Bimmerpost
4 Series
Marketplace Vendors Classifieds Suspension / Brakes / Chassis / Spacers Ohlins R&T for your G20 G21 RWD & X-Drive - Worldwide shipping!
      06-09-2021, 02:17 PM   #1
HP Autosport
Supreme Allied Commander
Drives: F80 M3
USD 2,990.00
This is the latest step in the Öhlins Racing automotive philosophy – Road&Track by Öhlins.
A more than 30 year long tradition of high-end racing commitments and state-of-the-art solutions within
advanced suspension technology is now available for street cars all over the world.
The focus has been clear from the very beginning – superior road handling without sacrificing comfort in your day-to-day transports. The time of compromises are over!
We have also added a clever light-weight design with a majority of the parts in aluminium and on top of that all shocks have suffered through vast corrosion tests according to ISO 9227. The end result is a 2-year limited warranty on all of our products - worldwide.
General
> DFV (Dual Flow Valve)
> Rebuildable
> Corrosion salt spray tested (ISO 9227) > 2 year Limited Warranty
Front
> McPherson Strut
> Single bleed adjuster
> Spring preload adjuster (approx. 20 mm lower than standard)(5 mm on M sport) > Coil Springs (rate 80N/mm)
> Dustcovers
> Use with original top mounts
Rear
> Conventional Shock Absorber
> Separate spring preload adjuster (approx. 15 mm(5mm on M Sport)
> Coil Springs (rate 140 N/mm)(Additional springs at the rate of your choice will be supplied at no additional cost)
> Dustcovers
> Use with original top mounts F2x F3x
(X-drive and RWD) 1-series (F20,F21) 2-series (F22,F23) 3-series (F30,F31,F34,F35,G20,G21) 4-series (F32,F33,F36)
One in stock as of 12/19/2021
***Vehicle with EDC will need to have EDC coded out***
***We can ship the standard kit worldwide at a very discounted rate. PM us your address for a quote!***
BMS MU00S1
$2990
      12-17-2021, 08:35 PM   #2
HP Autosport
Drives: F80 M3
Price adjustment for 2022. PM for details!
g20
