Bimmerpost
4 Series
Technical Topics B58 6-Cylinder Turbo Engine / Drivetrain / Exhaust Modifications Any1 have bms catch can? any results would help
      10-21-2020, 03:20 PM   #1
Obitelb
Obitelb's Avatar
15
Drives: M340
I wanna know if this catch can actually works let me know
      10-21-2020, 05:04 PM   #2
Fuel-It!
550
Drives: M4, M5, M2C, X4M, 440i, etc...
We run one on all of our B58s, works very well, and a nice clean install package.
      07-31-2021, 07:27 PM   #3
SuprBmwG20
Drives: Bmw G20 M340i
I have a BMS catch can on my car for about 6,000 miles now and it hasn't caught any oil.
      07-31-2021, 07:35 PM   #4
k4sh_90
k4sh_90's Avatar
Drives: 2020 BMW M340i xDrive
Had mine on for a while now (4-5K, lost count honestly) and it hasn't collected anything. The Supra guys have a Mishimoto option that connects on the other end of the engine that supposedly catches stuff from there than where the the BMS connects up.
2015 Kia Optima SX Turbo -> 2017 Infiniti Q50 Red Sport AWD -> 2018 BMW 340i xDrive -> 2020 BMW M340i xDrive
Hey Google, play "Who Am I" by Beenie Man
gorthol64.00
      07-31-2021, 08:42 PM   #5
G_B58
Drives: BMW 340xi
I was wondering the same thing, between vtt bms or mishimoto. I switched to the ftp inlet, and noticed a decent amount of oil in the old inlet pipe, so thought it might be a wise and fairly cheap preventative mod.
      08-01-2021, 09:07 AM   #6
k4sh_90
k4sh_90's Avatar
I recently saw the VTT one. It looks like it connects off a vacuum hose from the inlet whereas the BMS hooks up off a PCV line. But nothing really comes through the PCV line, from what I understand.
      08-01-2021, 10:44 PM   #7
G_B58
Drives: BMW 340xi
Has anyone tried the vtt catch can?
      08-02-2021, 02:26 PM   #8
k4sh_90
k4sh_90's Avatar
Been reading up on these as well. Marketed towards the Supra, but a B58 is a B58 and mounting is identical. Looks a bit more robust than just a catch can as it'll filter and drain the oil it caught back into the engine.
      08-03-2021, 09:28 AM   #9
G_B58
Drives: BMW 340xi
That does look interesting, I was looking at their heat shield before but pretty sure it wouldn't fit.
      08-03-2021, 11:43 AM   #10
k4sh_90
k4sh_90's Avatar
It should fit. I was following the Supra instructions for the charge pipe swap I did. Only difference I noted between engines (and subsequently engine bay) is the clip on the stock charge pipe actually having a coolant hose running through it or not.
      08-03-2021, 12:50 PM   #11
G_B58
Drives: BMW 340xi
The heat shield would fit?
      08-03-2021, 01:05 PM   #12
k4sh_90
k4sh_90's Avatar
I haven't installed the heat shield on my car. But, checking out the installation instructions and install video for the heat shield and it's pretty much the M340 engine bay I'm looking at, aside from the different engine cover.
      08-03-2021, 02:50 PM   #13
G_B58
Drives: BMW 340xi
I know they have two versions, because I believe 2021 there was a small change.
      08-03-2021, 03:55 PM   #14
k4sh_90
k4sh_90's Avatar
Ohhh. Sorry about that. I have a 2020, so I was speaking in that regards. I'm not certain about the 2021s.
      08-03-2021, 10:06 PM   #15
G_B58
Drives: BMW 340xi
I have a 2020 as well, i meant the supra versions changed slightly. Versus has two versions, and I believe even the downpipe mounting bracket changed in 2021.
      08-03-2021, 10:24 PM   #16
SuprBmwG20
I like the concept of the mishimoto catch can but seems like even this style catch can doesn't catch any oil
      08-04-2021, 09:38 AM   #17
G_B58
Drives: BMW 340xi
So does anyone have any experience with any of these options on the b58tu? Preferably on a non-tuned car, I would imagine if it worked on a stock car then with a tune it would only catch more anyways.
      03-11-2023, 11:10 PM   #18
Virtality
Drives: 2020 BMW G20 M340i X-Drive
Yeah, I'd love to get an update on this.
For one, has anyone used the heat shield and tested fitment. I have one from a 2021 Supra and I'm putting it in my 2020 m340i if it will fit.
Secondly and most importantly, has anyone found a catch can that will work for the VVT side or tested the Supra one. That's really the main thing I'm worried about.
      03-12-2023, 12:37 AM   #19
xnick101
Drives: 2021 BMW X3 M
2020 BMW M340i  [0.00]
I have a verus 2021 supra 6 port heat shield on my car. Fits perfectly. Should be the same.
2014 BMW 335i M-Sport - SOLD
2020 BMW M340i - SOLD
2021 BMW X3M
      03-12-2023, 12:36 PM   #20
Burr001
Burr001's Avatar
Philippines
3251
Drives: 2022 X3 M40i
2022 BMW x3 m40i  [10.00]
Just wanted to share my BMS OCC install and how much crap it filtered after 6 months and 10k miles...https://x3.xbimmers.com/forums/showt...hlight=bms+occ
rmedina114.00
      03-12-2023, 12:54 PM   #21
Virtality
That's not for the VVT side though. While I have one of those it's really not necessary as it catches almost nothing.
      03-12-2023, 02:28 PM   #22
kfer
Drives: G20-330e
I did a turbo upgrade and had to remove a lot of parts, the stock inlet too. So I‘ve noticed, that there is an „integrated“ catch can and that should be enough. As you can see, the vent pipe is connected to the upper side of the inlet, and if there is any oil, then it will be collected in the red marked part of them ( of course it can be full at some point). The ventillated gas/air comes back trough the lot of small holes into the inlet.
rmedina114.00
g20
