| 07-07-2021, 01:45 AM | #1 | |
![]() 4767
Rep 3,914
Front Sway Bar Install Guide
Like a few others here, I ordered an M2 CS Racing front sway bar and got around to installing it this past weekend. It's still amusing to me that the CSR front sway bar is cheaper than pretty much any aftermarket bar, and it really does seem to be the same as the H&R 30mm F8x front sway bar. Doing a front sway bar install is pretty easy on the M2/3/4 since the bar is mounted under the subframe, unlike on the regular 2/3/4 where you have to drop the front subframe because the bar is on top of it.
AlpinewhiteM2C149.00 bentom2347.00 M2guru661.00 tenkies165.00 ewohar21.50 thegrinchboy83.00 chris7197791.00 |
| 05-29-2022, 12:00 PM | #3 |
862
Rep 1,957
For even greater cost savings, it's possible to buy a used M3/M4 front bar from a breakers, as it's the same part as the CS.
![]() Edit: Actually no. The CS uses the M4 front sway bar - the CSR uses something else. Farkle, now you've had it on the car for a few months, what changes have you noticed in the handling? Last edited by M Fifty; 05-30-2022 at 11:44 AM.. |
| 05-31-2022, 11:31 PM | #6 | ||
![]() 4767
Rep 3,914
I wish that were the case!
| 06-01-2022, 06:41 AM | #7 |
862
Rep 1,957
Well, BMW appear to offer three springs for the front of the M2 CSR, so how do they relate to the rates of the ones you've fitted? Part numbers below:
31308416815 - 140-60-180 31337766685 - 140-60-200 31308431823 - 140-60-220 Which number is the spring rate is an interesting one as 140 works out as 800 lbs/in, 60 is 340lbs/in while 180-220 comes in at 1020 lbs/in to 1250 lbs/in. Stock spring rates are 218 lbs/in Last edited by M Fifty; 06-01-2022 at 07:00 AM.. Reason: Now with added Technobabble |
FTP2038.00 |
| 06-01-2022, 09:53 AM | #8 | |
![]() 201
Rep 199
140mm free lenght, 60mm inner diameter, 180-220 N/mm spring rate Nitron R1 uses front 140 N/mm softer, 160 N/mm harder setup for stock M2 Comp weight. KW Clubsport uses 70 N/mm for stock M2 Comp weight. My AST 5300 uses 130 N/mm front for stock M2 Comp weight. Are there also rear spring rates? I know there is real coilover but that is the same with Nitron and AST which I have. And to your question, for street 70-100 N/mm, for track 130-160 N/mm…. That's what I would fit there, but you need also right damper for that spring rates. ![]()
2009-2011 E90 320si street/track car - SOLD ; 2010-2016 E92 330d LCI street car - SOLD ; 2016-2018 F30 335d LCI street car - SOLD ; 2011-2021 E46 M3 track car - SOLD
2018-2024 F87 M2 Competition street/track car - SOLD ; 2021-???? 1986 E28 M535i show car ; 2025-???? G87 M2 street/track car My Instagram ![]() |
| 06-01-2022, 12:44 PM | #9 |
862
Rep 1,957
There appear to be 6 options on the rear:
33508321018 - 170-60-170 33508321019 - 170-60-180 33508322138 - 170-60-190 33508342780 - 170-60-200 33508342781 - 170-60-210 33508342782 - 170-60-220 All - as you say - for a rear coilover. |
Vojta89201.00 |
| 06-01-2022, 04:18 PM | #10 | |
![]() 201
Rep 199
I had 80 N/mm rear and went for harder track setup with 120 N/mm, but this is crazy hard 😁 Btw, Nitron has 110-130 N/mm as far as I know KW Clubsport is not real coilover at rear, so makes no sence to post it here
| 06-02-2022, 01:11 PM | #12 |
862
Rep 1,957
Yep. Which are listed in the above. But that's still over 1100lbs/in front - 1000lbs/in rear against stock rates of 218 lb/in front and 528 - 681lbs/in rear (noting the stock springs are separate and further inboard, so act as if they are even softer). So, a front bar designed for that is bound to dominate - as you mention - on anything designed for road use. Yes?
Last edited by M Fifty; 06-03-2022 at 03:12 AM.. Reason: Added the bit about the different rear spring locations |
| 06-03-2022, 03:22 AM | #13 | |||
![]() 141
Rep 100
| 06-03-2022, 08:57 AM | #14 |
![]() 4767
Rep 3,914
I'm far too lazy to wash the underside!
MooMooM21910.00 |
| 06-06-2022, 02:50 PM | #15 | |
862
Rep 1,957
I've yet to get the scales out and weigh it, but the centre section of the bar used on the M2CS is 24.4mm. So it might actually be softer than the stock bar. Updates on how much it weighs once I locate my scales... |
| 06-18-2022, 09:57 AM | #16 | |
862
Rep 1,957
Edit: But, the smaller diameter centre section - in addition to being 0.4mm smaller diameter than the stock M2/M2C bar - is a smaller diameter for quite a bit longer. I'll see how if feels on the drive to work tomorrow using the twisty route, but the initial shakedown drive suggested the rear end is more mobile under power in longer bends (even with all the electronic nanny still on...) Last edited by M Fifty; 06-20-2022 at 12:25 PM.. |
| Bookmarks |
