M2 Technical Topics > S55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > Best charge pipe for S55...
      01-06-2024, 03:35 PM   #1
m2ss
m2ss's Avatar
2607
Drives: people crazy
Title pretty well says it all other than is it even necessary on stock tune?
2020 M2C
2018 M2 LCI
Gone 1M, 991.1, 991.2, 718S, 991.2 TT, R8 Spyder RWD
      01-06-2024, 05:06 PM   #2
F87source
F87source's Avatar
Drives: Bmw M2
It actually turns out the S55 does suffer from chargepipe issues (inparticular at the flange): https://f80.bimmerpost.com/forums/sh....php?t=1113212
The good news is that it should be relatively easy to swap out and upgrade since everything is on top of the engine.
I would personally buy BMS charge pipes: https://burgertuning.com/products/m3...um-chargepipes
Because I have had really great experiences with BMS products. I would avoid carbon charge pipes because I hear they can crack under high boost conditions.
https://f87.bimmerpost.com/forums/sh....php?t=2038326
m2ss2607.00
      01-06-2024, 05:31 PM   #3
F87source
F87source's Avatar
Drives: Bmw M2
while you're at it you probably should replace the stock air to water intercooler as well, they are known to leak.
      01-06-2024, 05:46 PM   #4
m2ss
m2ss's Avatar
2607
Thanks.
2020 M2C
2018 M2 LCI
      01-06-2024, 09:28 PM   #5
allinon72
allinon72's Avatar
5838
Drives: 21' M5, 23' X1
Mishimoto. High quality and most stock looking.
      01-06-2024, 09:54 PM   #6
F87source
F87source's Avatar
Drives: Bmw M2
Personally I'm not a fan of the mishimoto charge pipes, they're made of multiple segments welded together rather than bms and ftp which look to be mandrel bent from a single continuous tube. As a result the mishimoto tubes are not perfectly smooth inside and have welds and tube segments that jut up inside of the tube and that doesn't allow air to flow as smoothly.
Credit: https://f80.bimmerpost.com/forums/sh....php?t=1703234
This is what I mean, look at the sections inside not fully lining up, that trips up air flow and makes this pipe flow more turbulently than the bms or ftp pipe. Then the second image shows the example of welds that you get from having to join multiple segments together. Not ideal imo.
      01-06-2024, 10:42 PM   #7
m2zcp
m2zcp's Avatar
Drives: F87 M2 Competition 6M LBB
Eventuri - I have the gloss carbon exclusively sold at IND. Fit and finish is perfect.
https://ind-distribution.com/collect...pipe-set-gloss
      01-06-2024, 11:05 PM   #8
F87source
F87source's Avatar
Drives: Bmw M2
Eventuri charge pipes are supposedly only rated to 24 psi iirc (evolve did say they tested to 145 psi so idk if 24 psi is accurate), and that's pretty low especially since some ots maps can exceed that. So not a great choice especially for the price imo. Charge pipes need to be durable and able to withstand any boost level the engine can and repetitively (carbon can fatigue if not layered strong enough to resist flexing, and idk how thick these pipes are) and the eventuri ones can't if true they are only capable of 24 psi. They look nice but honestly for charge pipes function is way more important than form.
https://f80.bimmerpost.com/forums/sh....php?t=1761232
Next (assuming that the allegations of the eventuri pipes can only hold 24 psi is completely wrong) we have to look at future flexibility for upgrades, the eventuri cp don't appear to have meth bungs sonif you want to run meth or water injection you can't. And finally they're $1k, that's just insane money for a pipe. That alone imo is a deal breaker, especially since they'll offer less features than the competition.
      01-07-2024, 12:12 AM   #9
FaRKle!
Best at what? Not cracking, heat rejection/not heat soaking, ease of maintenance...
Honestly on the stock tune I wouldn't even worry about your charge pipes. They're not a common S55 failure. I wouldn't worry too much about your intercooler either. Just take a look periodically at the seam on its expansion tank for signs of dried coolant as that's a common indicator of a leak.
Appreciate 5
      01-07-2024, 07:15 AM   #10
m2ss
m2ss's Avatar
2607
My wife's just cracked (18 M2 stage 1) and she went into limp mode.
Wasn't sure how prevalent it was on the comp at stock tune so may wait it out until warranty runs out.
Thanks.
2020 M2C
2018 M2 LCI
      01-07-2024, 11:42 AM   #11
mike@x-ph.com
mike@x-ph.com's Avatar
Depends on what you mean by best. The highest quality pipe on the market is the Evolution Racewerks. Their finish quality is second to none and all ER products are handbuilt in the US.
The best value charge pipe is the MAD.
Both will fit and never break. Its a matter of preference and budget on which to get.
https://x-ph.com/sale/
Phone number 725-221-5267
      01-07-2024, 12:56 PM   #12
m2ss
m2ss's Avatar
2607
Thanks.
Price gap is high, other than finish quality why would one choose the ER?
2020 M2C
2018 M2 LCI
      01-07-2024, 02:52 PM   #13
FaRKle!
Thanks.
Luckily you don't really have to worry!
chris7197788.00
      01-07-2024, 03:54 PM   #14
F87source
F87source's Avatar
Drives: Bmw M2
Yup under warranty you don't need to touch anything, let the dealer replace it for free.
      01-07-2024, 05:48 PM   #15
projekt-
Cruisin'
55
Drives: '19 LBB M2C 6MT
Personally, I went BMS charge + j-pipe combo, no complaints.
Oh, just be mindful if you are going to get a different engine cover...because depending on the charge pipe, the fit may vary.
F87source8737.00
      01-07-2024, 06:39 PM   #16
m2ss
m2ss's Avatar
2607
What's the purpose of a different engine cover?
2020 M2C
2018 M2 LCI
      01-07-2024, 06:46 PM   #17
F87source
F87source's Avatar
Drives: Bmw M2
Aesthetics, some people switch to carbon covers.
      01-07-2024, 07:10 PM   #18
m2ss
m2ss's Avatar
2607
Huh, I like the way the engine bay looks stock.
2020 M2C
2018 M2 LCI
      01-08-2024, 05:38 AM   #19
FMOS Racing
Boost All the Things
129
Drives: 2021 M2 Competition MT
From an engineering standpoint, I don't consider the multiple segments in the Mishimoto pipes to be an issue. If we were talking about tuned runners that went directly to the intake valves, then absolutely, but the charge pipe is under pressure and upstream of the massively turbulent intercooler plenum.
Enough BMWs to prove I'm a sadist.
F87source8737.00
mwpa7144.50
      01-08-2024, 09:15 AM   #20
WeekendWarriorz
WeekendWarriorz's Avatar
724
Drives: 2021 M2C
Best chargepipes are going to be any silicone ones. They keep IATs cooler and are less susceptible to heat soak than metal/aluminum.
2006 Z4 M Roadster Black/Imola Red, FBO VF-Engineering, e85 Flex Fuel-Sold
2012 BMW 135i N55 DCT Alpine White/Coral Red, FBO, TBI, Full e85, JB4 BEF-Sold
2006 Z4 M Roadster Black/Black-Sold
2021 M2 Competition DCT Hockenheim Silver
      01-08-2024, 10:19 AM   #21
mike@x-ph.com
Thanks.
Thats pretty much it.
      01-08-2024, 11:14 AM   #22
Info@mad-us.com
Info@mad-us.com's Avatar
4776
Drives: bmw
Thanks.
Other than the finish options anodized vs our powdercoated you wouldn't know the difference once installed except for the $300 bucks still in your pocket.
- Click Here
Performance Parts For Your Bmw At Crazy Low Prices!
5% OFF Code "BimmerPost" Email: info@mad-us.com
