07-08-2021, 05:13 PM | #3 |
Rep 433
Viscosity is on the low side for a W40, but somewhat expected
ZDDP is also a little low (presumably for SP rating?) What surprised me the most are the low flash points of 435F in my sample and 430F in the earlier sample I thought these GTL based oils would do better in this regard Are the low flash points an area of concern? |
07-08-2021, 08:14 PM | #4 | |
Rep 1,483
This is basically W30 oil. It is Porsche A40 approved which means it can take track abuse. That says it is stout package regardless pf flash point. IMO this is best choice for people with N20/26 engines as it has low Zinc. But for M vehicles or N/S 55 engines, there are better choices. |
2020M2Competition429.00 F87source7239.50 |
07-09-2021, 06:54 AM | #5 | ||
Rep 1,644
07-09-2021, 07:24 AM | #6 | |||
Rep 1,483
But PPE is exceptional oil, don't doubt it. Always keep in mind that oils with all these approvals have to go through most stringent testing in industry. |
07-10-2021, 11:09 AM | #10 |
Rep 1,483
07-10-2021, 11:26 AM | #11 |
844
Rep 1,962
07-10-2021, 11:49 AM | #12 | |
Rep 1,483
40 is KV100 range! 12.5 to 16.4cst! 5W is flow at certain temperature (in the case of 5W it is tested at -30c). Oil can be on various spectrum of W40 range. Redline 5W40 is 15.6cst at 100c (it would be called "heavy" W40 oil). As we see this PPE is at the bottom of the range. So, please be my guest. |
07-10-2021, 12:52 PM | #13 |
844
Rep 1,962
I'm mostly looking here:
https://www.castrol.com/en_gb/united...ty-grades.html But, sensing that you've feeling a little defensive, try to chill and remember it was not intended as an attack of your competence, intellect, expertise in the subject, inside leg measurement, IQ, size of your bits, whether you are any good with them, or what type of handbag you prefer. Yes? |
07-10-2021, 01:50 PM | #15 | |
Rep 1,483
07-12-2021, 06:13 AM | #17 |
Rep 1,644
