03-26-2024, 09:39 AM | #2 |
Rep 203
I can't make out the offset of the first wheel but assuming 19x9 2x offset, the specs on paper is fine but it's the caliper clearance that's key in the front. The 2NH calipers require a lot of space; even the OEM 788m is a tight fit.
The rear appears to be 19x10.5 26 offset. That will have a lot of poke on the outside and will most likely cause rubbing. |
03-26-2024, 11:16 AM | #3 | |
Rep 1,119
Are there issues with other 19’s not clearing the brakes? I assumed any 19” wheel should be safe to clear |
03-26-2024, 06:26 PM | #4 | |
Rep 203
03-26-2024, 07:33 PM | #5 |
Member
11
Rep 89
What’s this wheel intended to fit? What is the bolt pattern spacing? What is the hub bore diameter?
‘20 BMW M2 Competition
‘24 BMW i4 xDrive40 ‘22 Ford F-350 Platinum Power Stroke Super Crew ‘22 Jayco Pinnacle 32RLTS |
