11-30-2023, 04:09 PM | #1 |
Rep 111
Food for thought regarding Mobile One 0-40
I have been running their 0-40 synthetic euro blend on my own out of cycle home oil changes because, well, BMW uses it when they do the free ones.
I am rethinking that and moving over to Liquid Moly going forward. This jives with my Blackstone Oil analysis, the last one was < 1500 miles on the oil but two track days which is my limit. SUS Viscosity @ 210°F 54.4 -- SHOULD BE 55-56 cSt Viscosity @ 100°C 8.59 -- SHOULD BE 8.8 to 12.2 From the report. odometer. The viscosity is a little low for 0W/30 oil, and that's okay. It wasn't thinned by fuel and it didn't bother internal parts based on wear levels. Discuss away. I am an engineer, but not a chem engineer, those guys are the real nerds of our world and I tend to put a lot of faith in their work and findings. |
11-30-2023, 10:12 PM | #2 |
your average JAMF
3191
Rep 4,115
BMW doesn't use Mobil products, their "Twin Power Turbo" BMW-branded oil is made by Castrol.
Mobil 1 0W-40 hasn't carried the BMW LL-01 approval for the past few years, unless that has changed again.
'21 M2 Comp
'19 Golf R |
11-30-2023, 11:12 PM | #3 | |
Rep 6,980
Drives: 2018 M2 AW DCT
Mobile one is not LL-01 approved.
12-01-2023, 11:03 AM | #4 | |
Rep 136
12-02-2023, 04:48 PM | #5 |
Rep 7,340
M1 0W-40 is now API SP licensed and has a very similar additive package to the other SP oils like PP Euro with a split between calcium and magnesium. It's important to note that Lake is a smart guy but I don't think he was correct in his initial assessment if you are talking European 6 and 8 cylinder cars. LSPI is pretty much unheard of on stock N55, S55, Porsche 9A1, etc. I do think the new detergent package is a good idea to just eliminate that risk completely in case you have a sketchy tune or bad gas etc.
I am using this oil now in my S55, seems fine. I like it because it's available and comes in 5 Qt jugs. PP Euro is good too but in stock less often at my local Walmart. BTW - if you find a bottle of M1 0W-40 and it has 6748 stamped on the back label it's the new formulation even if the bottle says SN not SP. |
12-04-2023, 02:14 PM | #6 | |
In the garage
395
Rep 213
Food for thought regarding LSPI (which seems to be the majority of what this video is calling out):
TL;DR: Mobil 1 0W-40's current "recipe" contains a higher calcium level than newer formulas, which is not recommend for Direct Injection (DI) engines due to the potential causal factor of Low Speed Pre-Ignition** **(according to the video) "significant testing"
BMW M2CS 6MT
IG/TikTok: jd_m2d2 |
12-05-2023, 03:08 PM | #7 |
Rep 447
Just had my last free service by BMW today but I plan on switching to PP Euro 5w40 on my next oil change. Though Walmart's $28 for a 5-quart jug of Mobil 1 0w40 is pretty tempting- for some reason I thought I remember seeing edycol preferring Pennzoil/Castrol/Motul to Mobil 1, though I would imagine they all work pretty well.
2020 M2 CS AW 6-spd
Previous M Cars: M2C, M2, F80 M3, E46 M3, Z3M Coupe, E36 M3...and some other fun rides. |
12-07-2023, 09:03 PM | #8 | |
Rep 7,340
In that thread you linked, you can safely ignore CaryTheLabelGuy's post. He doesn't know what he's talking about in this case. LSPI is a very real phenomenon replicated by every major automaker and oil additive formulator. It's not the same as normal knock or pre-ignition, it's usually much worse when it does occur. However, it just doesn't seem to happen with N55/S55. |
12-23-2023, 07:20 PM | #10 | |
Rep 111
12-25-2023, 03:04 PM | #11 |
Rep 7,340
