08-26-2021, 08:02 PM | #1 |
Rep 336
Rattle on right side - 1/12/24 Update: BMW SIB 51 14 18
I know this has been mentioned previously, but I sometimes hear a rattle from the right side when I drive over bumps. I recall people mentioning glove box fastener, windshield/A-pillar, or other possibilities. I'd like to draft an email to my service advisor, and, assuming it's true, let him know it's a known issue that BMW has solved. Before I contact him, Can anyone share evidence of a service bulletin, the possible culprit(s), and an actual successful fix? Thank you in advance!
1/12/24 Update: BMW Technical Service Bulletin SIB 51 14 18 performed by dealer. Part 51-13-8-209-642 installed. Technician’s Notes: “Road tested vehicle and checked for noise coming from passenger door. Duplicated customer concern. As per SIB 51 14 18 performed procedure. R&I passenger door vapor barrier and installed dampening foam on passenger door. Checked functionality of all door functions and rechecked for noise. Noise is no longer present after repair.” |
08-31-2021, 09:07 AM | #4 |
Rep 51
I’ve been hearing a rattle as well on the passengers side coming from the cabin, but it’s the passenger seat belt hitting the pillar. Not sure what to do about that.
08-31-2021, 10:31 AM | #5 | |
Rep 241
I have a small plastic on plastic creaking sound from the passenger side as well, but for me it sounds like its the door trims rubbing between each other. Pressure on the door trims makes it go away. I can't drive with my arm pushing on the door trim constantly, so its been a minor annoyance. Turning up the music pretty much solves it lol. |
08-31-2021, 10:35 AM | #6 | |
Rep 2,327
Present: 2023 M2 BSM W/Carbon everything, 6 Speed
Past:2020 M2C HS Executive, 6 Speed |
09-01-2021, 06:56 PM | #7 | |
1137
Rep 662
ADDONE231.50 |
01-14-2024, 08:52 AM | #8 | |
Rep 336
chris7197392.00 |
