BMW 3-Series (E90 E92) Forum
N52 long crank cold start
05-14-2021, 12:15 PM | #1 |
Rep 3,386
Hello,
Recently I have noticed that my N52 takes an extra second or two to start after sitting for a day or longer. If I start it up and drive around for even 5 minutes and turn it off and back on it fires up no problem. Battery is only 3 or so year old. Any thoughts would be greatly appreciated!
05-19-2021, 08:19 AM | #3 |
Rep 852
What if you leave the key in the slot with the start button pressed with foot off the brake for like 10 secs before starting? Does it do the same thing? Would be worth scanning too
Airplane Mechanic
BMW Masochist |
05-19-2021, 01:35 PM | #4 |
Rep 3,386
Scanned and no codes and I actually already did that when starting it I just didn't film the beginning part. I always wait a few seconds with the key in and powered up before starting because was told it helps prime the fuel pump and makes it start easier.
05-19-2021, 10:05 PM | #5 |
Rep 558
My 5c would be not to worry about it, at least for now.
My E91 does exactly the same, no codes, 2 year old battery You could spend countless hours replacing spark plugs, coils, fuel pump & fuel regulator, CCV, starter, etc. Mine does "feel" better next morning after long 3 hour drive up in the mountains a day or two before. I also have 3 diesels - all fire up instantly - and my brain wants the older NA gasoline engine to do the same. 3 years ago I was told that my WP is dying and will give up any moment. Since then I replaced the battery (WP code went away) and driven 25K miles. When it (WP) dies - I'll replace it. If it bothers you too much, I'd probably start spending time and $ on the fuel regulator. Last edited by POBEP; 05-19-2021 at 10:14 PM.. |
05-20-2021, 03:49 PM | #6 | |
Rep 3,386
If it only happens after sitting 24 hours plus I feel like the theory of it being fuel pump related makes sense, but I'm certainly no mechanic.
05-23-2021, 03:00 AM | #7 |
Rep 558
michaelalex17
New data point. I let my E91 / N52K sit parked for 5 days. Ambient temperature was approximately 5C yesterday. I let ignition stay ON for good 15 seconds. It fired up right away, no delay. |
05-23-2021, 10:23 AM | #8 |
Rep 3,386
Thanks for sharing! I have a strange data point too which is I left the car for several days and when starting this time I removed the ancillary cig lighter charger and turned the headlights off and it seemed to start faster. Maybe that stuff was drawing juice from the battery on startup? Will keep updating on developments.
POBEP374.50 |
05-27-2021, 10:03 AM | #9 | |
Rep 558
New data point for my E91 - 22 hour rest time - 11C outside temp - start/stop button pushed immediately after opening the car - the starter spinned fine, but took nearly 5 seconds to fire up the engine At this point, I choose to believe that my E91 has issue with fuel delivery for the following reasons - battery is new and has 80% or more charge - starter spins fast, even during long cranks - no rough idling (not a CCV/ignition issue) - ambient temps does not seem to be a factor - keeping ignition on for 10s before startup after overnight rest always helps However, I am going to hold on to repairs, at least for now. |
05-27-2021, 11:21 AM | #10 | ||
Rep 3,386
06-09-2021, 11:57 AM | #11 | |||
Rep 144
Drives: 2006 BMW 325i (E90)
I was wondering if you have any updates on the situation? I'm also experiencing slow cold starts. I have a 2006 325i with 176k miles. I have reason to believe it's the starter but I'll take any inputs. I'm thinking about posting a video to see if that helps. |
10-12-2021, 07:16 PM | #14 |
Rep 3,386
Been awhile since updating this thread. So far have replaced the crankshaft position sensor, battery, spark plugs and none of those have helped. My last ditch effort is to replace the fuel pump and fuel filter and fuel pressure regulator. Will let you guys know if that ends up finally fixing the problem.
10-19-2021, 12:11 PM | #15 |
Rep 227
My N51 E90 experiences this same issue. If it sits for a few consecutive days, it will crank a bit longer than the OPs car.
I'm interested to see what others find here, but a well trusted shop looked into mine and didn't find any immediate issues. They recommended waiting to see if it gets any worse and so far, it has remained steady. |
10-19-2021, 12:19 PM | #16 | |
Rep 3,386
10-19-2021, 04:33 PM | #17 |
Rep 227
A few months. Car has always started on the first try, however. Please do let us know what you find.
10-20-2021, 10:33 AM | #19 |
Rep 3,386
That's good to hear! Should be doing install at some point this week.
10-23-2021, 08:12 PM | #20 |
Rep 189
sounds like fuel side issue based on everything else you eliminated. (rare case being valvetronic motor, essentric shaft sensor or crankcase sensor, if u getting rough idle after the long crank too)
try running some fuel treatment/injector cleaner for atleast 2 tanks if havent already, you'd be surprised. i used Lucas, made noticeable difference when i was getting low RPM hesitation, even after doing plugs/vanos/checkvalves etc... |
10-26-2021, 09:40 AM | #21 |
Rep 144
Hi
Just wanted to chime in again, after a succession of slow cold starts my starter decided to give out. Went to replace it and it fires up immediately every time. Hope this helps. |
