07-31-2021, 02:43 AM | #3 |
your average JAMF
3088
Rep 4,089
I used BimmerCode, it works too. When I bought it I wasn't even aware there was a BimmerLink and still don't fully understand the differences.
'21 M2 Comp
'19 Golf R |
07-31-2021, 03:18 AM | #4 |
Rep 214
07-31-2021, 04:06 AM | #5 |
Rep 831
BimmerCode is for all the features (seats, lights, windows, etc) and BimmerLink is more for diagnostics (battery registration, clearing faults, pulling trouble codes, etc.).
They just just happen to overlap with the ASD feature but only BimmerLink can code out burbles and open/close valves. |
07-31-2021, 04:09 AM | #6 | |
Rep 214
07-31-2021, 09:32 AM | #7 |
Rep 831
Pretty much.
Also confirming that the valve open option on BimmerLink is temporary, 10 minutes at best before the valve operation reverts back to factory settings. The app needs to be running with your phone for the valve setting to be remembered. Weird because the burble aka "sound tuning" settings are saved and the app doesn't need to run. |
Nicname351.00 |
07-31-2021, 10:54 AM | #8 | |
Rep 380
(K)1254.00 |
08-01-2021, 12:26 PM | #9 |
Rep 339
Drives: 2020 M2, 6MT
I used bimmercode to turn off ASD and bimmerlink to turn off the burbles (sound tuning). Once you have turned off the burbles with bimmerlink, you don't need to be connected to the app with the obd hooked up. However if you use bimmerlink to turn off asd, it will not remember that setting unless you remain plugged in to the obd with the app running.
stefan2349.50 |
08-01-2021, 12:51 PM | #10 | |
Rep 380
Edit - Never mind me. You are correct, ASD Is NOT persistent with BimmerLink. I just checked and mine is off because I have it off with BimmerCode. So you need BimmerLink to turn off the burbles and BimmerCode to turn off ASD for good. Sorry about that. |
Capt Canuck704.00 rns2947.50 |
08-01-2021, 05:41 PM | #11 |
Rep 380
This is one reason I just got both.
04-28-2022, 06:44 AM | #13 | |
Rep 126
Reason being I believe the previous owner disabled it, but i’m unsure how (bimmerlink, bimmercode, etc….) I verified and there’s no physical harness. |
05-07-2022, 09:37 PM | #15 |
Rep 873
Nope
2019 m2c 6MT C33/29U/MDOE/4MC/ZEC/Z4G/Z09/AA mid/Remus Axle-back Race/Carbahn Stage 1
2014 B8.5 s4 6MT Monsoon Gray Metallic/Black Optics/RS Grille/GIAC Stage 1/AWE Touring Exhaust & S-Flo Intake/H&R Sway Bars/Bilstein PSS10 |
WordOnRoad313.00 |
05-17-2022, 12:54 PM | #16 |
Rep 659
Any dealer that gives you a hard time about warranty after coding out ASD or adding comfort fold on your mirrors is garbage.
Winter: 13 PGM 3.5 E70|MHD
Summer: 15 6MT BSM F80|MHD|KW|SM-10 Gone: 09 AWD 6MT AW E90|FBO|MHD|XHP|KW|ARC-8 IG: 475_f80 |
05-17-2022, 01:32 PM | #17 |
Rep 241
