11-12-2019, 09:35 AM | #1 |
Rep 3,130
NEW RELEASE: Dinan S55 Flash Tuning (F87 M2C & F8x M3/M4)
Dinan S55 Flash Tuning (F87 M2C & F8x M3/M4) Part Number(s): D900-S55-S1-W / -HE, D900-S55-S1 Applications:
Description: Dinan has a long and storied past when it comes to engine tuning having introduced our first engine performance chip in the mid 80's — over 3 decades ago. From those early years with chips, followed by engine software and then to our own external control modules we have become experts in nearly every possible way to extract safe, reliable power from the factory powerplant. While we have long preferred the unheard of control and sophistication capable of being achieved from engine software, over the past 6 years that option was not one afforded to us. That changes now with the re-introduction to flash tuning for Dinan with the S55 engine. The first of the next generation of Dinan flash tunes the S55 calibrations are held to the same principles of the past; performance, reliability and safety. Dinan performance engine software is so much more than just tuning up the turbo boost after all. It is a fully re-tuned engine management program that maximizes power while keeping all the BMW factory safeguards in place. Protecting your BMW while giving the most performance is the definition of "Performance Without Sacrifice". Drivetrain and engine components are analyzed for strength then the calibration is tested on the dyno and in the real world for durability and drivability. This next generation of Dinan flash tunes does differ from the past however in that there are many different options to choose from depending on your needs or desires. Whether you want a warranted tune for 93 pump gas when under the factory warranty, an E85 performance tune for maximum performance when outside of the factory warranty, or something in between, chances are Dinan has an option for you. Features and Benefits Common to All S55 Performance Engine Software Variants:
Features, Benefits, Requirements and Power Charts Specific to "Dinan +" S55 Performance Engine Software:
Features, Benefits, Requirements and Power Charts Specific to "Dinan +HE" S55 Performance Engine Software:
Features, Benefits, Requirements and Power Charts Specific to "Dinan Stage 1" S55 Performance Engine Software:
COMPATABILITY NOTICE - BOX CODES & JUNE 2019 FACTORY UPDATE DME box code and bootloader information must be obtained from the vehicle to determine if a vehicle is flashable in its current state. In some cases we will need to create a file for your vehicle. This process could take several days and multiple dealer visits. Vehicles previously serviced or updated after June of 2019 may have received a DME bootloader update from BMW. This bootloader version will prevent the Dinan software upgrade from completing. DMEs with the updated bootloader must be removed from the vehicle, and sent to Dinan HQ to have the bootloader backdated. DMEs sent to Dinan for the backdating procedure will not be opened or physically modified in any way. Once the DME is returned to the dealer, they must still be flashed with the Dinan performance software through the OBDII port. If a previously backdated and flashed ECU is updated with the new bootloader, the above process will need to be repeated. Dinan will not pay labor under warranty to remove and reinstall ECUs that were previously backdated, and then updated by BMW or a third party. DINAN S55 ENGINE PERFORMANCE SOFTWARE FAQ: I already own a DINANTRONICS Elite kit for the S55 engine, can I switch to the flash? Yes, you can trade in your existing DINANTRONICS kit and qualify for a warrantied tune (balance of the factory matching 4yr/50 k warranty) upgrade for only $149.95. If you are already out of warranty or simply want more power you can opt to switch to the full stage 1 options (no factory matching warranty) without any associated upgrade fee. Pricing listed is dependent on trade-in of registered, first-hand units. Used, second-hand units do not qualify. When I purchase a Stage 1 S55 flash do I only have access to one of the octane mappings? When a stage 1 S55 flash is purchased you obtain licenses for ALL the various octane maps. However, only one map can be loaded on the car at any given time so if you wish to use a different octane then what is initially loaded it would require a trip to your authorized Dinan dealer for a reflash. Labor / install charges to perform this service would be at the discretion of the dealer. We recommend loading the octane mapping that is most commonly used for the vehicle (91, 93 or E85 most likely) and only do a map change for special occurrences such as a track day. I have the Dinan +/ +HE tune but want more. What are my options? Dinan+ users can upgrade to the Dinan +HE variant at no charge for more power while retaining the Dinan factory matching warranty provided a Heat Exchanger is purchased and installed as well. For those that want even more power you can opt to switch to the full Stage 1 tunes, taking advantage of more aggressive mapping geared for race fuels, at no additional cost. Switching to these mappings however will immediately cease any factory matching warranty obligation. For all of these scenarios, labor and/or install dealer fees still apply. I do not live near a Dinan Dealer can I still purchase Performance Software? At this time Dinan S55 Engine Performance Software must be installed through one of our authorized dealers. Our dealer list is constantly expanding however so check out the dealer locator often at https://www.dinancars.com/authorized-dealers/ to make sure a new dealer has not begun servicing your area. Will Dinan parts be covered under my extended/CPO warranty through BMW? The Dinan warranty (For Dinan+ / +HE variants) matches the new car 4 year / 50,000 mi warranty but does not cover any extended or CPO warranties. Can I flash my vehicle back to the stock tune? Yes, you have the ability to flash the vehicle back to stock but the process would need to be completed by a dealer. There is no cost to do so from Dinan but you would potentially be subject to dealer labor rates to perform the service. What if I am not happy with my Dinan Engine Performance Software purchase? Is there a return window? All Dinan engine software include a 30-day money back guarantee with no questions asked. If for any reason the owner is dissatisfied with the Dinan engine software, they may return to the place of purchase for a full refund, provided they are within the 30 day period from the time of the initial purchase. Labor or shipping charges are not included in the guarantee and are at the discretion of the place of install. Last edited by Dinan_Engineering; 11-12-2019 at 10:33 AM.. |
11-12-2019, 03:11 PM | #2 |
Rep 454
Both of my local Houston BMW dealers are listed as authorized Dinan partners. Will they backdate the DME or does it still have to be sent off?
Great tune! Would love to try it.
Ride: 2020 F87 M2C, 6MT Drive: Nine-Four Motorsports
Before: 2013 - 3.8L GTR, first DCT 2012 - 5.2L R8 v10, 6MT 2011 - 4.0L E92 M3, 6MT |
11-12-2019, 03:58 PM | #3 |
Rep 3,130
Would still have to be sent off if it has been updated to the newest boot loader I'm afraid.
11-12-2019, 04:24 PM | #4 |
8236
Rep 18,833
Drives: BMW
Fantastic, we are an authorized Dinan retailer/flash facility for those in SoCal.
Tom G. | european auto source (eas)
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM |
11-14-2019, 02:27 PM | #5 |
Rep 553
Dinan_Engineering3912.00 |
11-14-2019, 05:09 PM | #7 |
Rep 699
11-14-2019, 06:53 PM | #8 |
Rep 676
When B MW upodated my software in August it fixed a probl;em that caused it to go into limp mode twice and for Apple Carplay to crash over nad over. IUf it is backdated will these problems return?
11-15-2019, 11:28 AM | #9 |
Rep 3,130
Shouldn't. The backdating is localized to the bootloader itself and does not touch any of the programming or coding so the car will have the same updates and patches it had pre-flash.
12-06-2019, 08:02 PM | #11 | |
Rep 198
Haven't had an opportunity to really test it because it's been snowing. Last edited by DriverDaily; 12-06-2019 at 08:07 PM.. |
12-09-2019, 08:54 PM | #14 | |
Rep 198
I previously I've had:
My Impression of the Dinan Tune:
I'm going to try to find a way to get a Dinan intercooler without the Dinan logo. Possibly by media blasting, hot tanking, or with paint thinner. That way I can get the full tune.
Fenerbahce258.50 |
12-10-2019, 10:58 AM | #15 |
Rep 4
Drives: 2002 M3, 2020 M2C
Can you guys do the backdating with the DME in the car if I bring it up to Auburn? I'd rather drive then remove and ship.
12-10-2019, 11:24 AM | #16 |
Rep 1,153
Dinan--
Rumors are that you are working on an N55 flash, too. Correct? If so, will there be more than one version? For example, for those of us who already have the Stage IV M2 with the piggyback, will there be a flash that takes advantage of the uprated turbo and improves on the Stage IV set-up? |
12-10-2019, 11:35 AM | #17 | ||
Rep 3,130
12-10-2019, 12:01 PM | #18 |
Rep 699
12-11-2019, 10:02 AM | #19 | |
Rep 163
It will be interesting to hear your thoughts once you upgrade to the full +HE tune. I'm sure there will be a noticeable difference. |
12-27-2019, 01:34 PM | #20 |
HALA MADRID!
939
Rep 2,879
anyone here done the Dinan+HE tune (max with warranty)?
if so, would you PLEASE chime in and give us some impressions! thanks in advance
F87 M2 Competition, Sunset Orange, Exc, DCT. **SOLD** F80 M3 Mineral Grey/Sakir Orange, Exc, DCT... ED 6/2015 **SOLD**E90 M3, Interlagos Blue / M individual two-tone, ZCP, ZP2, ZCV, DCT, ED. |
12-31-2019, 12:46 PM | #21 |
Rep 198
Dinan_Engineering
01-01-2020, 01:43 PM | #22 | |
Rep 3,130
2. No, stock car (or with HE in the case of that tune variant). 3. Baseline was on 91. |
