E90Post
Studio RSR
BMW 3-Series (E90 E92) Forum > E90/E92/E93 Marketplace (For Sale / Trade / Wanted) > Private Owners For Sale / Trade / Wanted > Suspension / Brakes / Chassis / Spacers > FS: Rogue Eng 12mm Wheel Spacers
Reply
      04-11-2007, 11:15 AM   #1
jakehere
Drives: bmw
None
I put these spacers on my E90, drove around the block, decided I didn't need them, took them off. They are perfect. $100 shipped via UPS ground.
      04-11-2007, 11:30 AM   #2
Booster
Pave The Rainforest
269
Drives: Wagon
2007 335i Coupe  [0.00]
With bolts?
Sold: 2015 Pyrite Brown M3
Sold: 2020 Sunset Orange M340i Xdrive
Sold: 2021 Bluestone 540i Xdrive Msport
      04-11-2007, 02:00 PM   #3
jakehere
Drives: bmw
Yes, with the bolts that RE sent me.
      04-11-2007, 02:43 PM   #4
katsbimmer
Drives: 2010 e90 328i Msport
2010 328i LCI E90  [10.00]
2006 325i  [0.00]
What wheels
What wheels were you using these on...stock??? Do you now the offset of your wheels??? I have m5 reps. with 38 offset and was wondering how they would look on the rears...thanx, glen
AW 2010 E90 LCI
      04-11-2007, 04:45 PM   #5
JMeezee
JMeezee's Avatar
Drives: '07 E90 SG 335i
2006 E90 330i  [0.00]
These will net you a +26mm offset, which is kind of aggressive for the e90. But since I see no indication that you are lowered at all, you should be okay (ie. no rubbing)...and it will look good IMO.
<= these wheels are not 7-spoked
2007 SG E90 335i: OEM Spoiler / Hartge Replica lip / M-Tech Sides and Rear / ACS Replica roof spoiler / Blacklines / Eibach Pro-Kit Springs / Koni Yellows / 19" Miro M6 Reps / Modded CDV / 35-20 Tint / LUX 3.0 / MTEC Fogs / Stealth Turn Signals / OEM Leather Short Shift knob / NO TUNE YET so I drive slow
      04-11-2007, 05:31 PM   #6
katsbimmer
2006 325i  [0.00]
so this would keep me even with the wheel wells at the top or just under the lip??
AW 2010 E90 LCI
      04-11-2007, 05:39 PM   #7
E90330iS
Germany
143
Drives: BMW M4
2006 330i  [0.00]
Are there any improvements in handling other from its cosmetic improvement? And how much do they usually go for new??
      04-11-2007, 05:41 PM   #8
JMeezee
JMeezee's Avatar
Can't say for sure, but I don't think you'll be pushed out so far as to be perfectly even with the fender...You should still be slightly "tucked" somewhat.
I've got rims with a +30 offset, and I tried some 10mm spacers (for s#*ts and giggles) and the resulting +20 offset was almost perfectly flush. Rubbed like all hell, but it looked good!
      04-11-2007, 05:48 PM   #9
JMeezee
JMeezee's Avatar
Can't comment on handling, but they go for $110 plus shipping new.
      04-11-2007, 05:54 PM   #10
KkSc
KkSc's Avatar
Hong Kong
173
Drives: 13'FR-S/15' F80 M3
are this easy to install??are they for the front or the rear??
      04-11-2007, 06:04 PM   #11
JMeezee
JMeezee's Avatar
They'll fit both front and rear, but are recommended only for the rear. Anything thicker than 5mm can be dangerous in the front.
Install is easy! Remove the wheel, clean the hub, place the spacer on the hub (preferably with some anti-seize), and replace the wheel with the extended bolts.
      04-11-2007, 09:30 PM   #12
katsbimmer
2006 325i  [0.00]
check your pm's
Jake, please check your pm for my message...glen
AW 2010 E90 LCI
      04-13-2007, 02:36 PM   #13
katsbimmer
2006 325i  [0.00]
SOLD
Sold to me!!! Now i need some 10mm for the front...and a set of stock (sport pkg.) springs....
AW 2010 E90 LCI
Reply
e90post
