06-18-2023, 07:38 AM | #1 |
Rep 2,091
Differential output shaft leak
Was working on my exhaust yesterday and noticed my passenger side output shaft seal is seeping on my differential (17 OG M2). Anyone DIY this? I can't seem to find any DIYs on the f87 or f80/f82 forums.
Thanks!
MGM F82 M4 DCT / MPerformance / Swift / CSF / IND / Turner / BimmerWorld
BSM F87 M2 6MT / Fabspeed / MPerformance / Turner / AutoID - SOLD JB-NB E92 M3 6MT / IND / RTD / Alpine / KW / ActiveAutowerke / 360Carbon - SOLD SS2-FR E90 M3 6MT / IND / AFE / ActiveAutowerke - SOLD AW-FR E90 M3 DCT / ACM / IND / AutoTecknic / K&N / H&R / Bilstein - SOLD |
06-18-2023, 06:35 PM | #2 |
Rep 422
Drives: F87 M2 DCT, F15 X5
After removing the CVJ shaft, you’ll pry out the old seal. Be very careful not to damage the seal bore in the axle or the seal journal on the CVJ stub shaft. Clean up the bore, and use a tool that will evenly press the new seal back in.
‘18 F87 M2 DCT
'17 F15 X5 xDrive35i M-Sport Sold in 2023 '12 F30 335i 8AT Sport Line Sold in 2020 '08 E92 335xi 6MT Sold in 2016 '08 E90 335i 6MT - FBO |
06-18-2023, 06:57 PM | #3 | |
Rep 2,091
Will try and find the proper tool to install the new seal.
06-19-2023, 07:21 AM | #4 | |
Rep 1,334
chris7197334.00 |
06-19-2023, 08:45 AM | #5 | |
Rep 2,091
Perfect, thank you so much! So unbolt those arms there and unbolt the axle from the differential only right? You left it attached to the wheel bearing/hub? And left the brakes in place?
06-19-2023, 01:30 PM | #6 |
Rep 1,334
Drifter2090909.50 |
06-19-2023, 01:32 PM | #7 |
Rep 2,091
06-19-2023, 02:49 PM | #8 |
Rep 1,334
06-19-2023, 09:28 PM | #9 |
Rep 2,091
06-19-2023, 11:46 PM | #10 |
Rep 1,334
06-20-2023, 05:05 AM | #11 |
Rep 422
Is there any pry locations on this? Last time I designed a CVJ interface I put pry taps on it so service can get a pry bar on either size to over come the snap ring pull out force.
‘18 F87 M2 DCT
06-20-2023, 07:50 AM | #12 | |
Rep 2,091
Thanks again |
