M2 Technical Topics > Cosmetic Maintenance (Wash/Wax/Detailing/Exterior Restoration & Repairs) > does your trunk lid poooooooo?
      09-28-2023, 05:27 PM   #1
Bruuuce
the me
357
Drives: 01ZCoupe, 08M3Coupe, 21M2C
Finally got around to looking into this issue. Appears the trunk is discharging crap onto the rear bumper. Not happy with it and just finally got around to looking into it. I had another M2 and never had this issue.
I ended up using adhesive remover to get it all removed. Ill need to go back and do more detailing...
But what is more concerning is where it appears to be coming from. The little weep hole above the latch. First I thought it might be the latch, but the same material is/was around the weep hole.
I can take the lid apart and see what is under there that is weeping.
Just wondered if anyone else has seen this issue.
01 Z Coupe, 5MT, SB, not much else
08 M3 Coupe, 6MT, JB, not much else
21 M2c Coupe ,DCT, SOM, not much else
      09-28-2023, 05:30 PM   #2
MooMooM2
MooMooM2's Avatar
1845
Drives: M2 Comp
Has not happened to me and have not heard this be a common complaint
      09-28-2023, 07:38 PM   #3
allinon72
allinon72's Avatar
Drives: 20' M2C, 23' X1
It’s likely cosmoline, which is applied at the factory. It melts out in the heat and attracts dirt.
Bruuuce356.50
      09-29-2023, 06:22 AM   #4
Bruuuce
the me
357
allinon72 Interesting, thanks. That may just be it, it's hot here in Atlanta.
Wonder if the Orange vs the Blue makes a difference, or they were just very aggressive with the amount the day the M2 was made.
Hope its done messing up the rear of the M2.
      09-29-2023, 09:56 AM   #5
kthor703
Drives: 2021 M2 Competition
Strange that so much is running out, but normal that some of it is. You will see this in the engine bay/hood area near holes as well.
      10-18-2023, 04:36 PM   #6
Brokenbones
Drives: M2c and S2000
total vandalism... just awful the state of things these days
      10-20-2023, 01:33 PM   #7
stlb5
stlb5's Avatar
227
Drives: '19 M2C MT, '15 X5 Msport
My 235 did the same thing. Thought about plugging it, but afraid of water build up. So, I just made it part of my washing routine. I put some APC on a rolled up shop towel and wiggle it around up there. I keep my BSM really clean and this was certainly a sore point for me.
2019 M2 Comp, MT, BSM
2015 X5 Msport, CB (Hers)
2014 M235i MT, BSM, MPE, Dinan Springs (Sold)
      11-05-2023, 11:23 PM   #8
loshy
I thought I was the only one dealing with this issue. Hmm. Mine builds up in the same spot too.
