BMW 3-Series (E90 E92) Forum
That's it... I want a temp gauge!
08-18-2009, 05:18 PM | #1 |
82
Rep 2,446
N52K, no i-drive here.
Somebody around destroyed his 2010 Mazda3 engine because the temp critical light came too late and he needed 20s to pull over. He hit something and the failure occurred many minutes later and swore that he didn't extend the drive with the light on. The E90 coolant temperature is live in CANBUS... it should be easy to retrieve and to display, right? NOT. Of course not in the regular menu... I can get it through the hidden BC menu after 50 clicks or so with the unlock... insane. I won't open the cluster to install an OEM instead of the mpg-o-meter, but I wonder what options can be wisely considered. Any aftermarket offerings? |
08-18-2009, 06:12 PM | #2 |
Rep 297
I really doubt you will ever have a temp issue on a n52. That being said if it does come up i'm sure BMW has put it up with ample time for you to get off the road, and or least get the heat on to try to lower the temperature, while your pulling over.
08-19-2009, 05:31 PM | #4 | |
82
Rep 2,446
I am sure that the Mazda3 owner I referred to, trusted Mazda on that one as you do. Anybody knows what are the different temperature thresholds in relation with various warning? BTW, our E9X have an electric pump (and probably a very popular maintenance item after 6 yrs) and when it stops working according to what we read here, it is a matter of a few seconds. Maybe the engine won't let the engine run in critical temperature I don't know. Going on the crazy (and cheap) side, maybe this would work. http://cgi.ebay.com/ebaymotors/ws/eB...8428&viewitem= Being bluetooth, it can connect to my old faithful Palm Treo 650 or another device. I could even do this from my living room if the car is in my parking. I told you it was crazy. |
08-19-2009, 05:41 PM | #5 |
General
8265
Rep 18,849
Drives: BMW
Performance Steering Wheel will put both Oil/Coolant temp on display for you.
Tom G. | european auto source (eas)
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM |
08-19-2009, 05:45 PM | #6 | |
Midlife Crises Racing Silent but Deadly Class
1821
Rep 5,337
Drives: 2006 MZ4C, 2021 Tesla Model 3
That's why BMW stopped putting in a real coolant temperature gauge and instead just gives their consumers an "idiot" light that tells them their engine is about to go from "fine" to "Chernobyl." |
08-19-2009, 06:49 PM | #7 |
Rep 5,457
+1 I always drive with mine on the coolant oil temp display!
2022 X3M Brooklyn Grey
2008 E93 335i FBO 2012 Mercedes C63 Black Series Alanite Grey |
08-19-2009, 06:51 PM | #8 |
¡Barça!
168
Rep 12,042
Drives: Rainbow Sandals
that wheel is awesome!
Tate's chicken sucks!
08-21-2009, 05:05 PM | #9 |
82
Rep 2,446
The BMW wheel w/temp display leaves me think that *there is* probably already one circuitry (may a socket) left ... with no temperature gauge connected to.
I checked in the DIY, the closest thing should be http://www.e90post.com/forums/showth...ht=temperature I am not yet done with this; I'll do a request for DIY in the appropiate section and see. |
08-21-2009, 05:08 PM | #10 | |
1821
Rep 5,337
If you have one of them "GTech Pro" EGS dealio with OBD-II, you can get a gauge pod that attaches to the EGS to display the already present temperature signals. |
08-24-2009, 11:29 AM | #12 | |
General
8265
Rep 18,849
Drives: BMW
08-24-2009, 11:41 AM | #13 |
Rep 753
And real expensive too.
Every BMW I've owned has had at least one cooling system overhaul in its lifetime. I can't imagine this car will be any different. I can't believe BMW kept the cheesy MPG readout but deleted the temp gauge. Way to go BMW engineers! |
08-24-2009, 12:25 PM | #14 |
Rep 292
Drives: 2011 E90 328xi 6MT Alpinweiss
Garage List 2014 BMW 535i X-Drive [0.00]
2004 BMW 325cic 5MT [0.00] 2016 BMW R1200RT [0.00] 2011 BMW 328xi 6MT [0.00] |
I rented a Chevy van from Enterprise this weekend to take my kid back to school. What a novelty to see that it had gauges for coolant temp and oil pressure, and even an ammeter. Must have cost GM at least... gosh... $20 to build those in? My E90 has -- a gas gauge. Oh yeah, it also has a fancy TPM system that finally came on 3 miles after my tire had gone completely flat from a big nail thump-thump-thumping in the tread (a better TPM indicator), as I was already headed to a tire dealer.
08-24-2009, 03:14 PM | #15 |
32
Rep 867
How do you keep from running out of gas?
Not only will it kill you it will hurt the whole time while you're dying.
http://www.stevesnovasite.com/ http://www.jalopyjournal.com/forum/ http://www.garagejournal.com/ |
08-24-2009, 03:14 PM | #16 |
32
Rep 867
Actually the performance wheel is getting the data before it even gets to the OBDII, off PT-CAN.
08-24-2009, 03:23 PM | #17 |
Rep 292
BMW will soon drop the gas gauge and rely on the OBC to guesstimate how many miles of gas left -- and an idiot light telling you 5 miles until empty. Just like they don't want us to know the oil level by nixing the dipstick, who needs to know the gas level, right?
08-24-2009, 04:08 PM | #19 | |
32
Rep 867
Do you have a MT or AT? If someone has never known sat in an E9x and driven the MT how would they correctly correlate the proper shift point to RPMs without a tach? At this stage there's no reference point, so they cant use the engine sound. How would a deaf person be able use the MT? Would you remove the AT from their options list? There are needs for gauges other than the speedometer. An oil temp, water temp, tachometer, fuel, etc all have justified uses. Although you may not value them, that does not mean they have no use.
08-24-2009, 05:08 PM | #20 | |
Rep 59
Gauges have their own use, but you don't necessary need to have all of them. Do you think you will become a better driver if you have all the gauges you ever need? I doubt it. |
08-24-2009, 05:20 PM | #21 | ||
32
Rep 867
What does the statistic have to do with this?
08-24-2009, 09:17 PM | #22 | |
Rep 431
I had to pit in, drive the car at slow speed, etc. + 1 on the trick to turn on the heat in the cabin to evacuate it from the hood. Next sessions were fine but I stayed below 6k RPM. FM
F34 335i xDrive, M Sport, Alpine White, Black Dakota, Dark Burl, Dynamic Handling, Technology, Driver Assistance, Premium, Active Cruise Control, Heated Seats, Side and Top View Cameras, European Delivery, Debadged
