BMW 3-Series (E90 E92) Forum
E92 Loose Rear End
09-12-2010, 11:48 PM | #1 |
Rep 319
E92 Loose Rear End
I have the E92 coupe with the sports package with the 18 inch tires and 255/35's on the rear.
I notice when the road is uneven and bumpy, the rear end feels like it wants to slide out. This is noticeable if I drive only one side of the car (say the right side) over a manhole cover that is maybe recessed an inch (i.e. 25 mm for you Europeans). Anybody else notice this? I have had the car since new (2007) and it only has 18,000 miles so it can't be shocks or bushings. This is more noticeable when it is wet out. |
09-13-2010, 01:40 AM | #5 |
Rep 1,948
LSD does shit for you with what the OP is describing. Trust me, i have LSD and it doesn't help. Hell, i have ohlin coliovers, swift springs, m3 bushings, m3 control arms and then some.
Also, OP, i have a 2007 335 and i had the same feeling. Hence why i upgraded all the components. I still don't feeling 100% steady. |
09-13-2010, 06:18 AM | #6 |
Rep 861
Ok coming from my previous E90 that had LSD, to my current 335, I can say LSD does make a dfiference.. but however I was also noticing slidding out when i bought my 335 esp when going over a drain cover or anything slippery on the road.
I didnt believe it was due to not having LSD as every other cay without LSD never slips like mine did. Anyway long story short... IT was my tyres, they were wearing out, as soon as I changed them to new ones..problem solved. mine also had 18k on the clock when it was doing that. Hope this helps
09-13-2010, 03:19 PM | #7 |
Rep 319
Thanks guys. I have talked to a poster on another forum who had this same problem and it is due to tires.
My rear tires are cupped on the inside and need replacing. The Bimmer has a lot of camber, so the inside of the tire is the main point of contact. The poster I talked to said the problem went away as soon as he changed the tires. It is a little uncomforting because the rear end wants to kick out if one wheel is going over something slippery at any speed above 30 miles an hour. |
09-13-2010, 03:19 PM | #8 | |
Rep 319
09-13-2010, 03:27 PM | #10 |
Rep 319
09-24-2010, 02:08 AM | #14 |
129
Rep 6,773
+1 I swapped out my 18inch RFTs for 19" Falkens Fk452s non-RFT and what a difference...Also RFTs are super super heavy..I shed at least 40 pounds going from RFT to non-RFT and the ride is better on 19s non-RFT then w 18s RFT.
09-24-2010, 06:38 AM | #15 |
Rep 1,565
It has nothing to do with LSD.
It has everything to do with the RTABs, Subframe bushing, and such. The installability of this car compared to my stock 2003 M3 I had is appalling.
2020 M340i: Dravit Grey Mettalic. Loaded.
09-24-2010, 06:40 AM | #16 |
Rep 1,565
Were you arguing that AWD has some type of superior road handling and doesn't tramline, swerve all over the road with changes in the surface?
09-24-2010, 07:39 AM | #17 |
Rep 107
Rear Control Arm? This happened to my EVO VIII
2007 E92 328xi: Jet Black/ Black/ Aluminum|6MT/|Active Cruise|Xenons|Bluetooth|IPod|
Chuck Norris once kicked a horse in the chin. Its descendants are now known as giraffes. |
09-29-2010, 09:13 PM | #18 | |
129
Rep 6,773
Once you do these upgrades u can then align the car properly..I get the same feeling of instability and being all over the road too..The 335i is not meant to be a true track car like the M3..its built w comfort in mind which sucks for guys who wanna push its limits. |
