E90Post
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > LSD Question
Reply
      09-30-2011, 04:06 PM   #1
Superoo
Drives: 2011 335is
LSD Question
Hi Guys,
Did a bit of research and realized the 07 feb+ production e92 LSD are welded to the rear axel.
My question is if i don't want to spent extra money on retro the core, can i just swap the rear axel with pre feb 07 production and purchase the bolt on ones like Quaife? would the swap be a hassle? or straight forward?
Thanks in advance
Super
      09-30-2011, 11:06 PM   #2
Superoo
Drives: 2011 335is
so no one knows?
not many ppl upgrade the option of LSD due to price, but i urge you all to do it because it's makes a huge differece.
      10-01-2011, 10:19 AM   #3
dre_2ooo
dre_2ooo's Avatar
30
Drives: '14 435i
IF it would fit, it would be pretty simple. I don't know if it fits though.
      10-01-2011, 10:29 AM   #4
flip4335
General Nuisance in a Private Conveyance
flip4335's Avatar
Drives: like it's rented
Originally Posted by Superoo View Post
Hi Guys,
Thanks in advance
Super
Of course, it will work. OEM swaps for OEM parts will always work. If you are thinking of going to a salvage to pick up a pre-FEB 07 axle, then go forward with confidence!
OBTW, I got the Quaife diff for my OCT 06 production 07 e90 335i and love the predictability and safety that a mechanical diff provides over an open diff.
GL with your plan. I believe it would be an outstanding, straightforward choice.
BMWCCA Member # 414198 |E90|SGM|6MT|Premium|Cold|Sport|Tint|LCI MSport Conversion|MTech|Blacklines|219M|PSS|Quaife|Helix FMIC|M3 Suspension|Megan Racing|GC Camber Plates/Coilovers|Eibach 440/800#|AR Catted DP|Cobb AP|StopTech Drilled/Slotted|SS Brake Lines|DWS
Quaife Review: http://www.e90post.com/forums/showthread.php?t=311570
      10-01-2011, 12:10 PM   #5
Bakeme521
Some say...
Bakeme521's Avatar
Drives: Fresh
2007 BMW 335i  [8.24]
That would be way too much of a hassle, just buy the install kit from **********s or something. It comes with the bolts and new ring gear and shims. All you need is the ring gear, you could buy a whole other diff but you can also just buy the pieces you need for less.
I have exhaust and an intake...
      10-01-2011, 01:16 PM   #6
Superoo
Drives: 2011 335is
care to elaborate more my friend?
if the differential is welded on the axel, the options are pretty much limited no?
Thanks
      10-01-2011, 01:45 PM   #7
galahad05
galahad05's Avatar
158
Drives: '07 335i e90
Welded diff = need new carrier or some welding-torch surgery at a minimum.
Always do right. This will gratify some people and astonish the rest.
--Mark Twain
      10-01-2011, 02:17 PM   #8
tscdennab
153
Drives: BMW 335i
2008 BMW  [6.24]
I emailed diffsonline.com and they said that they sell bolted crown rings and pinion for $900. Not sure if it's a good price but it may be a solution sometimes. I think **********s requires the customer to send it's differential for separation of the crown, etc.
However, I would highly recommend sending the rear axle to wavetrac/quaife/etc. for diff swapping. This way you eliminate as much as possible from the possible unexperienced shop error.
Reply
e90post
