06-16-2020, 03:23 AM | #1 |
Rep 54
AK Motion OPF Delete with JB4 Map2
Hi there,
since my OPF is getting removed and i am on locked DME Software i am wondering if there is any chance to run the AK Motion OPF Delete in combination with JB4 Map2. As far as i know - if i unplug die OBD connector of the JB4, it is just adding boost like on map1. is there a way to use map 2 and the datadisplay(active) at the same time. At the Moment the Data Display is in passive mode(just oil and water temperature) BR |
06-16-2020, 07:02 AM | #2 |
Rep 744
Cant you just use one of these and run them in parallel?
https://www.amazon.com/obd-splitter/s?k=obd+splitter Also maybe I would try and us the USA maps if you remove the OPF. The exahust restriction will change which might lead to overspooled turbos no?
06-16-2020, 07:39 AM | #3 | |
Rep 54
i dont think this will lead to overspooled Turbos because you can drive complete catless aswell... |
06-16-2020, 04:01 PM | #4 | |
Rep 744
I dont think there are many people in your situation sadly. You might just have to try and see if there are any conflicts.
06-17-2020, 02:38 AM | #5 |
Rep 54
i think i will give it a try. otherwise i will use jb4 without obd....should be map1 then
06-17-2020, 04:41 AM | #6 |
Rep 1,477
Doesn't JB4 include an OPF-delete function?
