03-08-2024, 11:56 PM | #1 |
Rep 30
AA exhaust drone
Hi,
I recently got the AA EL midpipe and muffler - resonated. I really like the sound of high rmp range but on lower rpms it's quite boomy and drones on highway speed. Is that normal? didn't expect it to be like that.. |
03-09-2024, 10:22 AM | #2 |
Rep 19
What rpm are you getting drone? I have the AA EL midpipe with resonators to the AA valved axle back and it’s not droney at all. Even without resonators and it wasn’t bad.
FMOS Racing121.50 |
03-09-2024, 11:31 AM | #3 |
Rep 30
Hmm thx thats what i was expecting.
Its under 3k and most pronounced at 1800 rpm. I dont think its a leak. Not sure if it could drone if it has slight contact somewhere. The resonator was definitely fitting pretty tight aroubd the area.. |
03-09-2024, 12:57 PM | #4 |
Rep 60
I agree, the AA system which I own sings at higher RPMs , but at cruising speed there's definitely a drone.
I find myself driving around in a lower gear than I normally would, just to get out of that 1800-1900 RPM band. It certainly kills the fuel economy battling to get rid of the boom ... 25-27 mpg w/ stock system, down to 20-21 mpg trying to live w/ the AA. The AA system was also annoyingly loud on cold start w/ the stock exhaust valve map opening the valves. I chose a valve controller with the valves shut all the time and have it go in to the stock valve map when I activate the valve controller remote. That way I can occasionally hear the wail in sport mode when the coast is clear. I still own the complete stock system and may well swap it back on |
03-09-2024, 09:01 PM | #5 |
Rep 75
I think the EL midpipe is known for having a bit of a drone/rasp at the 2kish rpm. I have the EL non-res (soon to be resonated) and the AA muffler. The low end is definitely more droney and a tad too loud when revving in at idle IMO.
Hoping the resonators will fix some of those things for me. |
03-09-2024, 11:24 PM | #6 | |
572whp Stock Turbos/DP E60 Tune by Tier1Tuning
182
Rep 302
03-09-2024, 11:40 PM | #7 |
Rep 75
03-11-2024, 10:28 PM | #8 |
Rep 30
Yeah I was on that setting for a couple of months and wanted more sound so went with AA box but didnt want the droning. I guess there are pros and cons for going loud (except it isn't as loud as i hoped for in the high rpm range either.. )
I though this would be a happy medium but now i wish i would have stayed EL mid and stock exhaust or jus might as well go all the way with Remus race.. |
n8dgr84182.00 |
03-11-2024, 10:30 PM | #9 |
Rep 30
Would be interested to hear how its like with the resonator on. Let me know once you have them on!
03-11-2024, 11:07 PM | #10 |
Rep 75
03-11-2024, 11:19 PM | #11 | |
Rep 79
Drives: 2020 M2C (DCT) - Sunset Orange
When I had the stock muffler on with the AA EL resonated pipes I didn't experience any drone either FWIW. |
n8dgr84182.00 |
03-12-2024, 11:52 AM | #12 | |
Boost All the Things
122
Rep 95
The resonators make a shocking amount of difference given their size. I also had my tune done to keep the valves closed and reduce the magnitude of the rev at startup because that was simply ridiculous, even with the resonators.
'21 M2C, HS, MT, EP - AA EL + Axle Back, FMHE, "Enabled"
Past - '09 335i Sport, '11 M3 ZCP Sedan, '11 550i M-Sport Also - '94 F-150 Lightning (mild, mid-mount turbo), '95 F-150 Lightning (big motor, big turbo), '15 Chevy SS Sedan (supercharged) |
03-13-2024, 12:43 AM | #13 | |
Rep 30
03-13-2024, 05:56 AM | #14 |
122
Rep 95
I had to dimple the driver's side piping where it passes closest to the differential brace/mount. It would make contact and buzz really badly just off idle. Upside was that it made a nice mark on the tubing exactly where it needed to be modified.
03-13-2024, 09:03 AM | #15 |
Rep 30
hmm i don't have the buzzing issue. I had one before midpipe hitting the brace but fixed it. do you have any tune or code changes?
03-14-2024, 04:26 AM | #16 |
122
Rep 95
Yes, I have an ECU swap with an Enabled tune.
