M2 Technical Topics > N55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > Bimmercode HeadUnit
      03-05-2022, 12:16 AM   #1
scadagawd
scadagawd's Avatar
62
Drives: BMW M2 2018
Bimmercode HeadUnit
Just got an s/w update to my 2018 M2 to fix an issue with an ABS recall issue. All my coding is gone. I got most of it back with Bimmercode however seems like the HeadUnit section is greyed out. Is this a Bimmercode issue or an updated s/w issue? I did update the data for the Bimmercode app. Any thoughts would be appreciated.
V.
BMW M2 2018 LBB
BMW X1 2016 PSM
Audi S4 2014 SMG
      03-06-2022, 02:58 PM   #2
dtmurf
dtmurf's Avatar
532
1996 BMW 318is  [4.75]
2012 Audi Q5  [4.50]
2017 BMW M2  [10.00]
After I had full screen Apple Carplay coded, I lost the ability to code the head unit with Bimmercode. kubax86 said it was a problem with Bimmercode...not much help but maybe useful.
'17 M2 DCT Long Beach Blue
      03-06-2022, 06:23 PM   #3
samsamdar
samsamdar's Avatar
Drives: OG M2
2018 BMW M2  [7.50]
Yeah if the NBT has been modified from factory settings (like with a CarPlay retrofit), you won't be able to use BimmerCode to modify it.
      03-06-2022, 06:25 PM   #4
Tag
This is the way.
Tag's Avatar
23010
Drives: N-1 starfighter
You can restore the very first backup that BimmerCode created which will reset everything back to their stock settings. Then see if you can code again afterwards.
Check the 'Backups' section for more info.
https://www.bimmercode.app/support/
      07-06-2022, 08:37 AM   #5
LoganBryce
Scotland
I'm the same - had CarPlay retro fitted and Bimmercode stopped working for my Headunit. I now use esys for all my headunit coding and works fine.
///M TOWN35366.50
      07-06-2022, 12:11 PM   #6
magha
magha's Avatar
94
Drives: '18 M2 AW 6 spd
V.
You can code full screen straight through bimmercode now with the update. Assuming u had CarPlay to begin with
Headunit > expert mode > 3000 MI
CAR PLAY FULLSCREEN set to Aktiv
Just saw u can let access it but I'll leave the instructions in there in case it works fornl others
18 M2 6 Spd AW - VRSF DP / CP & Race FMIC, ER TIC & GFB DV+ with BM3 Stage 2
Retired 09 135 JB4 G5 ISO w/BEF, N54 Tuning Performance DPs, BMS DCI, ER Charge Pipe
      07-06-2022, 06:39 PM   #7
gphung
202
Drives: 2018 M2 LBB - 6MT
2018 BMW M2  [0.00]
You need to update the Bimmercode app. If it's already up to date, send a support request and let them know. They'll send you a beta invite with the fix, and eventually release it to the App Store as well. I went through the same thing after doing the ABS light recall programming.
