BMW 3-Series (E90 E92) Forum
Spring clamp on upper heater core hose
02-08-2024, 08:04 PM | #1 |
Rep 57
I’m in the process of changing the 8 hoses and radiator, but I can only work a couple hours here and there, so it’s been stop and start. Today I got the radiator out and attempted to change the heater core hoses. Got the lower one done no problem (except I whacked my elbow pretty hard on the power steering reservoir bolts — the ones designed to poke out an eye).
But I can’t get the stupid spring clamp in position with the hose. I can get the hose on, but then the spring clamp won’t slide up. And if I put the spring clamp on the aluminum nipple first, I can’t maneuver the hose under it. Are there any tips? Why is this a spring clamp? Why can’t it be a worm drive? <shakes fist at the sky> Sincerely, Jackie |
02-08-2024, 08:55 PM | #2 |
General
17395
Rep 18,786
Just use a worm drive hose clamp.
StradaRedlands4976.00 |
02-09-2024, 12:29 AM | #3 |
Rep 3,040
Drives: 2006 BMW 330i MT
Garage List 2006 BMW 330i [8.21]
2009 BMW 328i Touri ... [7.90] 2013 BMW X5 35i [7.63] 2011 BMW 528i [8.75] 2006 Mazda3 [5.50] |
It looks really dry, put some coolant on the nipple and hose. Then use pliers to open up the clamp while you put it on. If that doesn't help, then yeah, regular clamp.
mainbearing1084.50 tcphoto3547.50 |
02-09-2024, 12:41 AM | #4 |
Rep 189
As StradaRedlands said use pliers on that clamp, it locks open so you can freely fit the hose and then unlock it in place, it's a pita but it somehow works, took me some time too when doing the heater core
StradaRedlands4976.00 ForestHillsJackie102.00 |
02-09-2024, 09:41 AM | #5 |
Rep 57
PhaceN52 what do you mean by locking it open?
(My momma taught me how to fold a fitted sheet, but she taught me nothing about hose clamps. 😄 |
02-09-2024, 10:33 AM | #6 |
Cometh
1092
Rep 1,308
Drives: Boy's Soul
Are you using pliers to open the spring clamp fully before sliding it into position? There doesn't seem to be an issue based on the photo.
A spring clamp is preferred over a worm gear clamp for its constant tension during expansion/contraction |
02-09-2024, 10:47 AM | #7 |
Rep 6,304
Yeah I would avoid worm clamps as well after learning more about them and how it's not the optimal choice, although I think the water pump U hose under the car have them factory . Especially if those hoses are difficult to reach in case it leaks or need to be tightened. I'd opt for ear clamps/oteiker clamp if you have to change it.
But yeah if it was on there you should be able to put it back. I would defiintely try to get it on while it's on the hose instead of sliding hose under. The lube method might help it move. Also if you don't have lockable spring clamp pliers can be more of a PITA to deal with. |
02-09-2024, 11:34 AM | #8 | |
Rep 189
it has a tab that holds the clamp in position so you can slide it where it should go once you have put the hose on - the "end part" on the left with the square hole goes on the tab where the ") 703" is in the pic, if it's not exactly like that it should have some sort of "step" where it locks open then you force it even more and it closes somehow and happiness ensues Last edited by PhaceN52; 02-09-2024 at 12:21 PM.. |
ForestHillsJackie102.00 StradaRedlands4976.00 |
02-09-2024, 11:51 AM | #9 |
Rep 189
Ha I found a picture of when I did it, forget any kind of drawing skills , hope it's easy to understand
02-09-2024, 12:52 PM | #10 |
General
17395
Rep 18,786
What internet myth number is the thing about worm-style hose clamps? Lol.
02-09-2024, 12:56 PM | #11 | |
Rep 189
but reusing the original one has a more oem feeling, so you're satisfied after you finish a diy Maybe the heater core pipes are aluminum, clamps are iron, with a worm style one after like 10 years of heat cycles and different expansions it can maybe cut through the rubber pipe Last edited by PhaceN52; 02-09-2024 at 01:05 PM.. |
02-09-2024, 01:24 PM | #12 | |
General
17395
Rep 18,786
Jackie can use a worm clamp if she can't get the spring clamp in place; it is a tight working space. Last edited by Efthreeoh; 02-10-2024 at 09:04 AM.. |
PhaceN52174.50 |
02-09-2024, 01:26 PM | #13 |
Rep 901
this is what's can be useful for spring clamps:
https://www.amazon.com/Clamp-Pliers-...2c77224f5&th=1 or at least https://www.amazon.com/Professional-...hoCWdcQAvD_BwE look up hose clamp pliers, these are way better for this than regular pliers. used those many times on my Audi
09 328i TiAg 6MT barebones with sport package
ForestHillsJackie102.00 mainbearing1084.50 |
02-09-2024, 03:34 PM | #14 |
Rep 1,682
^ the first type with the steel cable really solved a lot of problems for me.
At that location I would think slip-joint pliers would work. If not the steel cable type should. And try what StradaRedlands wrote. A spring clamp on one hose, and a plastic connector on another. What was those BMW engineers thinking. |
02-09-2024, 05:23 PM | #15 |
Rep 57
I bet you they had an intern that day, and his manager was like “I’ll just give him a hose clamp assignment… what could go wrong?” Either that, or BMW is in cahoots with Big Pliers and they want you to buy ALL the pliers to deal with this. 😆
Efthreeoh17394.50 StradaRedlands4976.00 |
02-09-2024, 07:30 PM | #16 |
Rep 4,073
I've never had the need/ pleasure of accessing that hose or clamp, but your photo appears to show a "Cam-like" slide on lower/left side of clamp, where it will "Lock" in open position if you squeeze two "ears" together with pliers (far enough). If so, pliers with correct jaw to handle angle should make quicker job than screw-clamp.
Like F30, I'm "Old-school" and have a collection of screw-type hose clamps of all sizes, but NO "Squeeze" type clamps. George |
02-10-2024, 11:25 AM | #17 | |
Cometh
1092
Rep 1,308
Drives: Boy's Soul
https://www.realoem.com/bmw/enUS/sho...diagId=64_1497 |
02-10-2024, 12:01 PM | #18 | |
General
17395
Rep 18,786
02-10-2024, 12:04 PM | #19 |
Rep 261
Drives: 2007 335i Jb4 & perf. mods.
Some lubrication with the use of pliers will get you to the finish line. Be as gentle as possible with the tube you're mounting that hose to or you'll be in for a much more challenging job (leaking heater core).
02-10-2024, 05:45 PM | #20 |
Cometh
1092
Rep 1,308
Drives: Boy's Soul
Yes, and I found it strange that the hose with the spring clamp still has a quick connector on the other end. My only guess is the proximity of the two hoses prevents the use of two quick connects during assembly?
StradaRedlands4976.00 Efthreeoh17394.50 |
02-10-2024, 08:42 PM | #21 |
General
17395
Rep 18,786
I guess. If it were me I'd just use spring clamps at every hose junction. The plastic quick connects seem to add complexity to the part design with not much benefit IMO.
02-16-2024, 06:27 PM | #22 |
Rep 57
So I took another run at connecting this hose using the flexible hose clamp pliers suggested, but I wasn’t able to get it to squeeze far enough to open the clamp to its limit.
But fortunately, after heating the hose, applying coolant, and using this pair of pliers, I had success. It actually worked best by putting the clamp on the heater core outlet, sliding the hose on, and then maneuvering it under the clamp. |
StradaRedlands4976.00 PhaceN52174.50 |
