BMW 3-Series (E90 E92) Forum
do halogen lights
12-08-2010, 11:21 PM | #2 |
Rep 1,007
The head light housing is a diff story. If you bought the bulb itself then no you don't need ballast...If you bought a HID Kit, then yes it should come with a ballast..Hope that was clear enough!
12-09-2010, 10:06 AM | #3 |
Mmmm torque
19
Rep 318
Drives: Like a Boss, hard and fast
To OP, I'd recommend you get a projector based headlamp housing to go with your HID bulbs. HIDs in halogens, look bad, are ricey and produce an unnecessary amount of glare to oncoming drivers.
Depo makes a replacement headlamp housing that has projectors for low beams. Various sellers offer them here and on ebay. http://www.e90post.com/forums/showthread.php?t=455740 You will most likely need an error canceller as well since the lights will most likely flicker.
Monaco Blue E90 328i with Nav, Sport, Premium and Comfort Access packages, 6FL with iPod cable
SAE spec Depo with HIDs and HID fogs Depo AE replacement Album |
12-09-2010, 02:49 PM | #5 |
No 55mph
1622
Rep 8,476
^^^^^ THIS
GP Thunder 7500k's are simply halogen bulbs like the stockers, but in a different color/light output I know, the package says 'H.I.D.' on it - but that is a misnomer as they are not the same as the actual HID capsules, they just use that term to describe the 'look' of the light coming from the halogen bulbs. GP Thunder Halogen 'H.I.D.' bulbs will never even come close to the brightness/output of a tru HID capsule or the lifespan. So answer is NO, ballasts not needed... Example of GP Thunder Halogen 'H.I.D'. Bulb: Example of actual HID Capsule:
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
12-09-2010, 03:34 PM | #6 |
Mmmm torque
19
Rep 318
My bad, I always think people are asking about upgrading to HID bulbs.
To the OP, as the 2 posters said above, you don't need ballasts for halogen bulbs.
12-09-2010, 07:28 PM | #8 |
Rep 766
I agree. The LCI headlights are much nicer looking! I was going to get the Depo HIDs to replace my halogens but I just don't like the pre-lCI looking headlight assemblies. Now if depo would only use a newer housing...
12-09-2010, 08:37 PM | #9 |
Rep 1,007
DEPO does make a "LCI" Version headlight..if I'm wrong correct me, I thought I saw them on eBay from DEPO.
edit: Hm I thought I saw them, but can't find them anymore...well if I am wrong...DEPO is in the process of making one Last edited by bpsu07; 12-09-2010 at 08:43 PM.. |
