12-16-2020, 11:46 AM | #1 |
Rep 90
i got a new hpfp lpfp o2 sensors and a bpm4 the cars running stronger with the bom4 but my fuel pressure is still dropping
https://www.bootmod3.net/log?id=5fd9...90c60e1369f82f https://www.bootmod3.net/log?id=5fd9...0b4331d04fa34b https://www.bootmod3.net/log?id=5fd9...0b4331d04fa348 mod list ps2 ewg intake intercooler downpipes walbro 450 bpm4 pr coils pi installed but not connected yet |
12-16-2020, 12:29 PM | #2 |
Rep 7,622
Who did the install of the LPFP and HPFP? Did you have fuel pressure problems before the installs? Were both installed at the same time? Which HPFP?
You're only running about 17psi of boost, and although you have a PS2, realistically you dont need any fuel system upgrades to support this with a stock healthy fuel system. Especially the LPFP. What prompted you to upgrade HPFP and LPFP in the first place? All signs point to a problem with the HPFP or LPFP. I think the HPFP is harder to 'install wrong' than the LPFP where you could be leaking some supply. I would also note that, probably due to the HPFP crash, your STFTs are pegged at 1.3 and your AFRs are very unstable and you are going into the mid 14s at full boost, which is not really good, especially on 93. Timing targets are also quite aggressive for a 93 map. I would be weary of doing a lot of pulls like this. Also, you have a custom tune, so you should be asking your tuner... unless he's the one who told you to upgrade the fuel system in the first place. I'm looking mostly at this log: https://www.bootmod3.net/log?id=5fd9...0b4331d04fa34b |
12-16-2020, 12:43 PM | #3 | |
Rep 90
get the car 100% right now but a shop tested the sending unit and the hpfp and there fine the cars runing better with the bpm4 before the car would cut out at 4500 rpm now it can actually rev out without any fuel cuts stock hpfp and i always had fuel cuts in the upper rpms since i flashed my ots stage 2 tune but it wouldn't lean out |
12-16-2020, 02:46 PM | #4 | |
Rep 7,622
12-16-2020, 03:17 PM | #5 | ||
Rep 90
12-16-2020, 04:25 PM | #6 |
Rep 7,622
12-17-2020, 07:05 AM | #7 | |
Rep 90
12-17-2020, 10:05 AM | #8 | |
Rep 7,622
Why did you upgrade the LPFP and not the HPFP? That's completely backwards, since the HPFP runs out of fueling capacity far before the LPFP. I don't see how it could be the fuel pressure sensor. If you switch to a tune with lower boost and the HPFP doesnt crash i would say that's strong evidence its the HPFP itself. EDIT: I just realized you said you have PI. If you are going PI instead of HPFP for extra fuel, you need to get that turned on and tuned rather than relying on stock HPFP.... Last edited by thejeremyman9; 12-17-2020 at 10:29 AM.. |
12-17-2020, 11:08 AM | #9 | ||
Rep 90
https://www.bootmod3.net/log?id=5fa1...90c6740c921c4e https://www.bootmod3.net/log?id=5fa1...729b441f87f8de |
12-17-2020, 11:36 AM | #10 | |
Rep 7,622
12-17-2020, 02:17 PM | #12 |
Rep 90
i took it to a performance bmw shop and they tested everything leak testing etc spent 2 weeks diagnosing it. i had the pi for while, before spool came out with theres. i just did installed it with the ps2 turbo this summer.
12-17-2020, 02:23 PM | #13 | |
Rep 7,622
1. LPFP 2. HPFP 3. Pressure control for HPFP If the shop is absolutely confident its not 1 or 2 due to their testing, you should look at #3, which i am less familiar with. You could just be not regulated HPFP pressure correctly so you are 'bleeding' pressure/flow. |
12-17-2020, 03:09 PM | #14 | ||
Rep 90
12-17-2020, 04:36 PM | #15 |
Rep 7,622
