BMW 3-Series (E90 E92) Forum
Here a good one! Does the odometer read tire rotation?
07-10-2007, 05:33 AM | #1 |
Test here
41
Rep 374
Does the odometer on the 3 read tire rotation or from other source.
cause if so, people with slightly larger wheels are screwing themselves of warranty miles. |
07-10-2007, 05:53 AM | #2 |
General
1570
Rep 29,202
Why, with larger wheels you get some "free" miles.
F10 520d M-Sport Alpine White | HRE P43SC 20x9+20x11 | Michelin PSS 255/35+295/30 | KW V3 Coilover | M5 Front Sway Bar + M550d Rear Sway Bar | 3DDesign Front Lip | BMW M Performance CF Spoiler | BMW M Performance Diffuser | BMW M Performance Black Grills | BMW M Performance Pedals | |
07-10-2007, 06:02 AM | #3 |
Test here
41
Rep 374
07-10-2007, 06:35 AM | #4 |
Rep 587
Drives: 2008 135i Vert
Odometer is based on Number of rotations X estimate known circumference (simplified)
so, for sake of argument, 2 rotations at 2 feet circumference is 4 feet traveled Now, lets say you upgrade your tires and the circumference is now 2.5 feet 2 rotations at 2.5 feet circumference is 5 feet traveled, but your car still THINKS you traveled 4 feet.... Your speedometer also reads low (or closer to actual now) PS - TOTALLY made up numbers for easy math and explination Want to add the Number of rotations above can be calculated by engine rpm and gear ratio, wheel speed sensors, all sorts of stuff... Don't flame me for trying to explain this simply. Edit As LEDZEP points out below, number of rotations would normally be based on sensor in the transmission/drivetrain. I was having a brain fart. But the rest of the above still holds true (and if you really wanted to be accurate, you COULD multiple RPM's and gear ratio to get the exact number of revolutions) Last edited by MikeCCrutchfield; 07-10-2007 at 08:26 AM.. |
07-10-2007, 07:44 AM | #7 |
Rep 587
07-10-2007, 07:52 AM | #8 |
418
Rep 12,276
Diameter of the tires/wheels obviously makes a difference too! The odometer is set at the factory based on the diameter of the stock packages, with some degree of tolerance. Changing to larger or smaller diameter packages will certainly throw off the accuracy. It's just that it is not actually measured at the wheel usually, but from the gear box.
I think it is bad luck to be superstitious |
07-10-2007, 08:16 AM | #9 |
Rep 587
Like I said...at least the reast of my post makes sense
07-10-2007, 09:52 AM | #11 |
Rep 17,767
Drives: F36 428i,E90 328i, E85 Z4 3.0i
Nice...an info nugget obviously unbeknown to Ferris Bueller
Official DC Metro Registry - Current, New & Prospective Area Members Roll Call! |
07-12-2007, 02:30 PM | #12 |
173
Rep 3,415
07-12-2007, 02:37 PM | #13 |
Too many Alex's, from now on, call me Beaufort
342
Rep 6,188
Yes, and theres typically a plug that if disconnected, does you know what. However you will lose all of your dashboard except for the tach. Dont know why that is.
13 HD FatBob
17 A4 Glacier/Black 1st Edition/Pre+/Sport/EurocodeTMD/Racechip 16 S6 (gone),14 S6 (gone),14 S6 (gone),13 S6 (gone),10 S4 (gone) 07 335i(gone) |
