08-21-2022, 09:43 AM | #1 |
Rep 1,657
Missed my M2 CSR had a M2 CS. Why not make a Hybrid?
After selling the m2 CSR I decided to make a hybrid street / track M2 CS. Not great at either track or street but as good as a hybrid as I could design.
First up the seat / brackets setup. This seating position is proper for a hybrid. Lowers you about 2”. Not as low as the CSR but also safer on the streets. Saves about 100 lbs. I need to weigh. Add some manual Team Schirmer seat brackets and the seats are done. These seats fit 36” plus waist and have already done 200 mile road trip and happy to report they are perfectly comfortable. A couple of quick pics for now.
1995 LTW: Modified by BMW NA Factory team from new
M2 CS: CF Buckets & more (track toy) |
9
RideM317.00 Hedoniste3883.50 F87EVO4062.50 M3R12218.00 Wah2780.00 prompt292.00 MadBimmeRad7124.50 Rumbloki177.50 Thefog_M2CS91.50 |
08-21-2022, 12:59 PM | #3 |
Rep 117
Love the seats! This is something I wish BMW did from the factory. I have no idea why the engineers decided to remove the armrest and comfort access but keep power seats. Manual seats are much easier to move back and forth to get in/out of the car and they weigh LESS. 🤔
prompt292.00 |
08-21-2022, 02:03 PM | #4 | |
Rep 1,657
I'll have to check but maybe the seating position is now low enough to use the alcantera center console as an arm rest. The only thing that bothers me about the car now is the lack of comfort access. But as for the seating position it reminds me of our tourings now. I think yours has buckets no?
frostyrides311.00 |
08-21-2022, 02:06 PM | #5 |
Rep 1,657
They are a perfect match from materials to stitching to size and the best part about it, they are factory Sparco.
08-21-2022, 02:35 PM | #6 |
Rep 908
Drives: 2018 M3 Competition
Looks great and the weight savings makes a lot of sense also. I could definitely do without the power seats.
Did you just make the car a 2 seater or can passengers still get in the back? |
08-21-2022, 02:40 PM | #7 | |
Rep 1,657
More pics and info about the other mods to come
08-22-2022, 11:34 AM | #8 | |
Rep 280
One of the items I had pending was the bucket seats. I was incline to order the Recaro Podiums (expensive but they seem amazing). Which seats have you put in? Is the upholstery custom? Do you need to reprogram the car for a faulty code since the stock seats were removed? Lastly do you have pics of the cage install? Thank you, A |
08-22-2022, 08:20 PM | #9 |
Rep 4,733
New seats save roughly 90lbs, exhaust 40lbs, rear seat 30lbs. Add Li battery would be another 25lbs. CSR front brakes saves another 20lbs iirc. These are approximate. Rear seat might be closer to 50lbs, but I can't remember.
That adds up quick. ~200lbs. Easy to see why the CSL cars start going way up in price. The parts to get there start going way up in cost. |
Davil6601.50 |
08-22-2022, 08:54 PM | #10 |
Rep 3,102
Drives: 21 Vantage, 18 Vantage, 00 WRX
Probably a lot more than that. I just put a Deadweight industries battery in the Aston and that saved nearly 50lbs. All in the middle in that car as the battery is in the parcel shelf behind the seats. I know replacing an e92 battery with a deadweight industries battery saves 55lbs so I reckon it would be pretty similar on the CS.
08-22-2022, 08:58 PM | #11 | |
Rep 1,657
I went with Sparco CF buckets with manufacturer red stitching. Leather and Alcantara. I'm in the uphostery business and know getting something custom done is A expensive and B usually never comes out quite like the manufacturer. $2200 per seat IIRC. The seating position alone is a big upgrade, not to mention the other benefits. The Schirmer brackets ARE NOT PLUG AND PLAY. You need to drill a few holes here and there and minipulate them to get the sliders to work. Glad to see someone else is doing the same thing to their CS. This is exactly what was done to E30 M3's and LTW's back in the day. Heck, a lot of people even turned their LTW's into race cars. Doubt anyone would do that to a CS these days, how times have changed. I went with the Competition Motorsports bar. It's nice but I like the Schirmer design way better but didn't want to import one. I probably should have waited but I digress. Lifeline harnesses are so good. More pics to come.
aparedes302.00 |
08-22-2022, 09:01 PM | #12 | |
Rep 1,657
08-22-2022, 09:07 PM | #13 | |
Rep 1,657
I did add a roll bar so that was probably 40-50 lbs I never weigh anything, I'm so dumb.
chris7197393.50 |
08-22-2022, 09:14 PM | #14 | |
Rep 3,102
Good FAQ here. https://deadweightindustries.com.au/...uld-you-choose |
08-23-2022, 08:51 AM | #15 | |
Rep 4,733
08-23-2022, 09:02 AM | #16 | |
Rep 4,733
08-23-2022, 09:12 AM | #17 |
Rep 142
Correct Li Battery Charge Coding ?
Hi Davil
Can we properly code the Li Battery Charging sequence in the F87 Cs chassis ? Cheers Bruce |
08-23-2022, 01:59 PM | #18 |
Rep 4,733
@ptdltw Those carbon buckets on sliders. If slid all the way forward is there still reasonable access to the back seats for passengers. I like those seats, but loading kids is a higher priority for me.
08-23-2022, 02:05 PM | #19 | |
Rep 1,657
However you could do Bucket for the driver Let them in and out via passenger side. Accidents could be a problem if they could only exit one side.
08-23-2022, 02:06 PM | #20 | |
Rep 1,657
I wanted a piece of Schirmer in the car. Manual sliders work great let me check clearence for passengers. Update: Wow they slide up far enough where I can barely get out, this leaves 13" from the bolster to the b pillar. Not enough for anyone to safely crawl in and out. You're just going to have to buy another M2 CS and modify it. Keep yours for the street.
M2 CS: CF Buckets & more (track toy) Last edited by ptgltw; 08-23-2022 at 02:12 PM.. |
imperfectluck434.00 |
08-23-2022, 02:21 PM | #22 |
Rep 613
Drives: F87 M2 CS
Admittedly, I never knew an M2 CSR existed until finding this thread.
Current: F87 M2CS - 6MT | Öhlins R&T | Garagistic Endlinks | Autosolutions SSK | AA EL Midpipe & Axleback | 255/275 PS4S
Gone: F87 M2C - 6MT | Öhlins R&T | G.C. Camber Plates | Autosolutions SSK | UCP | AA EL Midpipe & Axleback | Apex EC-7 | 265/295 PS4S Last edited by DadVibes; 08-24-2022 at 03:41 PM.. |
