07-26-2021, 07:17 AM | #1 |
Rep 1,389
Quick Q is my Chargepipe located properly picture
Have no boost leak errors on DME codes or performance problems or weird noises. You can see that there is a wedge shape between the end of the CP connector and the 'flange' area of the intake manifold area. It seems to have come to rest in this position anyone else got similar or should I worry about it? Thanks |
07-26-2021, 08:51 AM | #2 |
Rep 1,899
As long as the c clip is fully locked in then yes it's normal. By design it has to have a bit of wiggle room. If you want to be thorough just push the charge pipe into the throttle as far as it'll go
07-26-2021, 08:54 AM | #3 |
mTekMods
2157
Rep 2,909
no its not, it needs to be flush against the throttle body.
2011 Frozen Black/Fox Red E90 M3 650+WHP
G-Power Supercharged First DCT to Manual Conversion Worldwide KW CS, BBS RI-A, BW Headers, Snow 2.5 |
07-26-2021, 11:48 AM | #4 |
Rep 1,644
Not true. The instructions for all metal charge pipes say there will be a tiny gap to account for metal expansion. As long as the clip is properly seated in the TB slot and the pipe can't be pulled off it's fitting as intended.
07-27-2021, 01:46 AM | #6 | |
Rep 7,470
Like others have said if the C-clip is fully seated that is perfect as the small gap is just for wiggle room and the O-ring inside is responsible for doing the sealing.
07-28-2021, 10:46 AM | #7 |
Rep 1,389
Thanks guys, I'm not going to touch it then. My garage aren't muppets and will have clipped it in properly when installing it, just wasn't sure if it had moved and should be flush.
Car is in rude health |
