06-15-2021, 12:19 AM | #1 |
@lbb_kev
491
Rep 514
Rogue Engineering Transmission Mounts
Despite running the AutoSolutions SSK, Ultimate Clutch Pedal, and a CDV delete I would run into shifter resistance when up-shifting to the next gear. This was due to transmission deflection, which was made worse by my car's significantly increased torque.
So after some research I came across the Rogue Engineering transmission mounts as one of the better options for dual purpose cars. In the attached photo, I'm holding the stock transmission mount compared to Rogue's. I can bend the stock one with my thumb and index finger, while Rogue's mount design is a solid piece made of neoprene rubber that reduces deflection while minimizing NVH. Had these installed today and, my god, the difference in feel is enormous with a minute increase in NVH (Would have to listen for it). The shifter goes directly in on upshifts now with no hesitation, as it should be. With over fifty miles on the mounts so far I can safely say that this is probably the best bang for your buck mod ($59) that you could do for shifter feel after the CDV delete, especially if you're tuned and pushing a lot of torque. If you have a good shop to do it it should take no longer than an hour for install (Thanks SD Garage!). Might as well install an E90 slave cylinder to delete the CDV while you're at it if you haven't done so already.
Full E85 DI-Only 717WHP Flex Fuel tuned by BendCalibration (ECUTek) | Built by SD Garage Last edited by -Eidos; 06-15-2021 at 12:28 AM.. |
06-15-2021, 02:21 PM | #2 |
Rep 433
I've done the same mods as you including the E90 clutch slave (CDV delete), Ultimate Clutch Pedal, Auto Solutions SSK (80a+ bushings) and the Rogue Engineering transmission mounts
The change in shifter feel is simply amazing As you noted, the stock transmission mounts are incredibly soft I did experience a slight increase in NVH, but well worth it IMO |
06-15-2021, 02:43 PM | #3 | |
@lbb_kev
491
Rep 514
The change honestly shocked me. Something always felt off despite doing the "Big 3", so I'm glad that there's a relatively cheap solution.
06-15-2021, 03:42 PM | #5 |
@lbb_kev
491
Rep 514
Can purchase it from Rogue Engineering directly:
https://www.rogueengineering.com/Rog...nts_p_137.html Ships from New Jersey.
tenkies147.00 |
08-05-2022, 11:00 PM | #6 |
Rep 1,244
Drives: 2017 Big Turbo BMW M2
does this only benefit manual cars ? I'm sponsored by 034Motorsports and realized they sell them for the M2 but wasn't sure if this works on DCT vehicles
08-08-2022, 12:22 PM | #7 | |
@lbb_kev
491
Rep 514
It's a cheap mod and the install is straightforward, so I'd give it a go
08-08-2022, 04:56 PM | #8 |
Rep 7,429
Man how did I miss this thread? Ok this is going to be fun laying on my back doing this job.
shaneguags1189.50 |
08-08-2022, 11:38 PM | #9 | ||
Rep 1,244
F87source7251.50 |
08-09-2022, 12:05 AM | #10 |
Rep 7,429
Yeah it seems like a mod you can pass on. But for me I'll do anything for better shift feel.
08-09-2022, 12:12 AM | #11 |
Rep 1,244
it seems cheap, especially with my sponsorship discount. maybe I should just try it out
08-09-2022, 12:29 AM | #12 |
Rep 7,429
08-09-2022, 12:38 AM | #13 |
Rep 1,244
unfortunately, I have no lift and live in an apartment garage without tools so I'd be outta luck for self installment
08-09-2022, 01:15 AM | #14 |
Rep 7,429
Ah I see. Well technically you don't need a lift, I do all of my work on 4 ramps. I prefer ramps because I feel it's much more stable as the car was designed to stay permanently on 4 wheels which also has much more surface area contact than the jack pads. I also use bmw scissor jacks at the jack points + 2 jack stands on the rear sub frame for extra security. So that's my setup.
08-09-2022, 01:26 AM | #15 | |
Rep 1,244
08-09-2022, 01:42 AM | #16 |
Rep 553
Would these be a relatively easy diy install with the car up on stands? (I'm no mechanic but have installed my Ohlins, replaced rotors & do all 3 oil changes)
08-09-2022, 02:19 AM | #18 | |
Rep 7,429
Then since I am always as careful as possible I put bmw scissor jacks (with the recantgular jack adapter which sits perfectly into the jacking pad) under each jack pad, these do not sink like hydraulic jacks and can hold the weight of the car for prolonged periods without dropping. They have a decently wide base so tipping is not a major risk, so this is another line of safety. Then I put jack stands under the rear subframe. So it is really really secure. Wheels are chocked, parking brake is on, car is in gear. I've put alot of torque into the car while it was up in the air like this while replacing the stiffening plate bolts and torquing it and the car is always rock solid. Ramps are also super light weight so it is really easy to move around.
08-09-2022, 02:22 AM | #19 | |
Rep 7,429
If so it would be doable. Easy depends on your mechanical skills, but not too difficult because everything is right there.
08-09-2022, 02:28 AM | #20 | ||
Rep 1,244
08-09-2022, 02:50 AM | #21 | |
Rep 7,429
08-09-2022, 02:53 AM | #22 | ||
Rep 1,244
