12-23-2021, 08:46 AM | #1 |
Rep 1,200
Amazing Brake Coding Fix/Review - daap1193
So I recently contacted daap1193 aka David about his recent findings with fixing the overboosted/overreactive brakes and I'm happy to say that he did a phenomenal job!
I had noticed this for a while on my M2C where the braking behavior was inconsistent; there would be times when transitioning off throttle and quickly applying brake where the brake was fully loaded up already and pressing <20% into the brake pedal travel would apply way more brake than was normal or typical of 20% pedal position. It wasn't the biggest priority for me at the time of noticing this but it was a behavior I did not love. I had also noticed this inconsistent behavior on the road course the first week owning my M2C. The car always stopped or slowed but the inconsistent feel was annoying to say the least as I did not know how the behavior was calibrated or how to repeat it consistently. Fast forward to learning more about it from daap1193 and feedback from others who had him do the coding on his brakes and I wish I had found him sooner. To summarize the main differences: "You will feel a harder and more consistent brake pedal feel, less ABS intervention which completely eliminates the on/off-like sensation all of this translates into better braking on track and a more race car brake feel." While I didn't necessarily notice a harder pedal...it was definitely consistent and allowed proper threshold braking to which inadvertent ABS intervention never happened. Otherwise the brakes felt absolutely perfect to me now. David also took the time to write me a detailed paper about what the changes are...basically he modifies the "Dynamic Brake Control", "Brake stand by (EVB)" and adjustment to the brake pedal assistance function. Secondly for Non-M cars, there are a couple other functions disabled *(as they are on M cars by default)* So at the end of the day if you don't like an over-assisted brake pedal and you want a proper/linear brake then I highly suggest you contact David daap1193. He sent me all the files I needed to download and remoted into my car. The process took about 5min and there was not a single issue. I highly recommend it for those that are looking for the benefits described above.
575RWHP F87 M2C - ECUTEK RACEROM with flex fuel tuning by Bend Calibration 1000+RWHP E46 M3, Lab22 Built Turbo S54, Bend Calibration Tuned - BMW Half Mile Record Holder |
12-23-2021, 09:34 AM | #2 |
Rep 485
I second this! Wish I had done this sooner. David is a great guy!
I used to experience side to side wiggle while threshold braking and David's coding paired with m4 GTS steering helped a lot! I would guess at least 75% better than before! Along with all the added benefits commander pointed out above! Can't say enough good about David and his brake magic! |
Commanderwiggin2050.00 daap1193172.00 |
12-23-2021, 05:35 PM | #4 | |
Rep 7,422
I also believe it was disscussed here for those with esys and want to do it themselves: https://f87.bimmerpost.com/forums/sh....php?t=1781115 and on this German forum: https://www.trackdayforum.com/index....#comment-26122 The function for the brake preloading as soon as you rapidly lift off the accelerator and responsible for the irratic braking is: C_Ffunktion_Bremsbereitschaft_aktiv_I Deactivating this via esys should pretty much eliminate this issue. There are other things you can modify as well which is discussed in this thread. But for those that don't have esys or don't want to tinker with it then it would be easier to contact someone who can do it like Daap.
https://f87.bimmerpost.com/forums/sh...2#post30368242 Last edited by F87source; 12-23-2021 at 07:09 PM.. |
12-23-2021, 06:06 PM | #5 |
Rep 485
12-23-2021, 06:56 PM | #6 |
Rep 1,200
You have a Merry Christmas as well good sir...also if you look at my post history that will help you out with whatever you want to call me.
12-23-2021, 11:47 PM | #7 | |
Rep 485
I was super thrilled when this helped like it did! |
12-24-2021, 02:04 PM | #8 |
Rep 739
I will definitely try this! Here at our local road course, I get a typical soft but predictable pedal through most turns, but through others like turn 11 (downhill 160 degree right hander), I get this unexpected and very firm pedal, which means I end up braking way too early.
I'm running Ferodo 2500 DS pads with titanium shims, SS lines, and Castrol SRF. Should I expect pedal feel closer to the extreme end of firmness, or somewhere in between? Thanks! Edit: for clarity, I've bled the system at the dealer every 6 months and replace fluid annually. It's always been like this. |
12-24-2021, 02:39 PM | #9 |
Rep 70
Thanks Commanderwiggin for the review, it's great to see how all the time and effort invested to improve the platform was worth it. If more people it's interested don't hesitate to ask or PM for more information, for the time I'm including gts steering and diff coding at no extra cost when you get your brakes coded, this car more enjoyable on track.
Wish all forum members a happy Christmas. |
4
12-24-2021, 05:19 PM | #10 |
Rep 488
I guess I'm a fan boy as well.
Just had mine done and took it for a drive around the hood. Everything felt great. My complaint about braking on the track felt inconsistent. I thought it was me but after 7 track days I realize it's not just me. Looking forward to the next event where I can test the changes out on the track. |
02-19-2022, 07:01 PM | #12 |
M2 From Down Under
85
Rep 33
Just a quick review on Daap1193's brake coding. I have been using his coding for the last 3 to 4 months and it has been pivotal in my ability to fully utilise my brakes. I run ap racing front and rear calipers. Prior to the coding, they were unpredictable and hard to modulate.
Post coding, the braking feels consistent with the same feeling everytime. I am able to modulate the pedal and enabled me to brake much later and suddenly with full confidence whereas previously I would just hit abs randomly. Whilst it greatly helps anyone with a bbk. This coding will also benefit stock brakes once you are really pushing hard on the track. Highly recommend David to all. He has excellent customer service and is very prompt in responding. He takes his time to ensure everything is done correctly whilst also explaining it in simple terms so that I could understand what was being changed. Would never go back to stock brake coding after this. |
4
05-08-2022, 04:39 PM | #15 |
Rep 70
Thanks to all the members for the support, now more than 100 cars coded with no other than positive reviews, last week I was working on a G20 M340ix and an G80 M3 in order to develop the coding for the newer G series platform, found out some interesting data, the new G80 M3 came from factory with the same coding I develop for the F8X, but base cars such as the G20 don`t, seems that BMW finally understood that M cars must be more analog and enjoyable, this also mean that my coding is worth a must on all M cars.
Commanderwiggin can´t demonstrate enough appreciation for your help. Will be traveling next week to Miami if some locals are interested. |
Commanderwiggin2050.00 sly1types431.50 |
05-21-2022, 07:14 PM | #18 |
This hobby is expensive!
132
Rep 72
Another satisfied track driver...
I had daap1193 code my M2C in December 2021 after taking ownership in April 2021. I went to a few tracks while 100% stock so I can make informed value added decisions before I made any changes to the car. Like others, I noticed a nervous and inconsistent braking experience under heavy deceleration. Particularly after VIR's long back straight...
He remote'd into my laptop and after some troubleshooting, proceeded to make the coding changes. He was very patient and thorough. Quick notes: don't use a Mac with VMWare or Bootcamp; we had problems. Windows 11 worked better. Results: There was no change in street driving at all due to this change, so I was only able to test it this past weekend in May 2022 at Palmer Motorsport (clockwise) in Massachusetts while I shook down the car overall. With a lot of other changes made over the past Winter, I was overall impressed, but completely forgot about the brake coding! Which means it felt really good and intuitive- not a point that I needed to address. I'm using stock rotors, race pads (front and rear) on the track. It's a highly recommended change for those really working to get the most from their braking zones. |
chris7197334.00 |
06-10-2022, 01:23 AM | #20 |
Rep 447
I always wondered about the pre-load of the brakes when coming off the throttle, nice to know there is a solution.
2020 M2 CS AW 6-spd
Previous M Cars: M2C, M2, F80 M3, E46 M3, Z3M Coupe, E36 M3...and some other fun rides. |
06-10-2022, 05:26 PM | #21 |
Rep 70
06-10-2022, 05:33 PM | #22 |
Rep 7,422
He only has 3 posts, he needs to post more (I think 10 posts) to enable pm'ing.
