09-28-2023, 08:40 PM | #1 |
Rep 11
M2 LCI "Turbo" Noise normal?
Hey guys,
Got the m2 last week, and coming from a Golf R I am hearing some interesting wooshing noises. Under any amount of throttle, I am hearing a deep, "exhale" type of woosh that seems to increase with rpm, however, it does not sound like any turbo whistle under load that I have experienced. Even at 2000 rpm on throttle is a exhale type deep woosh, and I am wondering if this could possibly be a vacuum leak somewhere in the intake system? Anybody else have a similar sound? I am used to the high pitched intake and turbo sounds from the golf and dont really have anything to compare this to. |
09-28-2023, 08:44 PM | #2 |
Rep 2,384
Drives: 2018 BMW M2 & 2024 BMW X1 M35i
Video would be your best bet to get a better idea of the sounds. Some sounds are normal. I’ve had MQB VWs as well as the M2 and they all make different noises, more than likely nothing to worry about.
Another question is whether you have any modifications that you are aware of. Upgraded diverted valve or blow off valve would give you more of what you’re describing. An intake would give you more noise as well.
Follow my builds:
The Racecar (2018 M2 - M0010): Build Thread | @_m0010 The Daily (2024 X1 M35i - X001M35):Build Thread | @_x001m35 |
09-28-2023, 09:26 PM | #3 | |
Rep 11
abirmaher843.50 |
09-28-2023, 09:28 PM | #4 |
Rep 2,384
Pretty sure what you’re describing is normal but video will make it easier to be sure. Everything feel smooth? Holding boost? Etc?
Follow my builds:
09-28-2023, 09:48 PM | #5 | |
Rep 11
Thanks! |
09-28-2023, 10:33 PM | #6 | |
Rep 2,384
Follow my builds:
09-28-2023, 11:40 PM | #7 |
Rep 11
Car is a DCT, Im aware the popping/farting on lift off is normal, but Im talking about maybe 1/3 throttle then letting off, the wooshing sound continues and dies down. If I were doing a light throttle pull, this is what the sound would be like lol: woOoOooOOOOOOOOOsSsSshhhhhhhh, but the sound is the same the whole time, just the pitch/intensity changes with rpm. Identical sound on light throttle as there is on a downshift
09-29-2023, 12:40 PM | #9 | |
Rep 11
09-29-2023, 12:45 PM | #10 |
Rep 2,384
Sounds normal to me. The turbo noise seems normal and the higher pitch you are hearing sounds like the differential to me. But both seem normal.
Follow my builds:
09-29-2023, 12:51 PM | #11 |
Rep 11
I can tell what the diff whine is, and the higher pitch sound is associated with the intake system, not the diff. The vid didnt do a great job of getting the woosh on audio, but typically how loud are the stock turbos on these cars? It sounds like a rough wooshing, not a smooth turbo whistle
09-29-2023, 12:53 PM | #12 |
Rep 2,384
Hard to convey. Also tough for me being far from stock for many years. If you’re able to get a better video to point it out I could tell you better.
Follow my builds:
09-29-2023, 02:18 PM | #13 |
Rep 97
You would not hear the turbo with this amount of throttle/in 7th gear, the turbo spools at higher revs/load and even then it's not really something that is very audible from the cabin with windows closed.
09-29-2023, 03:36 PM | #14 |
Rep 11
Its going into the dealer next week, should I ask them to check if there are any vacuum leaks then?
09-29-2023, 04:21 PM | #15 |
Rep 2,384
I would just ask them to drive it and she your concern and have them check it out in that case.
Follow my builds:
09-29-2023, 07:04 PM | #16 |
Rep 1,389
Don't think normal in my experience. Stock turbo is not exactly pronounced on my car, windows down gunning it maybe a little. See what dealer says?
10-05-2023, 10:06 AM | #17 |
Rep 11
Bruh....
The dealer told me that the wooshing boost is normal and that there is no boost leak or anything, and any boost sounds im hearing is because of my dented muffler. Bruh... |
10-05-2023, 11:19 AM | #18 |
Rep 255
