof Spoiler, DCI, VRSF 3" DP, VRSF CP w/ Tial BOV, VVT Stage 1
08-19-2013, 08:20 PM | #13 |
ahat
1036
Rep 2,592
Looks like I will be getting added to the tailight fail list. :-/
'13 335IS N54 (1 of 373 LeMans Blue out of 3597 total production e92)- Grey interior (1 of 24 in LMB with any trans- 1 of 14 with DCT)-MODS -MFactory LSD/MHD-BQ custom Tune/ATM-IC/AFE Momentum GT Intake/Konis/Mfront&HeimJoint Rear rods&arms/Brembos. https://photos.app.goo.gl/Lo6aHZRo7XqtPkhL8 |
04-07-2014, 01:59 PM | #14 |
Rep 735
Another one here, after struggling to work out what was lighting the bars and then working out the contacts, I took my rear lens out and tried to get it working on the bench. No luck unfortunately
04-07-2014, 02:17 PM | #15 |
ಠ_ಠ
74
Rep 1,539
Take apart the lens and reflow the LCD PCB and there's a very good chance it'll work again. Examine for any contaminates, burns, or damaged traces. You can also just remove the old solder for the LEDs and resolder them by hand with some good 60/40 lead-based solder.
| 335i coupe | Monaco Blue | JB4 G5 ISO | Style 313M | Huper 40% tint | Aero lip | CSL trunk spoiler | M3 sideskirts | Paint-matched grilles | Painted reflectors | GP Thunder II angel eyes | Smoked LED sidemarkers | Self-coded | |
04-08-2014, 05:05 AM | #16 | |
Rep 735
I've had my rear lens in an oven for 25 mins at 130 Deg C doesn't seem to want to come apart .. it seems plastic welded rather than sealed with goo |
04-08-2014, 01:00 PM | #17 |
ಠ_ಠ
74
Rep 1,539
If you can't bake it open, then you'll have to break out the dremel and cut the damn thing open and then reseal it when you're done. Not the most elegant solution, but such is the case when BMW decides to make things as unfriendly to consumers as possible. Pretty ridiculous to have a a taillight that can't be replaced, even if it is an LED.
09-14-2014, 03:56 PM | #18 | |
Rep 4
i just did that...
I just dremmel away the transparent part of the tail light and had access to the pcb. Apparently there was a burned out led (the outermost) which i desoldered and replaced it with a 330 Ohm resistor. Problem solved. No flickering, no dullnes, no error on dash. notes: 1. 2 cracks appeared on the transparent plastic probably in the cut away phase of the repair... 2. Resealing is not as difficult as i thought it will be (just be sure no excess silicone is purred and a second layer of sealant is used) 3. The car is a total dissapointment 4. every led sits on the pcb on 4 pins. 3 of them are positive and one is negative, be sure to identify the ground one, so as to not short the whole board. 5. during testing be sure to use negative on black wire and positive on yellow (if repair is on the turn indicator leds) |
05-07-2015, 10:02 AM | #19 |
Rep 1,062
http://www.e90post.com/forums/showthread.php?t=769428
Would be nice if his pictures worked, I'm ordering an LCI set and then I'll be selling my old set, I'll probably take that one apart to see if I can fix it.
Sideways is the way of life.
08-10-2015, 08:05 PM | #20 |
Rep 5
So I have a weird problem along these lines. So on the drivers side only the top and bottom bar are lit, but the light above the reverse light is lit up. The passenger side has all three bars and no light above the reverse light. Thoughts??
08-10-2015, 08:50 PM | #21 |
Rep 10
I just repaired mine last week. My passenger side would go out and flicker. I used an oscillating tool to cut a section out of the back side of the tail lamp assembly to gain acess to the small LED circuit board. The culprit was a cold solder joint on small 8 pin surface mount IC. I re-soldered it and sealed it back up and it has been working great ever since. I guess I should have taken some pictures of it.
01-08-2016, 04:08 PM | #22 |
Rep 60
Drives: E92 325i 2007 sgm
have you got a photo of where you cut the hole or does anyone know how to split the unit?
TIA |
