01-02-2021, 12:38 AM | #1 |
Rep 1,288
Drives: 2015 335i xdrive Msport Mbrake
Charging battery
A message came up and said to drive the car to charge the battery... I took it on a 25 minute drive and it disappeared but came back on after a couple of stops... question is can I take the battery out and charge it...can't really charge it in the car in the buildings garage.... thought I read somewhere this might cause issue with something... thanks in advance...
Or should I just buy a new battery... I'm pretty sure this is the original which would make it 5 years old... Last edited by FastF30; 01-02-2021 at 12:45 AM.. |
01-04-2021, 10:20 AM | #3 |
3606
Rep 10,372
5 yrs on an AGM isn't bad but they can go much longer. I would invest in a trickle charger (ex.CTEK 7001)) and see how that works out. The charging posts are located in the engine bay.
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line |
01-04-2021, 11:20 AM | #4 | |
Rep 7,622
01-04-2021, 12:07 PM | #5 | |
Rep 1,288
Should I try charging the battery but I have to take it out to charge going back to my original question.... or should I just get the new battery... Last edited by FastF30; 01-04-2021 at 12:14 PM.. |
01-04-2021, 12:14 PM | #6 | |
Rep 7,622
Also, it can take more than 25 minutes of driving to charge the battery, depending on what type of driving you did. In any case just unplug that, take the car on a long drive (with coasting in particular) and see if the message comes back. |
01-04-2021, 12:32 PM | #7 | |
Rep 1,288
01-04-2021, 12:38 PM | #8 |
Rep 7,622
Keeping RPMs up doesnt necessarily mean charging in these cars... most of the charging is done when you are costing and you see the MPG gauge go to the blue in the cluster (with battery symbol). Sport/S might actually make that happen less, although im not entirely sure.
01-04-2021, 12:56 PM | #9 | |
Rep 1,288
01-04-2021, 01:47 PM | #10 | |
Rep 1,288
01-04-2021, 01:55 PM | #11 |
Rep 7,622
01-04-2021, 02:06 PM | #12 |
Rep 1,288
Yea... I thinking that too more I think about it... I've always gotten the message every winter but this time it said to drive car... can I take it out and charge it????? ....
01-04-2021, 02:16 PM | #13 |
Rep 1,288
One video said that phone charger adapter in cigarette lighter could also contribute to it...
01-04-2021, 02:19 PM | #14 | |
Rep 7,622
Yes, definitely. I believe the 12V, at least the one in the passenger area, has full time power and not just with ignition/acc on. You basically don't want to leave anything plugged in there if you are not driving the car for a while. |
01-04-2021, 02:26 PM | #15 |
Rep 5,385
Winter and not driving the car often are draining the battery. These car's require a lot from the battery. I've gotten the same error as you have in the winter when my battery was just 3 years old. You really should get a trickle charger like a MUSE 4.3 and get the battery fully charged. I've never had an low battery issue since and the battery in my M235 is 5 years old. Driving 25 miles will not fully charge the battery, especially if the car sits for a long period of time in the cold. I charge all our cars (2016 M235, 2020 4Runner, 2015 Outback) on the trickle charger once every 2 to 3 weeks in the winter to keep the batteries strong.
visionaut1311.50 |
01-04-2021, 04:04 PM | #16 | |
Rep 1,288
01-04-2021, 04:41 PM | #17 |
3606
Rep 10,372
01-04-2021, 04:55 PM | #18 | |
Rep 7,622
In terms of longevity for the battery, is it better to just let the car do its thing, or should i put on a maintainer whenever i park the car for that ~1 week (or a little more) at a time? |
01-04-2021, 08:16 PM | #19 |
Rep 888
Since COVID, I'm out and about a lot less - so I've added a maintainer for year-round use (or in BMW parlance, a Battery Comfort Accessory). Got those 'low battery' iDrive msgs after it sitting. It prolly cost a bit more, being BMW kit, but it's very nice gear, with car-like 8-stage charging, and it's Auto/MC, Lead/Li switchable.
I've been using it for last 3 months - it's super - and I just installed the additional 'Comfort Indicator Panel' (who comes up with these names?) today to the front grille on my F36. Check my post in the 'what have you done today' thread for pics... All my other cars are on Battery Tender gear while garaged, but for the 435 outside, given it's special battery management needs, I opted to go OEM... Highly recommended. BMW charger: 61432408594 BMW comfort indicator panel: 61432289105 |
FastF30521.00 |
01-04-2021, 08:49 PM | #20 |
Rep 245
BMW charger costs upwards of $150, it is basically the same thing as the CTEK one, right now amazon has it priced at $78.. I have used the CTEK battery charger without issues, but use it when battery is in the vehicle & garaged at home.
01-04-2021, 09:13 PM | #21 | |
Rep 1,288
This is the charger I bought for when doing unlocking of DME... might find something smaller just for trickle charging... One thing I'd like to note is I read somewhere that you either have to have the hood all the way up or closed... anywhere in between could cause the hood struts to leak.... this was on a E90 so don't know about F30s gonna go charge now... google says roughly 3.5hrs at 15amps... that is great for me... just hope the spot is still empty... Update... spot was full... just gonna go buy a new battery... Last edited by FastF30; 01-04-2021 at 09:37 PM.. |
01-05-2021, 07:10 AM | #22 | ||
3606
Rep 10,372
