BMW 3-Series (E90 E92) Forum
E90 window trim drip trim removal?
09-11-2021, 08:39 AM | #1 |
Rep 346
Hi, just replaced one of my doors and on this door it has a black rubber trim. On my car it has a metal silver/chrome one so i am trying to take the black rubber off to put the silver/chrome one back on to match the rest of the car.
How do you take it off? When I am trying to take it off it just breaks. It seems really fragile and I noticed corrosion below and I the black rubber seems like it’s almost welded it self to the metal/corrosion |
09-11-2021, 03:23 PM | #3 |
Rep 4,324
Pry up on the backside of it from the door panel.
That silver trim is a nightmare to snap into place on its rubber strip. Should’ve pulled that off as 1 whole piece.
E90 335i-408WHP. Alpine over Terra brown
E70 X5 35i M Sport-Stage1 Tune. Alpine over Black E91 328 M Sport-Alpine over Black-Alpine over Saddle brown. E93 335i-DINAN tuned. Alpine over Saddle brown |
09-11-2021, 04:00 PM | #4 | |
Rep 346
Were you explaining how to take the black rubber trim off the new door I have put on the car? The first 3 pics show the new door with the black trim which I can’t figure out how to get off and looks ruined. The 4th pic shows the track left on the old door from where I removed the chrome/silver top piece And the 5th pic just shows another door with the chrome/silver trim |
09-11-2021, 08:49 PM | #5 |
Rep 4,324
Yes I’m explaining how to get the old trim off
From the inside of the door, (with door panel off) pry up on the bottom of the seal. Hard to explain. Post a photo of the back of the door. Also, try to put the silver trim on the black seal first before installing
09-12-2021, 01:38 AM | #6 | |
Rep 346
So put the silver trim back on the window which has the track left in and then take off as one piece? Or take the trim track out of the old window, put the silver trim and track together and then install? Here are the pics |
09-12-2021, 05:09 AM | #7 |
Rep 4,324
You can try to put the silver trim back on with the black strip installed on the old door.
I had a hard time when I did that. To remove either black strip. Remove the inner window strip (strip above door panel clips) And use a wide pry tool to lift it up. A flat head will work, but high chances of bending the strip you’re reusing. The tip of the pry tool will sit under the exterior seal and the body of the pry tool should sit on the door frame (where the inner seal is) and that’s how you’ll pry it up. On the all black seal, just rip it off. It’s no good. On the seal you’re re using, pry/lift it a little at a time in different areas so it doesn’t bend as much.
09-12-2021, 06:42 AM | #8 | |
Rep 346
I have managed to get the black rubber trim off and put the chrome trim back on the new door. Another question if you can help with this lol; I need to lower the window on the old door to be able to lift off the silver trim and track. Now, it’s not plugged in so I have no power. I do have a 12v power supply and the regulator/motor plug is accessible. Do you know which pins I can apply power to, to put the window down? Or know how I may find this out? Thanks Last edited by Processing61; 09-12-2021 at 06:47 AM.. |
09-12-2021, 07:26 AM | #9 |
Rep 346
Got there in the end. I used the old loom to power the other window. The only thing is on one end the little rubber retaining bit has snapped off but apart from that, all good!
Thanks |
