BMW 3-Series (E90 E92) Forum
Spring Cleaning: Get your HVAC ready
04-09-2010, 01:12 AM | #1 |
2009
Rep 6,916
Clearing the Air By Michael Mankarious Featured Product: Klima-Cleaner Nothing goes hand in hand like spring and detailing your car. If you’ve been dealing with snow than more likely than not you’ve been waiting for the moment when you can unearth your car from layers of road salt and grime. While surface treatment of the paint finish and interior get all the attention during the car care season, there’s one area that is often overlooked – the air conditioning system. If you’ve ever noticed an unpleasant odor (old gym socks maybe?) coming out of your vents when your air conditioning system is on, you might think there’s nothing that could be done about it other than ignoring it or masking it with an air freshener. Or maybe you’ve never noticed it and a passenger brought it to your attention. So why is there an odor coming from the air conditioner? Cause Every time you use your air conditioner, you are providing an opportunity for odor causing mold, mildew and bacteria to grow within your air conditioning system. To explain how this happens we must understand how the air conditioner system works. Here’s a basic explanation. When the air conditioner is on, it pulls moisture out of your car’s interior through a unit called the evaporator core, which is located underneath your car’s dashboard. When the humidity (moisture) levels drop, the air temperature also drops. The moisture that is pulled from the air condenses and is drained outside the car. Ever notice a pool of water under your parked car on a hot summer day? That’s the water that was drained from the system. This also happens to be the way home air conditioners and refrigerators work. Even though most of the moisture is drained from the car, moisture still remains on the evaporator core system. As the air circulates around the evaporator core, dust and pollen in the air stick to the moisture on the metal fins of the evaporator. Soon thereafter mildew and bacteria begin to grow on the surface of the evaporator. This collection of grime and odor causing agents begin to release odor and is the cause of the smell coming out of your vents. Solution One way to help prevent or at least reduce this issue is to keep the air conditioner on the fresh air setting. This keeps fresh air circulating around the evaporator which helps keep it and the surrounding area dry thereby reducing the chance of any mold, mildew and bacteria from growing. However, there are two disadvantages to this method. First, it’s also not always convenient to switch to the fresh air setting in order to draw in hotter air to dry out the system. It just might be too hot or cold to be worth this extra effort. It’s also not economical. Second, allowing fresh air to flow in increases the accumulation of dust, pollen and brake dust build up. Of course if you have a cabin air filter you don’t have to worry about that since it will trap the pollutants before it reaches the evaporator area. Another possible solution is to spray a disinfectant like Lysol® into the ventilation system or have your car treated with ozone or other similar system. However, this process does not affect any dust, pollen and other contaminants that have accumulated on the evaporator. While it may disinfect any mold, mildew and bacteria, the results are usually short term. Last but not least, you can have your system treated by the dealership. They will use Klima-Cleaner or a similar product and may charge $150 and higher for this service. This is the most effective solution but it can be expensive. Solution: Klima-Cleaner As we found, the best solution is to have the dealership treat your air conditioning system for you. However, it’s quite expensive. If you are a do-it-yourselfer, you can use the same product they use. Applying einszett Klima-Cleaner effectively disinfects mold, mildew and bacteria on the evaporator core. It also applies a thin layer of protectant that has been proven in laboratory tests which makes the growth of contaminants more difficult so the results are long lasting. Klima-Cleaner’s effective foam solution emulsifies the debris build up on the evaporator core so it’s cleaner and will run more efficiently. Another significant benefit is the result of cleaner cockpit air. This is especially important for allergy sufferers who are sensitive to airborne contaminants. For those who are highly sensitive to chemicals, rest assured that Klima-Cleaner is a water- and salt-based cleaner so chances of any skin reaction is extremely minimal. Application Apply Klima-Cleaner exactly as directed on the product label taking caution that it may be best to have it applied by a certified mechanic if you are unsure about applying the product yourself. It’s best to apply Klima-Cleaner every six months. The easiest way to remember is to apply it every time you change your oil. We also suggest you change your cabin filter at the same time for optimum air conditioning performance and the freshest, cleanest air. And don’t’ think that Klima-Cleaner is only for the spring and summer. Applying it in the winter is also important whether you live in area that snows or rains. If you drive in the winter, you’ve probably used your air conditioner setting in conjunction with the heat setting to de-humidify the interior. If so, the evaporator core is susceptible to the same issues as in the warmer months. Summary Detailing your car is a full system process involving the treatment of every aspect of the car. An application of Klima-Cleaner as part of your detailing regimen will improve the performance of your air conditioning system and improve the air you breathe inside your car. Disclaimer: If you are unfamiliar with your car’s air conditioning system or unsure about application, you should have Klima-Cleaner applied by a certified mechanic only. Many cars in the last few years have complicated air conditioning systems that are operated using electronic components. Applied incorrectly, Klima-Cleaner may damage these electronic components. einszett will not be responsible for any damage caused due to improper application of the product. To purchase please click here - 1Z einszett Klima Cleaner |
06-22-2010, 07:17 AM | #3 |
2009
Rep 6,916
06-22-2010, 09:09 AM | #4 |
IN THE KNOW!!!!!!!
12
Rep 431
Great stuff! I smoke in my car sometimes and this stuff does the job! It does freshen up the HVAC.
2007 Jet Black 335i Coupe: Saddle Brown interior | ZSP | ZCP | ZPP | iPod integration. 1994 Hellrot 325is: Sport Package | PSS9 Coilover | AutoThority chip | AutoThority CF Intake | UUC pullies | Dinan HiFlo Throttle Body | UUC StrutBarbarian | UUC Evo II SSK | BMW Motorsports X Brace | Rogue Engineering DMS exhaust | Kumho Ecsta V700 R Comps | |
02-25-2011, 03:12 PM | #5 |
Rep 335
Question for you phil - does this fix the defroster air that comes through the vents right below the windshield? When I use my AC and have it coming through the front vents, it smells fine, but when I turn on the front defroster - smells like dead skunk!
02-25-2011, 11:47 PM | #6 | |
2009
Rep 6,916
did you check the filters? |
02-26-2011, 01:14 AM | #7 |
Rep 335
02-26-2011, 12:52 PM | #8 |
2009
Rep 6,916
I would probably give it a try. You have nothing to lose if that doesn't work you may want to bring it to your dealer, there might be something trapped in there or stuck.
