08-03-2022, 10:32 PM | #1 |
Rep 8
2021 M340i Femto torque limitation issue?
Hey everyone, I currently have an 2021 M340i femto unlocked tuned, xHP tune stage 3, catless DP, AWE track exhaust, and MST intake. For some reason, my car won't make more power past the stage 1 tune. Every time my tuner "cranks up" the tune in a new version I only make stock power to maybe a 5-10hp increase, while stage one is pushing numbers attached. I also get these two codes popping up in every tune version:
Active -180001 - Catalytic converter: Efficiency below limit value. Shadow -10D000 - Combustion engine: Torque limitation active. Any ideas on what may be causing the power loss? |
08-04-2022, 02:01 AM | #2 | |
Rep 243
08-05-2022, 02:38 AM | #3 |
Rep 240
https://g20.bimmerpost.com/forums/sh....php?t=1937745
^ This guy is also having the same issue on another thread. Probably has something to do with the Mild Hybrid system my two cents. |
08-05-2022, 07:16 AM | #4 | |
Rep 8
09-22-2023, 02:26 PM | #8 |
B58 Power
496
Rep 631
Drives: 05/2022 M340i xDrive Touring
Yes.
Either get the MHD custom ROM for the torque limit removal or install xHP. The issue has been fixed some time ago. Note that the MHD custom ROM has a problem with the Launch Control and it doesn´t work anymore.
05/2022: BMW G21 ///M340i xDrive Touring - Individual Verde Ermes
dancing__narwhal141.50 |
12-06-2023, 06:25 PM | #10 | |
Rep 72
Drives: BMW 335i
I just installed MHD in a 2021 m340i xdrive (femto unlocked) and after one launch control, we're unable to do another one. Before that the car had ECU and TCU Stage 2 flash from Madness (idk if it was Madness Motorsport, Madness Tuning or what). What would be happening here? I need to reflash the previous TCU tune? I need XHP mandatory? |
12-21-2023, 04:17 AM | #11 | |
B58 Power
496
Rep 631
That´s why you need xHP and have it installed before installing MHD. I installed xHP Stage 2 on saturday, did my 100km drive and then flashed MHD Stage 1. Until now it´s running fine but i couldn´t do a proper log, because it´s raining since sunday...
